gettin 24mm hex hubs    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Slash 4x4 roller with TQ 2.4GHz Traxxas Link - Kit
Seller:  Callifas38
Details:   $150.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> gettin 24mm hex hubs
Page: [1]
Login
gettin 24mm hex hubs - 12/31/2012 1:35 AM
Watsy
Score: 100
Last Login: 5/7/2013
Status: offline
hey guys im thinkin of gettin 24mm hex hubs. is there any reason why i should stay away from doing this. what parts would u recommend upgrading to cope with the extra load?? what wheels n tires would u suggest?? i really dont like the stocks on the savvy xl. i also have a losi 454 engine in the xl. im either gettin the ofna 086 or jp-2. any suggestion on which one to pick??
watsy
_____________________________
HPI SAVAGE XL W/454, LOSI LST XXL W/454, HOLDEN CALAIS GEN3 LS1 5.7L
Hide Signatures
       Post #: 1
RE: gettin 24mm hex hubs - 12/31/2012 2:42 PM
Borneoben
Score: 100
Last Login: 3/10/2013
Status: offline
I have the HPI 24mm adapters and they are nice quality
I have them on my XL and i run the Proline Desparado 1/5 rear buggy wheels all around  with the Bow Tie tires
Everything else is bone stock and works great.
The wheels and tires are significantly heavier than stock though.
So far nothing has broken!!
Cheers
Ben
Scratch Built Depron Biplane, Park Zone Extra 300, BlueSkyRC FPV Spider Quad with Naza+GPS
Savage XL
Hide Signatures
(in reply to Watsy)
       Post #: 2
RE: gettin 24mm hex hubs - 12/31/2012 10:49 PM
Watsy
Score: 100
Status: offline
hi Ben, thanks for that. i'll chech the wheel out. how many tanks have u been through since having the bigger wheels on?
watsy
  • _____________________________
    Hide Signatures
    (in reply to Borneoben)
  •        Post #: 3
    RE: gettin 24mm hex hubs - 1/1/2013 11:12 AM
    Borneoben
    Score: 100
    Status: offline
    I have about 3 or 4 tanks on the wheels so far
    Savage XL
    Hide Signatures
    (in reply to Watsy)
           Post #: 4
    RE: gettin 24mm hex hubs - 1/1/2013 11:43 AM
    Watsy
    Score: 100
    Status: offline
    well i checked out the wheels n tires. ill be ordering them very soon along with all the other parts. lol.
    thanks for the suggestion, Ben.
    now which pipe to go for. 086 or jp-2.
    graham
    Hide Signatures
           Post #: 5
    RE: gettin 24mm hex hubs - 1/1/2013 2:00 PM
    Borneoben
    Score: 100
    Status: offline
    I am also looking into new exhaust for my K5.9 motor
    Other suggestions are the Cen Racing Genesis Pipe
    The ultimate pipe seems to be teh ERCM Endbleed pipes
    but they are a bit pricey
    Cheers
    Ben
    Savage XL
    Hide Signatures
    (in reply to Watsy)
           Post #: 6
    RE: gettin 24mm hex hubs - 1/1/2013 4:07 PM
    Watsy
    Score: 100
    Status: offline
    yea i have seen the endbleed pipes. im afraid i dont need nothin like that. think im leaning towards the jp-2.
    Hide Signatures
           Post #: 7
    RE: gettin 24mm hex hubs - 1/1/2013 6:35 PM
    Borneoben
    Score: 100
    Status: offline
    do you have a link for the JP2?
    what motor will you put it on?
    Savage XL
    Hide Signatures
    (in reply to Watsy)
           Post #: 8
    RE: gettin 24mm hex hubs - 1/1/2013 11:06 PM
    Watsy
    Score: 100
    Status: offline
    im puttin it on a losi 454. its virtually a lrp .28 spec3. u can have a look on ebay for either a losi 454 or the lrp they are cheap. i wish i got the lrp because i replaced the carb on the 454 with the spec 3 carby anyways. on ebay they both are around 150 mark. but def go the lrp z.28 spec 3. when i first put the 454 in the xl i was amazed on the difference in power. also with the pipes check out ebay. to get that stuff here in aus from my lhs is way to expensive. ebay is the way to go for me. it depends if it works for u.
    graham
    Hide Signatures
           Post #: 9
    RE: gettin 24mm hex hubs - 1/2/2013 3:28 AM
    Watsy
    Score: 100
    Status: offline
    hi Ben, can u post a pic of ur MT with the new wheels n tires.
    cheers
    Hide Signatures
    (in reply to Watsy)
           Post #: 10
    RE: gettin 24mm hex hubs - 1/2/2013 8:42 AM
    Borneoben
    Score: 100
    Status: offline
    Yep no problem i will post some pictures tonight when i get home
    You mentioned above...
    "when i first put the 454 in the xl i was amazed on the difference in power"
    Was it the stock K5.9 that you replaced with teh .28 454 that gave you the big improvement in power?
    Cheers
    Ben
    Savage XL
    Hide Signatures
    (in reply to Watsy)
           Post #: 11
    RE: gettin 24mm hex hubs - 1/2/2013 10:00 AM
    Watsy
    Score: 100
    Status: offline
    hi Ben, yes thats correct. the power difference was amazing. good power across the whole rev range. heaps of torque down low. and with a new pipe to go with the engine it will come alive even more. the 454 is just starting to loosen up so i would think its still yet to show even more power. the k5.9 was ok tho. but until you slap a 454 or lrp z.28 in ur truck u wont understand.. but if u do get either of these engines definatly pick the lrp z.28 spec3. ppl might chime in as to get a high priced engine but if ur not racing or anything like that the lrp is the best bang for buck.
    watsy
    Hide Signatures
           Post #: 12
    RE: gettin 24mm hex hubs - 1/2/2013 10:19 AM
    Borneoben
    Score: 100
    Status: offline
    Thanks for that
    Thats really interesting.
    I would have thought the extra displacement of the K5.9 over the .28 would have given it more power all through the range.
    When i need to replace the K5.9 then an LRP .28 Spec3 sounds just the ticket.
    Cheers
    Will post pics of my wheels when i get home
    Ben
    Savage XL
    Hide Signatures
    (in reply to Watsy)
           Post #: 13
    RE: gettin 24mm hex hubs - 1/2/2013 10:41 AM
    Watsy
    Score: 100
    Status: offline
    yea no worries mate. but with ur 5.9 if u have not already, make sure u seal the engine back plate and carby. i liked the 5.9. as i said, if ur not racing it doesnt matter. its good for just us bashers..hopefully b orderin the hex hubs wheels n tires in the next day or two. lookin forward to checkin out ur pics.. any chance of a pic with them on the xl?? think i have about 400 to spend and i SHOULD be done n happy. lol
    Hide Signatures
           Post #: 14
    RE: gettin 24mm hex hubs - 1/2/2013 10:45 AM
    Borneoben
    Score: 100
    Status: offline
    Yes the wheels and tires are mounted on the Truck at the moment.
    I did it mainly for looks as i don't like the original wheel tire combo.
    They are significantly heavier as well though, i will take one off and weigh it to compare against the original when i get home mate.
    Cheers
    Ben
    Savage XL
    Hide Signatures
    (in reply to Watsy)
           Post #: 15
    RE: gettin 24mm hex hubs - 1/2/2013 11:00 AM
    Watsy
    Score: 100
    Status: offline
    that would b good, mate. it will be interesting to c what the difference is. my main concern is the extra load on the drive train are the tires much wider than the stock or are the just taller?? how do i think they compare the the orignals?? handeling, traction ect??
    Hide Signatures
           Post #: 16
    RE: gettin 24mm hex hubs - 1/2/2013 11:17 AM
    Borneoben
    Score: 100
    Status: offline
    The 1/5 Wheels an tires over all dimensions are almost exactly the same as the originals.
    The tires are much harder and they have a much more shallow side wall so they don't compress like the originals do. So if your into big jumps and stuff then the original will absorb much more of that impact.
    I have only run the originals once or twice so i cant really compare traction. I run on soft sand and  hard packed sand with allot of rocks / gravel in it so the deeper tread of the Proline Bow Tie tires maybe be better for me?? i dont really know.
    I think the extra load on the drive train and suspension will come from the extra weight.
    One thing to consider is that the outside bead locks on the Proline Desparado wheels are exposed and take a beating.
    They are pretty dinged up already. So far i cant see where i can buy spares but i think the STD HPI 1/5 beadlocks fit the wheels if needed, they just dont look so nice, but they are available in different colours.
    Cheers
    Ben
    Savage XL
    Hide Signatures
    (in reply to Watsy)
           Post #: 17
    RE: gettin 24mm hex hubs - 1/2/2013 4:21 PM
    Borneoben
    Score: 100
    Status: offline
    OK here are the pics as promised!
    I think the XL looks way better with these wheels / tires on.
    Please ignore the decorations my daughter added for me!
    It could have been worse, it could have been Tinkerbell stickers!
    They are very close in size to the originals Bare in mind that the orinals look taller as there is no weight on them in this pic.
    BUT
    The new wheels are quite a bit heavier
    Thats 200 grams more EACH wheel.
    Dont forget the HPI 24mm wheel nut wrench, that caught me out as i didn't have any 24mm sockets either!
    Hope that helps mate!
    Ben
    Savage XL
    Hide Signatures
           Post #: 18
    RE: gettin 24mm hex hubs - 1/2/2013 11:08 PM
    Watsy
    Score: 100
    Status: offline
    thanks for sharing the pics, mate. lookin forward to gettin mine. i was lookin on ebay and i noticed u can buy replacement beadlocks. i dont no how to post the link via my phone.
    Hide Signatures
           Post #: 19
    RE: gettin 24mm hex hubs - 1/6/2013 12:43 PM
    Watsy
    Score: 100
    Status: offline
    well i ordered the 24mm hex hubs along with proline badlands and the dynamite 086 pipe goin to order proline desporado wheels and proline desert rat clear lid next week.
    Hide Signatures
    (in reply to Watsy)
           Post #: 20
    RE: gettin 24mm hex hubs - 1/6/2013 3:16 PM
    Borneoben
    Score: 100
    Status: offline
    Awesome
    Dont forget to post some pics when you have it all installed!
    Savage XL
    Hide Signatures
    (in reply to Watsy)
           Post #: 21
    RE: gettin 24mm hex hubs - 1/6/2013 10:55 PM
    Watsy
    Score: 100
    Status: offline
    yea no probs. wont be for a while tho. psrts are coming from the states. i cant wait to get it all here.
    watsy
    Hide Signatures
           Post #: 22
    Page:   [1]
    Page: [1]
    Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.718RCU1
