O.S. 70 surpass looses rpms at full throttle.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Garage Sequestration Liquidation
Seller:  Mr DJ
Details:   $999,999.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> O.S. 70 surpass looses rpms at full throttle.
Page: [1]
Login
O.S. 70 surpass looses rpms at full throttle. - 12/31/2012 3:46 AM
harlanb
Score: 105
Last Login: 5/23/2013
Status: offline
Hi all.
I have a O.S. 70 surpass 4 stroke that I bought on ebay (probably not the best place to buy a reliable engine).
The engine seems to run and idle well. However, the engine rpm will peek at about 90% throttle.
When I push the throttle the extra 10% to full throttle, the engine rpms are reduced by 300 to 400 rpm.
I am using a new glow plug, and have adjusted the valves twice. i have also tuned the low and high speed settings as best as I can.
Can any one help me understand why I am loosing rpms at full throttle?
Hide Signatures
       Post #: 1
RE: O.S. 70 surpass looses rpms at full throttle. - 12/31/2012 5:06 AM
alan0899
Score: 100
Last Login: 5/12/2013
Status: offline
G'day Mate,
It's probably lean, richen 1/4 turn, if it's on a plane, lift the nose vertically, & make sure the RPM's don't drop.
Then fly it, if it looses RPM in the air, throttle back & land & richen some more, until it runs without loosing RPM's.
Cheers
_____________________________
Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee,
Allan.
Hide Signatures
(in reply to harlanb)
       Post #: 2
RE: O.S. 70 surpass looses rpms at full throttle. - 12/31/2012 5:39 AM
harlanb
Score: 105
Status: offline
alan0899
thanks for the tip. I have tried to richen and lean the fuel mixture. the engine acts the same regardless if it is running lean or rich.
Hide Signatures
(in reply to alan0899)
       Post #: 3
RE: O.S. 70 surpass looses rpms at full throttle. - 12/31/2012 12:26 PM
rosnik
Score: 100
Status: offline
IMO:
To make 'like new' one OS 4 stroke is quite easy.
-Buy the 2 main bal bearing and replace them .
-Buy one piston ring and replace it .
-clean all the engine before remount it, and not lose to clean the valve conduct and valve polishing .
You'll find again all the lose power .
I ALWAYS THINK POSITIVE
BUT I FLY NEGATIVE.
Hide Signatures
       Post #: 4
RE: O.S. 70 surpass looses rpms at full throttle. - 12/31/2012 1:03 PM
ronwc
Score: 100
Status: offline
I've notice it too, probably valve float so I don't push it.
Ron - AMA 1025 - Largo, FL
Hide Signatures
       Post #: 5
RE: O.S. 70 surpass looses rpms at full throttle. - 12/31/2012 1:58 PM  1 votes
Hobbsy
Score: 650
Last Login: 5/24/2013
Status: offline
My guess is that the LowSpeed needle is too lean, that renders the HighSpeed needle ineffective above a certain point. Richen the LS needle about one half turn then try to peak the HS needle.
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
       Post #: 6
RE: O.S. 70 surpass looses rpms at full throttle. - 12/31/2012 2:36 PM
w8ye
Score: 318
Status: offline
quote:
ORIGINAL: Hobbsy
Bingo!
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to Hobbsy)
       Post #: 7
RE: O.S. 70 surpass looses rpms at full throttle. - 12/31/2012 9:37 PM
harlanb
Score: 105
Status: offline
Thanks for the tip rosnik,
I am not sure what you mean by this statement, can you clarify?
"-clean all the engine before remount it, and not lose to clean the valve conduct and valve polishing ."
thanks
Hide Signatures
(in reply to rosnik)
       Post #: 8
RE: O.S. 70 surpass looses rpms at full throttle. - 12/31/2012 9:39 PM
harlanb
Score: 105
Status: offline
Thanks for the tip Hobbsy,
I did adjust the low speed idle for the best idle speed, but I will try to richen the idle screw and see if that helps.
Hide Signatures
       Post #: 9
RE: O.S. 70 surpass looses rpms at full throttle. - 12/31/2012 10:15 PM  1 votes
Hobbsy
Score: 650
Status: offline
Always be willing to sacrifice a few idle rpm in favor of the best transition. Take car, Dave
Hide Signatures
       Post #: 10
RE: O.S. 70 surpass looses rpms at full throttle. - 1/1/2013 12:22 AM  1 votes
blw
Score: 655
Status: offline
The low speed needle is for engine running like the high speed needle. The low speed is more important to engine performance than the high speed needle, imo. Too rich causes problems all over the place, and too lean causes backfires. Tune where you get the best transition *just* rich enough where it doesn't wheeze or backfire as you advance the throttle.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 11
RE: O.S. 70 surpass looses rpms at full throttle. - 1/1/2013 12:44 AM
harlanb
Score: 105
Status: offline
Hobbsy
I bow to your supreme knowledge.
I did exactly as you said and the engine ran great. No rpm drop off at full throttle.
I am starting to figure out that for each low speed setting, there is high speed setting that works the best for the low speed setting.
If your low speed setting is not correct, you can still adjust the high speed setting to get a seemingly optimum setting evan if the low speed setting is off.
You have to go back and forth to get the right combination.
Thank you again for the info. I hope to be knowlegable enough to help people on these forums.
Thanks again.
Hide Signatures
(in reply to blw)
       Post #: 12
RE: O.S. 70 surpass looses rpms at full throttle. - 1/1/2013 12:46 AM
harlanb
Score: 105
Status: offline
Thanks for the info btw. I am starting to figure this out.
Hide Signatures
(in reply to blw)
       Post #: 13
RE: O.S. 70 surpass looses rpms at full throttle. - 1/1/2013 3:54 AM
blw
Score: 655
Status: offline
An incorrect low speed will screw up attempts to set the high speed. Hobbsy always advises to peak the high speed, leave it there, and set the low speed correctly. Go back and set the high speed a few hundred rich. This really is the best method to tune a 4 stroke,
Coach Pat Dye
Hide Signatures
       Post #: 14
RE: O.S. 70 surpass looses rpms at full throttle. - 1/1/2013 2:16 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: blw
I follow his tuning method on my Enya 4-stroke as well. I use a tach as I don't quite have the 'ear' for setting the needle on a 4-stroke just yet.. Still new at the 4C scene.
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to blw)
       Post #: 15
RE: O.S. 70 surpass looses rpms at full throttle. - 1/1/2013 2:52 PM  1 votes
Hobbsy
Score: 650
Status: offline
1Q, my very first RC engine was an Enya .46 MKII which I still have. I know that many on here advise to not get a fourstroke first. The only mistake I made, (according to some), was using Fox fuel with 20% castor for its first two seasons. This did not have the devastating effect that some think. It only got a brown muffler. I used the same fuel in a Saito .80 and 1.50, no ill came to them either.
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 16
RE: O.S. 70 surpass looses rpms at full throttle. - 1/1/2013 5:05 PM  1 votes
blw
Score: 655
Status: offline
I like gadgets and have a newer TNC tach. I use it most of the time out of curiosity for the numbers. You can tell more by listening though.
Coach Pat Dye
Hide Signatures
       Post #: 17
RE: O.S. 70 surpass looses rpms at full throttle. - 1/1/2013 5:36 PM
1QwkSport2.5r
Score: 155
Status: offline
quote:
ORIGINAL: Hobbsy
I've been in RC for over 15 years, but most of that is with cars only. I wanted to have a 4C just to have one and it so happened I fount the Enya. The instructions say to use castor oil or a high quality synthetic, and being of the "old school" belief, I use all castor in my aero engines. I save the synthetic oil for the car engines that rev to 40k, the thick castor hold the rpm back some.
With my Enya 60-4C, I find if I start rich and lean it until it runs smooth, it's still 1000rpm rich of peak. By smooth I mean clean four stroke, no missing or popping. The 600-700rpm I gain using the tach doesn't sound much different to me. Again, this is my first season with a 4-cycle, and being an old Enya, it's got it's own learning curve. I still find it comical seeing castor "goo" spraying from the exhaust at fast rpm. I don't know why.
Hide Signatures
       Post #: 18
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> O.S. 70 surpass looses rpms at full throttle.
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
