9505 Duel Ele    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> JR Radio & Spektrum Radios >> 9505 Duel Ele
Page: [1]
Login
9505 Duel Ele - 1/1/2013 3:02 AM
MX240
Score: 115
Last Login: 5/25/2013
Status: offline
How do I program two elevators servos?
I have tried the flaperon and normal wing types.
By mixing ele with Aux 2 or Aux 4 I can get it to work but....no trim on one elevator.
This plane also has flaps so I need them also.
Hide Signatures
       Post #: 1
RE: 9505 Duel Ele - 1/1/2013 3:09 AM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: MX240
I assume you mean the JR 9503? Like the 9303, the proper way to set up Dual Ailerons and Dual Elevators is to set the Wing Type to Normal and use the Mate parameter to specify the channel you wish to Mate with the Right Aileron and/or the Right Elevator. If you plan on using the Ailerons as Flaps, then you would choose a Wing Type of Flapperon.
_____________________________
Rich
byronf16@gmail.com
Hide Signatures
(in reply to MX240)
       Post #: 2
RE: 9505 Duel Ele - 1/1/2013 3:18 AM
Len Todd
Score: 100
Status: offline
I had the same problem with my DX8. There was a setting that activated the trim on the mixed control surface. On the DX8, that setting was in the mix settings. Not sure where you find it on a JR. The other option is to mechanically set both servo's linkages correctly and matched (i.e. where no trim is needed.). I typically go back and mechanically set the linkages so that no trim is needed,, once I maiden and get an idea where they need to be. That way you can use different transmitters w/o worrying about having to retim, etc.
33% Extra DLE 111, DX8
33% Extra for 3D, DX8
Hide Signatures
(in reply to BuschBarber)
       Post #: 3
RE: 9505 Duel Ele - 1/1/2013 7:29 AM
codimasta
Score: 100
Status: online
Try this:
Hook up 2 Servo Elevator
#1. Go to DEVICE SELECT and rotate the roller until you are under AUX3 (on the bottom of the screen), Press the roller and INH AUX3
#2. Go to WING TYPE: NORMAL and rotate the roller until you are under ELEV, Press the roller and select AUX3.
NOTE: You may have to REVERSE AUX2 OR AUX3 or both depends on the hookup of the linkage.
NOTE:
Connect the Elevators Right Elevator to Elevator and Left Elevator to Aux3.
Hide Signatures
(in reply to Len Todd)
       Post #: 4
RE: 9505 Duel Ele - 1/1/2013 1:55 PM
BarracudaHockey
Score: 280
Status: offline
Rich is correct, using mates is the only way to get the trim to follow.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to codimasta)
       Post #: 5
RE: 9505 Duel Ele - 1/1/2013 2:59 PM
MX240
Score: 115
Status: offline
Ha, Thanks a bunch guys...you were all a great help. Now it works.
But, how/where do you find this "mate" thing?
Using two channels for the ailerons it's "mate" would be??
Jim
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 6
RE: 9505 Duel Ele - 1/1/2013 4:59 PM
codimasta
Score: 100
Status: online
When using the DEVICE SELECT you are using the MATE function.
Dual Ailerons:
Hook up 2 Servo Aileron non Flaperon
roller until you are under AUX2 (on the bottom of the screen), Press the roller and INH AUX2.
#2. Go to WING TYPE: NORMAL and rotate the roller until you are under AILE, Press the roller and select AUX2.
Hide Signatures
(in reply to MX240)
       Post #: 7
RE: 9505 Duel Ele - 1/1/2013 5:08 PM
MX240
Score: 115
Status: offline
OK,
Thanks COD for that information.
Now I think I am getting the hang of it.
Everybody have a good flying New Year ahead.
Hide Signatures
       Post #: 8
RE: 9505 Duel Ele - 1/2/2013 3:15 PM
Hoosier06
Score: 105
Status: offline
The attachment will show a good start of inhibiting switche3s in Device select and then going to Wing type to mate surfaces for ailerons and dual elevater.
Click to see the file in new window.Attachment.pdf
Hide Signatures
(in reply to MX240)
       Post #: 9
RE: 9505 Duel Ele - 1/2/2013 4:11 PM
MX240
Score: 115
Status: offline
Thanks for that,
I copyed it off and put it in the book and I am sure it is already in the book (maybe) but I sure didn't see it.
Hide Signatures
(in reply to Hoosier06)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.484RCU1
