RE: NEW PRODUCT IDEAS FOR 2013?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: NEW PRODUCT IDEAS FOR 2013?
Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 12:40 AM
rorywquin
Score: 100
Last Login: 5/23/2013
Status: offline
http://intairco.net/
Also have a few nice jet fittings but postage to the UK / USA etc may make them too expensive. .
Hide Signatures
(in reply to marc s)
       Post #: 51
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 1:11 AM
David Searles
Score: 115
Status: offline
How about a "Tips & Tricks" book compilation of your scale and custom build techniques with lots of pics and explanations of how you go about creating some of the master pieces I've seen you constructing over the years. I'd buy it for sure!
David S
Hide Signatures
(in reply to rorywquin)
       Post #: 52
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 2:39 AM
FalconWings
Score: 121
Status: offline
1. External AC generator that can be connect to the engine shaft fitted with an inverter/regulator to power up the RC system. Batteries would only be used for startup and backup. (Remember Genesys by Sullivan? Only required an engine spinning at 8000 RPM).
2. A fitting adapter at the compressor stage of the turbine connected to a pressure relief mechanical valve to provide constant air pressure to the air system. Even if you have a leak, your air system would still work.
3. A reasonable cost smokewinder system. Think a kero start type hot plug inside an AIM 120 body, big enough to generate the needed heat inside a hot chamber, with two lines fed in and routed inside the wing: one feeds fuel through a 4mm line to keep plug hot, the other is a 3mm that feeds in smoke fluid.
Not sure you can get it done this year, but it could keep you busy.
David
_____________________________
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
(in reply to David Searles)
       Post #: 53
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 8:22 AM
extra 300
Score: 100
Status: offline
Marc,
Any chance to see the spring loaded hinges idea materialize somehow? or maybe you have reasons to believe that it would not operate properly?
Regards,
Dany
Hide Signatures
(in reply to FalconWings)
       Post #: 54
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 8:51 AM
marc s
Score: 110
Status: online
David I am flattered, not sure my techniques are really that ground breaking! - a book from you would be more beneficial to the RC community.
Falconwings the B300F has an internal converter but appreciate its not the ideal size turbine for everyone....
Not a sidewinder but I am working with a colleague to develop a really intense smoke fluid that hopefully will deliver thick dense smoke at 40% less volume than current fluids - less smoke fluid more smoke for longer
Dany its on the list for consideration, only issue with small items like this you need to make 1000's to really see a benefit and not sure there is that sort of demand - love to be proved wrong though.
Keep the ideas coming
marcs
Hide Signatures
(in reply to extra 300)
       Post #: 55
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 9:22 AM
HarryC
Score: 100
Status: offline
quote:
ORIGINAL: FalconWings
A friend of mine who was an engineer on full-size jet engines actually did that to provide air for the wheel brakes but it never worked. The output from the compressor stage is well below the sort of psi our retracts and brakes typically work with.
Hide Signatures
       Post #: 56
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 9:26 AM
marc s
Score: 110
Status: online
I know some turbine manufacturers have a pressure outlet (AMT?) which has been used to add positive pressure to fuel systems but also with the advent of electric gear and brakes I feel air has a limited role in RC jets/planes.
marcs
Hide Signatures
(in reply to HarryC)
       Post #: 57
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 9:30 AM
extra 300
Score: 100
Status: offline
marcs
Marc,
Appreciate your feedback and fully understand your concern. If it makes a difference, i would be willing to get 80/100 pcs for my little fleet...
Hide Signatures
       Post #: 58
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 10:04 AM
FalconWings
Score: 121
Status: offline
quote:
ORIGINAL: HarryC
For brakes I could understand why. Under 70 psi you really don't do much. But if you can accumulate 30-35 psi during 6 minutes of flight time, it could be enough to lower the gear. Again, something lightweight as a backup.
Hide Signatures
       Post #: 59
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 10:08 AM
FalconWings
Score: 121
Status: offline
quote:
ORIGINAL: marc s
marcs
Hey that's not bad, similar concept. To make a good smokewinder a highly concentrated smoke oil would be ideal, specially if less heat is needed to make half a decent trail.
You are onto something great!
Hide Signatures
       Post #: 60
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 10:11 AM
Robrow
Score: 100
Status: offline
How about a small range of landing gear/trailing link struts (with compression rather than extension springs) to compliment the electric brakes/wheels for the many flyers on a budget these days?
Rob.
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
       Post #: 61
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 10:28 AM
Carsten Groen
Score: 100
Status: offline
quote:
ORIGINAL: marc s
David I am flattered, not sure my techniques are really that ground breaking! .
Thats the very first time I have seen you being wrong Marc
Does the "request for new product ideas" also include electronic stuff (or just purely mechanical) ?
Carsten Groen
Hide Signatures
       Post #: 62
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 10:52 AM
marc s
Score: 110
Status: online
Carsten so what do you want then......
Electronics is fine too as long as its not very complex.
marcs
Hide Signatures
(in reply to Carsten Groen)
       Post #: 63
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 3:25 PM
BaldEagel
Score: 118
Status: offline
Love the spring hinge idea, on any trike UC if not attached to the legs then each door would require at least two hinges, getting close to 10 hinges per airframe, most of us have at least two or three airframes that make about 30 for each of us plus some spares, would not take long to get the 1000 needed for manufacture.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 64
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 5:02 PM
marc s
Score: 110
Status: online
Mike, the numbers could creep up but here are a few questions - are people going to replace existing hinges (not sure they would) and would a spring device that could be added to a door to do the job be an interesting option?
marcs
Hide Signatures
(in reply to BaldEagel)
       Post #: 65
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 5:28 PM
Carsten Groen
Score: 100
Status: offline
quote:
ORIGINAL: marc s
marcs
I'll get back to you on that, have a couple of ideas (development is already done, just need someone to produce and sell it )
Carsten Groen
Hide Signatures
       Post #: 66
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 6:23 PM
marc s
Score: 110
Status: online
Look forward to the info
marcs
Hide Signatures
       Post #: 67
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 8:30 PM
extra 300
Score: 100
Status: offline
quote:
ORIGINAL: marc s
marcs
Absolute YES. The end result is what we would all be looking after!!
Regards,
Dany
Hide Signatures
       Post #: 68
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 8:45 PM
jetmodeller
Score: 100
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: Robrow
Rob.
Hi Rob check out spring air they do exactly what you are after regards Keith w
never did get those Rhino bits!!
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Robrow)
       Post #: 69
RE: NEW PRODUCT IDEAS FOR 2013? - 1/3/2013 11:24 PM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: marc s
marcs
Hmm a spring to add to an existing hinge would probably be even better, if only to help all those ailing rams and servo's out there.
Mike
EDIT: one suggestion how about a wrap around sleeve that allows us to position the air nipple where we want on retracts .
Mike
Hide Signatures
       Post #: 70
RE: NEW PRODUCT IDEAS FOR 2013? - 1/4/2013 7:46 AM
DominicM
Score: 101
Status: offline
Several systems for electric flight where remaining capacity can be seen on the ground so why not a telemetry based fuel level? or maybe onboard beacon indicating low level? With the fuel sloshing around in the tank would suspect you'd have to do it by analysing fuel flow rate into the engine to calculate what is left.
Hide Signatures
       Post #: 71
RE: NEW PRODUCT IDEAS FOR 2013? - 1/4/2013 10:40 AM
BaldEagel
Score: 118
Status: offline
Both already available, but the on board fuel system means cutting into your tank with the disadvantage's associated with making holes in a perfectly good tank, JetCat have a fuel flow/amount used on board, can't be too difficult to put a warning light or telemetry on this especially with the new wave of telemetry enabled Rx's available.
Mike
Hide Signatures
(in reply to DominicM)
       Post #: 72
RE: NEW PRODUCT IDEAS FOR 2013? - 1/4/2013 12:27 PM
marc s
Score: 110
Status: online
Here is an idea from a PM'd suggestion and wanted to see what you guys felt about it.
I always hate doing hinging and horns on any build (closely followed by the canopy!) so the suggestion was a neat simple and easy to use alignment jig to help builders make 100% sure horns are placed and glued exactly in the right place on the chosen control surface.
I envisage a fully adjustable jig which will adjusted and set for one surface and then used on the other to give 100% accuracy. It will keep horn(s) in place while they set at the correct angle and in the right place.
Any good?
marcs
Hide Signatures
       Post #: 73
RE: NEW PRODUCT IDEAS FOR 2013? - 1/4/2013 12:32 PM
Countryboy
Score: 114
Status: offline
quote:
ORIGINAL: BaldEagel
Mike
Assembled spring loaded hinges would be nice, but really not that hard to make your own. Hadn't really looked at it, but I'm sure the concept could be applied to offset hinges as well.
First pic is the hinge and the second pic shows it in application.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 74
RE: NEW PRODUCT IDEAS FOR 2013? - 1/4/2013 5:09 PM
Bob_B
Score: 100
Status: online
quote:
ORIGINAL: marc s
Any good?
marcs
That would be a welcome addition to my shop and while your at it how about a router and routing guide for the horns??
Cincinnati Jet Club, Team Futaba, Wren Turbines USA
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.578RCU1
