Which UAT for P200sx    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Which UAT for P200sx
Page: [1] 2   next >   >>
Login
Which UAT for P200sx - 12/30/2012 1:26 AM
Pierrot57
Score: 100
Last Login: 5/21/2013
Status: offline
Hi,
I've a P200sx for my next project, in all model I use BVM UAT, is it good for this turbine or is it too small?
Who have experience?
Best regards.
Pierrot57
Hide Signatures
       Post #: 1
RE: Which UAT for P200sx - 12/30/2012 3:56 AM
ddennison
Score: 103
Last Login: 5/22/2013
Status: online
MY experience:
I have run several 120 (3) and 160 (4) on the BVM UAT with NO problems. One my one 200SX (UltraBandit)I kept having a leak at the plastic bottle neck. I wrapped it with teflon tape etc....still leaked. None of my other (8) UATs ever leaked with usual maintenance. While some say the UAT is fine, I couldt get rid of my leak and switched to a JMP accumulator and it is working well now.
Just my opinion. All of my other 160 and smaller installations all have the BVM UAT and work perfectly as well.
Dave
Hide Signatures
(in reply to Pierrot57)
       Post #: 2
RE: Which UAT for P200sx - 12/30/2012 4:35 AM
sskianpour
Score: 120
Status: offline
GBR CAT. Todd has them for sale. A perfect UAT.
Shaz
Hide Signatures
(in reply to ddennison)
       Post #: 3
RE: Which UAT for P200sx - 12/30/2012 4:57 AM
dubd
Score: 135
Status: online
I've used BVM UATs in a number of P-200 powered planes without an issue, but your results may vary. The JMP Accumulator and CAT products are very good too.
Hide Signatures
(in reply to sskianpour)
       Post #: 4
RE: Which UAT for P200sx - 12/30/2012 6:15 AM
indubitably
Score: 101
Status: offline
I believe that the usefulness of an air trap is over rated. If you have saddle tanks you need to bring the collection to a hopper tank. Good filtration is a nice feature of the UAT and the CAT. So we find them useful for these reasons, but not - in my opinion as an air trap. So use the needed items for filtration, and final combination of saddle tanks, and if you can see into the tank and know the air fuel line, and know the final draw is full of fuel, then its good.
Hide Signatures
(in reply to dubd)
       Post #: 5
RE: Which UAT for P200sx - 12/30/2012 6:25 AM
FenderBean
Score: 119
Status: online
The MAP high flow UAT is nice
_____________________________
Kingtech 170F
Fly Eagle 1/6 F-16 1/7 F-15E 1/7 F-14
Hide Signatures
(in reply to indubitably)
       Post #: 6
RE: Which UAT for P200sx - 12/30/2012 6:55 AM
Ali
Score: 135
Status: offline
For me it has to be the CAT. I have had 4 P-200 powered planes. All with CAT's and all working perfectly. I too have also had 200 set ups running UAT's.. I just have better peace of mind running the CAT's
Regards Al
Al''''s Hobbies. Airworld. BVM, Tams, Jet Cat, AMT, Skymaster, FEJ, pull over, Tomahawk, Skygate, C-ARF, Jet-Teng,Kingtech
Hide Signatures
(in reply to FenderBean)
       Post #: 7
RE: Which UAT for P200sx - 12/30/2012 7:16 AM
davo580
Score: 100
Last Login: 5/20/2013
Status: offline
i use a pst bubble trap it's great
Hide Signatures
(in reply to Ali)
       Post #: 8
RE: Which UAT for P200sx - 12/30/2012 7:22 AM
dubd
Score: 135
Status: online
quote:
ORIGINAL: Ali
Regards Al
Agreed. All I buy now are CATs. They work great.
Hide Signatures
(in reply to Ali)
       Post #: 9
RE: Which UAT for P200sx - 12/30/2012 12:46 PM
jason
Score: 111
Status: offline
quote:
ORIGINAL: indubitably
Hide Signatures
       Post #: 10
RE: Which UAT for P200sx - 12/30/2012 1:02 PM
Pierrot57
Score: 100
Status: offline
Thanks all, I will order the Cat Uat (big model).
Best regards.
Hide Signatures
(in reply to jason)
       Post #: 11
RE: Which UAT for P200sx - 12/30/2012 1:57 PM
hooker53
Score: 100
Status: online
quote:
ORIGINAL: sskianpour
Shaz
+1 can't beat them for keeping the setup clean.
Scratch it till it bleeds Convert it till it chokes
Hide Signatures
       Post #: 12
RE: Which UAT for P200sx - 12/30/2012 2:06 PM
Ragz
Score: 100
Last Login: 5/18/2013
Status: offline
After using a CAT on an Olympus I cannot even think of using anything else. Solid simple build. And SEE THROUGH/translucent. I have used JMP accumulator with great results as well.
Anurag
Hide Signatures
(in reply to hooker53)
       Post #: 13
RE: Which UAT for P200sx - 12/30/2012 5:36 PM
sysiek
Score: 100
Status: online
Hi the most important is not the uat tank ,is the size of yours vent tubs with p-200 minimum 6mm and bigger bras tubing in tank plug ,the bvm ,cat,pst the all work with the same result with proper tanks tubing installation the bigger for vent will make all uat to work just fine.
Hide Signatures
(in reply to Ragz)
       Post #: 14
RE: Which UAT for P200sx - 12/30/2012 7:37 PM
DiscoWings
Score: 102
Status: offline
IV bags work the best, put 2 of them instead of fuel tanks, guaranteed no air bubbles, BUT DON"T CRASH![>:]
"Hi,You are 100% correct but are also 100% wrong... "
- rcflip
Hide Signatures
(in reply to sysiek)
       Post #: 15
RE: Which UAT for P200sx - 12/30/2012 8:45 PM
ddennison
Score: 103
Status: online
For clarity, my ultra bandit installation did have dual large vents (which I always use as well) and still would leak with the 200SX.
I am not arguing with others and their installation, just reporting my earnest attempt with a bulletproof fuel line installation to make my UAT work with the BVM UAT for the 200SX.
Perhaps I had a bad bottle or top but my other BVM UATs have all worked flawlessly on the 160 and smaller turbines.
I just was not inclined to buy another one to see if it would still leak and just switched to the JMP so I could get flying.
Hide Signatures
(in reply to DiscoWings)
       Post #: 16
RE: Which UAT for P200sx - 12/30/2012 9:04 PM
sysiek
Score: 100
Status: online
Once I have same problem with the uat that was not the teflon tape the problem was on the main seal in one of the brass nipple check them all I used mine retract pump and water when I did lurked over 8 lbs one nipple start to leak ,I used the shogoop to seal and tested after 48h and till now no problems.
Hide Signatures
       Post #: 17
RE: Which UAT for P200sx - 12/30/2012 9:22 PM
ddennison
Score: 103
Status: online
mine was at the neck
Hide Signatures
       Post #: 18
RE: Which UAT for P200sx - 12/30/2012 9:42 PM
sysiek
Score: 100
Status: online
Just take a part and use some shogoop tide and don check after two days should be fine ,once I expiring problem with mine fill plug same story air in uat and once mine fuel line inside the main tank get suspend forward and up from storing mine jet on his nose rudder up ,just one minut after take off engine stop safe landing and sample fix I just point jet up nose and shake til jingle noise in tank.
Hide Signatures
       Post #: 19
RE: Which UAT for P200sx - 12/30/2012 11:22 PM
ddennison
Score: 103
Status: online
I guess that is my point, I didn't have to do anything with the JMP accumulator to make it work.
Hide Signatures
       Post #: 20
RE: Which UAT for P200sx - 12/31/2012 12:55 AM
sysiek
Score: 100
Status: online
Hi the jmp is same as others ,mine friend used one for lake 4 years till the seal get hart and crack in one spot ,I did same think tested go to ACE hardware store got all new seal replaced and is working til now ,I think ther is no forever uat just one the work til the is time for service if the losing the vacuum seal .
Hide Signatures
       Post #: 21
RE: Which UAT for P200sx - 12/31/2012 1:11 AM
sysiek
Score: 100
Status: online
The only think I do not lake in the jmp is the think is not clear the is no ways to look for air to locate if ther is problem with the uat to lost vacuum ,I using the cat ,bvm and the micro model aviation products for small jets.
Hide Signatures
       Post #: 22
RE: Which UAT for P200sx - 12/31/2012 1:38 AM
darryltarr
Score: 100
Status: offline
From several years of experience with P-200 and P-200SX (and limited time on B300F), the TWO best systems are:
JBR-Jet CAT (260ml), plus Marc can also custom make you a bigger size if required
JMP Machined Air Accumulator
Both of these systems have the 6mm (3/16") High Flow fittings
Hide Signatures
       Post #: 23
RE: Which UAT for P200sx - 1/1/2013 3:29 PM
ricardinho
Score: 100
Status: offline
hello there i have really been considering one of these for my new build... i am building a new ultra lightning with a p180rx.. i had one before that i sold with the bvm uat... after each flight lots of wide open throttle i noticed a third off the top...now if i took it easy it would stay filled.. i was thinking of getting the big cat uat for this build ..seems thats the best for the bigger engines...what do you think...? pat
Hide Signatures
(in reply to dubd)
       Post #: 24
RE: Which UAT for P200sx - 1/1/2013 3:44 PM
wojtek
Score: 110
Status: offline
http://www.modelaviationproducts.com/products/accessories.html
I have used these with good success on large engines. I have one a a p200 in a mb339
~V~
Nothing can ever be fast (or scale ;) ) enough !!!
www.all-scale.com
Hide Signatures
(in reply to ricardinho)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
