JR 11X2.4 Version 2 Update    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> JR Radio & Spektrum Radios >> JR 11X2.4 Version 2 Update
Page: [1]
Login
JR 11X2.4 Version 2 Update - 12/30/2012 5:44 PM
AWorrest
Score: 115
Last Login: 5/22/2013
Status: offline
On Horizon’s web site, http://www.horizonhobby.com/pdf/JRP1100_SDCard_Firmware_Addendum-10-06-10.pdf there is a link to the version 0002-0100 update of the 11X2.4. It brings the firmware nearly up to the XG11 level. Make sure your transmitter battery is charged and you have copied your models to the SD card before updating. The update will wipe out the models in the normal memory and inhibit some of the functions of those written on the SD. This is likely necessary as there are some definite differences between version 1 and 2 firmware.
I’ve done the update on my transmitter and it is worth it.
Allan
Hide Signatures
       Post #: 1
RE: JR 11X2.4 Version 2 Update - 1/4/2013 5:32 PM
AWorrest
Score: 115
Status: offline
The link I originally posted has been discontinued. The surest way to find the current link is to log onto Horizon web site, Search for the 11X 2.4 transmitter and open the Manuals & Support tab.
Allan
Hide Signatures
(in reply to AWorrest)
       Post #: 2
RE: JR 11X2.4 Version 2 Update - 1/4/2013 5:44 PM
BarracudaHockey
Score: 280
Status: online
http://www.horizonhobby.com/pdf/JR_1...are_Update.pdf
LOL good grief, they changed it again!
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 3
RE: JR 11X2.4 Version 2 Update - 5/9/2013 1:22 AM
Boom Operator
Score: 100
Last Login: 5/20/2013
Status: offline
Can any one help? I need to know has anyone done the XG11 download to the 11X 2.4? They recommend it on the Horizon web site so it will make the JR 11X more like the XG11 and a much better radio. If anyone has done this, has affected in any negative way and would you recommend it or leave the JR 11X alone?
I flew for 17 years and I touched the face of God. I do that now with RC aircraft!
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 4
RE: JR 11X2.4 Version 2 Update - 5/9/2013 9:19 AM
AWorrest
Score: 115
Status: offline
Boom,
LOL, did you read the first post with which I started this thread? Yes, I’ve done it and glad that I did! If you are 100% happy with version one, you should study the XG11 manual and see if there is anything new that interest you. Some of the menus were expanded. If you aren’t going to use any of the new features, you will have to wade through extra pages. For example, the D/R&EXPO menu is now four pages. The only updated version one function that will give you more trouble is the Stick Position Switch. It is not as intuitive as before but a lot more flexible and usable.
Some very good pilots have little interest in transmitter programming. For them, version one has more than enough features to keep them happy. However, if version one's limitations chafe you , then you should go for version two.
Allan
< Message edited by AWorrest -- 5/9/2013 10:14 AM >
Hide Signatures
(in reply to Boom Operator)
       Post #: 5
RE: JR 11X2.4 Version 2 Update - 5/10/2013 10:33 PM
Boom Operator
Score: 100
Status: offline
Thanks Allan and no I don't bother reading prior threads. (JOKE) I am just concerened that if I wanted an XG11 and not an 11X 2.4 I would have bought one. I understand with this update you have an XG11 with DSM2 and DSMX protocols. I will turn my 11X Zero into DMSS with JRs' telemetry someday.
Hide Signatures
       Post #: 6
RE: JR 11X2.4 Version 2 Update - 5/11/2013 4:32 AM
AWorrest
Score: 115
Status: offline
I haven’t run across anything you can do with version one that you can’t do with version two. One of the better features of version two is the expanded timer switch option. It doesn’t appear in the XG11 manual as it was an XG11 upgrade after the manual was published. For the start and stop timer switches, instead of the limited choice in version one, there are now the same options you would have for the select switches in any other mix.
Version one had the rudimentary beginnings of the TRIM IN flight feature. To use it, you had to be on the ground to turn this feature on and off. The version one manual failed to explain what this feature was and how to use it. With version two, the feature can be turned on and off while in the air. Also, version two has TRIM IN in the ACRO’s FLAP SYSTEM, DIFFERENTIAL and GYRO SEN menus. I can’t recall if version one had this feature in any menu other than FLAP SYSTEM.
Version two also gives you more rates, flight modes, and switch position switches.
Allan
Hide Signatures
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.281RCU1
