Green R/C Mini Sopwith Help    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Green R/C Mini Sopwith Help
Page: [1]
Login
Green R/C Mini Sopwith Help - 12/29/2012 12:52 AM
N7532B
Score: 100
Last Login: 1/14/2013
Status: offline
Hello, I'm looking for a copy of the manual or at the very least the CG point for a Green R/C mini Sopwith. I've got her all rigged up and ready to go...almost.
Kurt
Hide Signatures
       Post #: 1
RE: Green R/C Mini Sopwith Help - 12/29/2012 1:23 AM
BrokenSpoke
Score: 100
Last Login: 6/17/2013
Status: offline
Here you go:
http://www.rcgroups.com/forums/showthread.php?t=749694
Look under the section titled F;ying. The last sentence is "You need to find a CG about 50 to 55mm from the leading edge of the upper wing."
Hide Signatures
(in reply to N7532B)
       Post #: 2
RE: Green R/C Mini Sopwith Help - 12/29/2012 4:58 AM
N7532B
Score: 100
Status: offline
Hi,
Thanks but that is the bigger Camel Green R/C produced. I own that one too. (It's a great flying plane!) I was looking for the info on the smaller 26-1/2" wingspan version. I'm certain the same rules apply to it that the balance point is directly above the lower wing leading edge on the upper wing, but I just wanted to make sure. Was also looking for surface throws but I can normally guess pretty good on those too.
Cheers,
Kurt
Hide Signatures
(in reply to BrokenSpoke)
       Post #: 3
RE: Green R/C Mini Sopwith Help - 12/29/2012 10:47 AM  1 votes
cubaneight
Score: 101
Last Login: 6/15/2013
Status: offline
Measure the horizontal distance from the leading edge of the top wing, to the trailing edge of the lower wing. Let's assume that figure is 400mm. A safe CG setting will be 25 to 30% of that figure, measured back from the leading edge of the upper wing.
So. balance the model at 25% of 400mm back from the leading edge of the top wing i.e. 100mm. Just substitute the correct figure for your particular model............works for all biplanes!
Hide Signatures
       Post #: 4
RE: Green R/C Mini Sopwith Help - 12/30/2012 1:55 AM
felicitero
Score: 100
Last Login: 12/30/2012
Status: offline
Hide Signatures
(in reply to cubaneight)
       Post #: 5
RE: Green R/C Mini Sopwith Help - 12/31/2012 6:19 AM
N7532B
Score: 100
Status: offline
Hi,
Well I flew it today for the first time. It is a great little flyer! Plenty of power, easy to take off and land. But, it has one heck of a stall! If you can find one, get one. It is a great canidate for some detailing and weathering.
Too bad it was run into while taxing off of the runway, attacked by a big foamie Parkzone Trojan. Broke some wing struts, ribs and now has puncture wounds. Easy to fix and now it will get detailed and weathered.
Cheers,
Kurt
Hide Signatures
(in reply to felicitero)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.188RCU1
