Cooling Volcano between tanks of gas    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Volcano S30
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Cooling Volcano between tanks of gas
    Page: [1]
    Login
    Cooling Volcano between tanks of gas - 12/28/2012 7:50 PM
    Flip73
    Score: 100
    Last Login: 12/29/2012
    Status: offline
     New Redcat Volcano S30 and have finished break in steps. Have run two other tanks of fuel.   Do I need to let it cool down between tanks of gas or just refuel and run?  Thanks!
    Hide Signatures
           Post #: 1
    RE: Cooling Volcano between tanks of gas - 12/28/2012 8:42 PM
    nitrosteve22
    Score: 100
    Last Login: 5/12/2013
    Status: offline
    As long as break in is complete and engine is tuned to run correct you should be able to run tank after tank if you like... Always helps to keep an eye on temps though.
    Hide Signatures
    (in reply to Flip73)
           Post #: 2
    RE: Cooling Volcano between tanks of gas - 12/29/2012 2:11 AM
    nitrosportsandrunner
    Score: 296
    Last Login: 5/22/2013
    Status: offline
    this is the advantage nitros have, as long as you have fuel you can keep playing.
    The only thing you want to do if you plan to run multiple tanks in a row is to clean the air filter. If in sandy areas, do this every tank. If its not that bad, then every other tank or so will be fine.
    If you are cleaning the air filter when refueling....use a bit of nitro fuel to clean it. If you used water, the filter will have some water in it and mess up the mixture when you try to start it again. I used to have a small bowl to put a bit of nitro fuel into.
    The other option is to have a couple of air filters, clean, and just swap them between tanks.
    _____________________________
    Redcat Mirage Pro, Tornado EPX Pro, SC10, TTR Phoenix XB. Redcat Racing Dealer.
    Hide Signatures
    (in reply to nitrosteve22)
           Post #: 3
    Page:   [1]
    Page: [1]
    Volcano S30
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.766RCU1
