Tissue Vs. Monokote?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
98 inch Caribou - ARF
Seller:  AUSTARSMODEL
Details:   $820.00   |  4/15/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> Tissue Vs. Monokote?
Page: [1]
Login
Tissue Vs. Monokote? - 12/31/2012 4:22 PM
Bloodrobe
Score: 100
Last Login: 1/8/2013
Status: offline
 Okay showing my newbie side. I'm just finishing the build on my first balsa plane and been looking for my
next build. I see many planes with tissue covering. Can monokote be substituted for the tissue cover?
Hide Signatures
       Post #: 1
RE: Tissue Vs. Monokote? - 12/31/2012 5:25 PM
gene6029
Score: 120
Last Login: 5/20/2013
Status: online
It depends on the size of the model/airframe you have. Alot of the older control line models came with silkspan for covering & their wing structures were strong enough to be able to substitute Monokote in place of the silkspan. However, most of the rubber powered kits also came with silkspan & monokote potentially could crush or warp the structure during application. You didnt mention the type airframe you have, so just be aware that Monokote could produce the above mentioned results. I just finished applying Monokote to an old Mini Mambo kit and the monokote wanted to twist the wing during application. I got it done, but had my hands full keeping everything square. This was a kit that came with silkspan for covering.......Gene
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Bloodrobe)
       Post #: 2
RE: Tissue Vs. Monokote? - 1/1/2013 12:00 AM
Bloodrobe
Score: 100
Status: offline
Thanks Wilson, the plane I have been looking at are electric powered.
Hide Signatures
(in reply to gene6029)
       Post #: 3
RE: Tissue Vs. Monokote? - 1/1/2013 7:47 PM
jaka
Score: 158
Status: offline
Hi!
Choose Oracover instead of Monokote! Much better!
You should not use tissue for covering an R/C model. Covering will be too fragile! Tissue is only used on small, light free flight planes and CL planes when used in conjuction with silk and dope.
_____________________________
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 4
RE: Tissue Vs. Monokote? - 1/2/2013 12:11 AM
Bloodrobe
Score: 100
Status: offline
Great thanks never heard if orocover. What makes it better?
Hide Signatures
(in reply to jaka)
       Post #: 5
RE: Tissue Vs. Monokote? - 1/2/2013 1:47 AM
Top_Gunn
Score: 134
Status: offline
There are threads in which people argue at length about Monokote and Oracover (called Ultracote in the U.S.) Some people prefer one, others like the other one. Don't take any one person's word as gospel. As for tissue, if you are building a small, light model and the instructions call for tissue, either Monokote or Ultracote would likely be too heavy and too likely to damage the framework when shrinking. You wouldn't use tissue on a .40 size sport model, but you wouldn't use an ordinary film covering on a 1/2A Texaco model, either, at least not on the wings. Coverite makes a lightweight covering called "Coverlight" which is easier to apply than tissue and lighter than conventional films. Both tissue and silk take some skill to apply. What model are you building?
Al Gunn
Ultra Sport Brotherhood No. 9
Hide Signatures
       Post #: 6
RE: Tissue Vs. Monokote? - 1/2/2013 4:34 AM
Warbird40
Score: 105
Last Login: 5/14/2013
Status: offline
I am covering a Shoestring and after trying both Monocote and Ultracote, I prefer Ultracote. It shrinks way better than Monocote, its easier to work with due to the lower temp used, and feels tighter when done.
Ed
Hide Signatures
(in reply to Top_Gunn)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.438RCU1
