O.S. 55AX Vs 65AX    Gallery
Logged in as Guest
    Search This Thread
Printable Version
TurboHeader Muffler
Seller:  RC Specialties
Details:   $69.95   |  4/28/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> O.S. 55AX Vs 65AX
Page: [1]
Login
O.S. 55AX Vs 65AX - 12/30/2012 6:58 PM
markhamregular
Score: 111
Last Login: 5/18/2013
Status: offline
I would like to know if there is a diference in power between the 55 and the 65. As per the specs below, it seems the only difference is an additional weight of 3.3 ounces.
Specs for the 55AX: 1.68 HP/16,000 RPM Weight: 18.52oz w/ muffler
Specs for 65AX: 1.73 HP @ 16,000 RPM Weight: 21.8oz w/ muffler
Harry
_____________________________
What''s rudder?
Hide Signatures
       Post #: 1
RE: O.S. 55AX Vs 65AX - 12/30/2012 7:38 PM
jeffk464
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: markhamregular
Harry
what plane are you putting it in? 55AX is already pretty strong for some of the smaller 40 sized planes.
Hide Signatures
(in reply to markhamregular)
       Post #: 2
RE: O.S. 55AX Vs 65AX - 12/30/2012 7:59 PM
markhamregular
Score: 111
Status: offline
I just got myself a Sundowner 50. I know the 75 is heavy, even heavier than a 95AX.
But many told me the 95 is too heavy and the HP Sundowner 50 is very light and will do better with a smaller engine.
So I have reduced my list to a 55 or 65.
What''s rudder?
Hide Signatures
(in reply to jeffk464)
       Post #: 3
RE: O.S. 55AX Vs 65AX - 12/30/2012 8:01 PM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
You cant really use manufacturers horsepower specs, they are completely out to lunch. Usually they are arrived at with a tiny little prop at an ungodly rpm which you could never use. Best to use posted rpm specs in the tach readings section, even then some of our members might post numbers that are a little "fishy?"
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
       Post #: 4
RE: O.S. 55AX Vs 65AX - 12/30/2012 8:30 PM
markhamregular
Score: 111
Status: offline
Have you used both engines? Do you know if there is any substantial difference?
What''s rudder?
Hide Signatures
(in reply to jeffie8696)
       Post #: 5
RE: O.S. 55AX Vs 65AX - 12/30/2012 11:51 PM
jeffk464
Score: 100
Status: offline
Haven't heard much on the 65ax from the speed guys. The faster the more fun for the sundowner, if it turns out that you get more speed with it I would probably go with it.
Hide Signatures
       Post #: 6
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> O.S. 55AX Vs 65AX
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.250RCU1
