replacing old nicads, but what with?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> replacing old nicads, but what with?
Page: [1]
Login
replacing old nicads, but what with? - 12/31/2012 10:34 AM
Keith 65
Score: 100
Last Login: 3/1/2013
Status: offline
hi. i need to replace the old nicads in my reciever packs in my planes after a number of yeares lay up.
i see the batteries have changed some since i last bought any,and nicads seem to be very much out of fashon these days plus more expensive
 can some tell me the best replacements i can use to replace 4.8 1100 mah, plus the  tx pack
My charging equipment is mainly set up for nicads obviously but i have a pro peak fast charger that will charge most batteries of 7 years ago ie nicad , nmh, etc.
wondered if there was a simple replacement that i can use that will still allow the use of these chargers.
the radio im running is still an ols 35meg futaba FF6 .
regards keith
Hide Signatures
       Post #: 1
RE: replacing old nicads, but what with? - 12/31/2012 12:18 PM
Rodney
Score: 174
Last Login: 5/23/2013
Status: offline
Check out the Eneloops (the newer version using the Nickle Metal Hydride with very low self discharge) made by Sanyo. They make excellent transmitter batteries (all the advantage of LiPo's with none of the disadvantages). Depending on peak current requirements of your receiver set up, they can also be used for the airborne part. These let you use your present NiCad charger with no modifications. You may want to also check out LiFe and/or LiPo for some applications but realize that you must also then procure new chargers as the charging regime is much more complicated and, if not proper, can result in damaged batteries or even a fire when using LiPo's.
Hide Signatures
(in reply to Keith 65)
       Post #: 2
RE: replacing old nicads, but what with? - 12/31/2012 1:38 PM
Keith 65
Score: 100
Status: offline
are  eneloops similar to Nimh batteries as i know these can be charged similar to nicads
All of my onboard batteries are 4.8v as im still on the old 35 meg recievers i have to be reasonably carefull on there output voltages, think the average servo max's out at 6 volts
http://www.sussex-model-centre.co.uk/shopexd.asp?id=36286
http://www.overlander.co.uk/batteries-chargers/eneloop-batteries/sanyo-xx-eneloop-2500-aa-4-8v-rx-flat.html
Looking at our local model shop supplies these look very similar if not the same as overlanders enloop batteries
Hide Signatures
(in reply to Rodney)
       Post #: 3
RE: replacing old nicads, but what with? - 12/31/2012 3:16 PM
Goldenduff
Score: 114
Last Login: 5/24/2013
Status: offline
I believe eneloops are nimh but better...
NBS batteries has a lot of good info on batteries. They say not to use as receiver as mentioned current draw tends to exceed their discharge ability.
_____________________________
Hello, the IMAX b6 quattro fits the bill?
Hide Signatures
       Post #: 4
RE: replacing old nicads, but what with? - 12/31/2012 3:44 PM
Keith 65
Score: 100
Status: offline
quote:
ORIGINAL: Goldenduff
i cant seem to find NBS batteries have you a link by chance?
Hide Signatures
(in reply to Goldenduff)
       Post #: 5
RE: replacing old nicads, but what with? - 12/31/2012 6:23 PM
vicman
Score: 189
Status: offline
They might push your max V a bit but I have made the change to Life for my stuff that needs upgrade. So far I'm happy with them.
ps. no voltage reg, my Rx is fine with 6.5v
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
       Post #: 6
RE: replacing old nicads, but what with? - 12/31/2012 9:20 PM
Rodney
Score: 174
Status: offline
In all cases I can think of, NiMh and NiCad batteries are direct replacements for each other as the voltage per cell is essentially identical. If your servos can live with x number of NiCad cells, they can live as well with x numbers of the NiMh cells.
Hide Signatures
(in reply to vicman)
       Post #: 7
RE: replacing old nicads, but what with? - 12/31/2012 11:30 PM
aghost
Score: 100
Status: offline
keith: NOBS battery site. I have been happy with my battery purchases here.
http://www.hangtimes.com/index.html
Brian
Hide Signatures
       Post #: 8
RE: replacing old nicads, but what with? - 1/1/2013 12:24 AM
4*60
Score: 111
Status: offline
Buy a $30 charger and $5 life packs from Hobbyking and come into the modern world.
"Of course, that''''s just my opinion. I could be wrong." the other Dennis Miller
Hide Signatures
(in reply to aghost)
       Post #: 9
RE: replacing old nicads, but what with? - 1/1/2013 1:08 AM
JPMacG
Score: 123
Status: offline
NiCd packs are still available. A rx pack is about $12, a Tx pack is about $24. The 700 mAh Sanyo NiCd cells are bulletproof and will last many years. NiMH and LiFe are excellent alternatives. They give you more capacity, which may or may not be something you care about. Both are arguably less robust than the old tried and true NiCd technology.
Hide Signatures
(in reply to 4*60)
       Post #: 10
RE: replacing old nicads, but what with? - 1/1/2013 3:07 AM
Checklst
Score: 115
Status: offline
There is a lot to consider but the NOBS site and Reds site will keep the BS down for sure. With me it is about how I fly and what planes I fly......my style and planes are not all that weight sensitive...............My new 88" Yak is on 2 1900ma Nicad with a third 1600man Nicad 6volt all feeding the receiver..........the ignition is on an IBEC. The plane still weights only 17LB 2oz. and these cads have low impedance........ running triples cads on heavy wire with short runs and good switches.
I went old school on this Yak due to its heavy tail.......I would have used NoBS twin 123 packs set up buy I would have to add 3/4 lb lead up on the fire wall(did I mention I hate bolting lead to a plane).
No matter what battery you choose buy good Batterys, charger/cyclers,......form the batts right on the first charge, run a discharge graph chart on them new and compare this to your graph you run............at the start of every season................store you batts during the off season right, and no matter what check them with a loaded meter before each and every flight!!!!!!!!!!!!! I have never had lost plane to a battery failer in 30 years....I have always used duel batts/switches and a loaded meter.
I can due enough damage with my stupid thumbs......Battery,and mechanical failer is easy to find and fix before it causes you a headache....if one takes the time.
JMO
Hide Signatures
(in reply to JPMacG)
       Post #: 11
RE: replacing old nicads, but what with? - 1/1/2013 1:13 PM
Keith 65
Score: 100
Status: offline
having looked up the voltage limits of the servo's i have fitted it looks like i am limited to 4.8 . but it does look like any future build i do i will go for a more up to date power supply and buy the servo's acordingly, but for the time being think i will stick with some new nicad packs for the old stuff.
thanks for the links you guys have supplied, will give me plenty to read up on.
keith
Hide Signatures
(in reply to Checklst)
       Post #: 12
RE: replacing old nicads, but what with? - 1/1/2013 4:54 PM
JPMacG
Score: 123
Status: offline
Sanyo cells are by most accounts the best NiCds. The 600 mAh and 700 mAh AA size Sanyos will last many years. The 1100 mAh AA sized Sanyos seem to go bad after only 2 or 3 years. Rx and Tx packs made from Sanyos are available from lots of RC suppliers.... NoBS, Tower Hobbies, RadicalRC, etc, etc.
As mentioned above, Red's information is excellent.
Hide Signatures
       Post #: 13
RE: replacing old nicads, but what with? - 1/1/2013 7:57 PM
Four Stroker
Score: 104
Last Login: 3/28/2013
Status: offline
As Red himself said, NiCD cells are dead after 7 years if you have used them or not. Many famous RC suppliers get surplus cells that are crap precisely because they are near or over 7 years old. I have replaced ancient TX packs with Eneloops and RX packs with A123. NoBS has relatively fresh cells and that is why they have a small selection compared to others. Get a big linear regulator like the Fromeco Sahara if you have old 5 volt servos.
Hide Signatures
       Post #: 14
RE: replacing old nicads, but what with? - 1/1/2013 9:46 PM
Rodney
Score: 174
Status: offline
In some 40+ years in RC, I have found that NiCads are superior to NiMh in all respects except capacity versus mass. They are more rugged, take abuse better, will last years if properly maintained (I have some that have served well over 10 years), have lower internal impedance etc. They have two disadvantages over NiMh; larger (more mass) for equivalent capacity and must be properly disposed of when you are done with them (hazardous waste).
Hide Signatures
(in reply to Four Stroker)
       Post #: 15
RE: replacing old nicads, but what with? - 1/3/2013 4:40 PM
Cougar-RCU
Score: 100
Last Login: 4/6/2013
Status: offline
Just did the same thing. replace all my stuff with the LiFe battery's LOVE THEM !!
All my stuff is now 6 volts. they seem to last a long time in flight. way better
then my Ni-Cd's ever did. Good luck on what you decide.
Jeff
** CUB BROTHERHOOD ** #90
Hide Signatures
       Post #: 16
RE: replacing old nicads, but what with? - 1/3/2013 5:44 PM
P-40 DRIVER
Score: 105
Last Login: 2/14/2013
Status: offline
No BS batteries has enough info to answer all your questions, I have flown Nicads and LiFe batteries, both work and both have their advantages and disadvantages. It comes down to personal choice in the end. I really have no love for NiMh batteries though.
Hide Signatures
(in reply to Cougar-RCU)
       Post #: 17
RE: replacing old nicads, but what with? - 1/3/2013 5:56 PM
JollyPopper
Score: 158
Status: offline
A lot of us traded our model 12 Winchester shotguns off when the newer swoopier models came out. And how much every one of us wishes we had the model 12s back. Just because the technology is older doesn't necessarily mean it isn't good. Nicads have a lot going for them still.
"In theory, there is no difference between theory and practice; In practice, there is"
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.703RCU1
