Old Gasser Trying Electric    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RC Airplane Tie Down kit for your Trailer,Truck or Van - Kit
Seller:  rcjunky2
Details:   $29.99   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> Old Gasser Trying Electric
Page: [1]
Login
Old Gasser Trying Electric - 1/2/2013 12:21 AM
jjmretired
Score: 100
Last Login: 5/23/2013
Status: offline
After flying glow and gas for twenty years, I'd like to give electric a try. Need suggestions on motor (geared??) , esc, battery sizes and charger. Make it simple. All I know about electicity is to put the plug into the wall socket.
The aircraft is a Proctor D.VII. It's a 23 lb biplane, 1/4 scale, 88" wing span. If using glow it would take a 300 twin or a 45cc -50cc gas turning a 23" to 24" prop at about 7,000 rpm.
HELP, Jay
Hide Signatures
       Post #: 1
RE: Old Gasser Trying Electric - 1/2/2013 1:32 AM
Dr Kiwi
Score: 120
Status: offline
You are way out of my league, but you might try posting here! http://www.rcgroups.com/glow-to-electric-conversions-247/
_____________________________
Dr Phil Millener, Chattanooga, TN
Hide Signatures
(in reply to jjmretired)
       Post #: 2
RE: Old Gasser Trying Electric - 1/3/2013 2:31 AM
blvdbuzzard
Score: 123
Last Login: 5/24/2013
Status: offline
I have to agree with Dr. Kiwi, your setup is out of the range of what I usually work with.
Best I can do is a direct drive setup. It should put out 24 pounds of thrust for an ever so slightly better then 1:1 power to weight.
Motor
http://www.hobbypartz.com/96m608-bigfoot160-5335-245kv.html
Battery (2) per flight, wired with a "Y" harness for 12s
http://www.hobbypartz.com/geace45c6ce.html
ESC, does not come with a BEC so you would need a battery to power the radio gear.
http://www.hobbypartz.com/07e26-proton-100a-hv.html
Prop would be an 18X8
Here is another setup
Motor
http://www.hobbyking.com/hobbyking/store/__14426__Turnigy_CA80_80_Brushless_Outrunner_50_80cc_Eq_.html
Same ESC and batteries. Calc program says 28 pounds of thrust with a 23X10 prop.
From what I have put together, there really is not need for a gear reduction any more. The out runner brushless motors work so much better then the old gear brushed motors.
Buzz
Hide Signatures
(in reply to Dr Kiwi)
       Post #: 3
RE: Old Gasser Trying Electric - 1/3/2013 3:40 AM
jjmretired
Score: 100
Status: offline
Buzz, Thanks for the info. Think Im getting an idea of what's needed. Jay
Hide Signatures
(in reply to blvdbuzzard)
       Post #: 4
RE: Old Gasser Trying Electric - 1/4/2013 5:19 AM
blvdbuzzard
Score: 123
Status: offline
There is a learning curve with E power. I look back and think of all the magic smoke I let out in learning.
Here is an online calc program. I forgot to put the link in the post above.
http://www.s4a.ch/eflight/motorcalc_e.htm
Spend some time messing with this and see what dopes what.
Buzz.
Hide Signatures
       Post #: 5
RE: Old Gasser Trying Electric - 3/16/2013 12:36 AM
flytreetimes
Score: 100
Last Login: 5/21/2013
Status: offline
 fwiw   The biggest issue with stubby nosed biplanes is getting the weight forward enough for CG. Alot of fellows use a motor larger than required to put the most weight forward possible.
To keep at 24 prop ( assuming thats scale or close), you will need a 50cc class motor, running on 12s with a 100a esc minumum. I have a Suppo 7035-8 (190kv) that can turn up to a 24/12, it would need a 160A esc for this tho.
I currently use a 23/10 for 99a 4200watts in my Aeroworks 50cc Extra, I use a Castle Creations 110HV Esc, on 12s ( two 6s/5000/30c in series). You could use a 23/6 or 8 to get the power levels down with still plenty of power for the bipe. Even at the 4200 watt level I use, the motor is barely warm after flight.
The 7035 weighs 3 lbs, same as a DA50, so balancing issues are easier, established with moving the batteries to attain CG.
I don't know how you feel about props being too small, I detest tiny little props on big airplanes. Electric allows a scale prop by matching the kv of the motor to the number a cells used and the motor amp ratings.  jm2cw  flytreetimes
Hide Signatures
       Post #: 6
RE: Old Gasser Trying Electric - 3/16/2013 1:16 AM
jjmretired
Score: 100
Status: offline
Thanks for the reply. I'm pretty far along now and hope to maiden in the next two weeks and take the D.VII to the Las Vegas Warbird fly-in April 4-6. I went with a 50cc Rim Fire, a Castle 160 ESC and two 6s/5000/40c lipos in series. I have a Vess 23A and a 22A to try. The lipos are mounted as far forward as I could get them. This might be the first WW1 biplane I've had to add weight to the tail.
Hide Signatures
(in reply to flytreetimes)
       Post #: 7
RE: Old Gasser Trying Electric - 3/16/2013 2:23 AM
flytreetimes
Score: 100
Status: offline
Hi jj   Another good combo!  Sounds ideal. Yes even a biplane can thro in some surprises and need the weight moved around.  three of us on rc groups are building 81" Mosquitos, we designed the battery box to allow the battery within 2" of the nose, figuring that would likely be its point for balance. I got mine assembled and found the battery goes Back at least 3" to get CG. Suprise!!!
Please let us know how the maiden goes, keen to hear.  flytreetimes
Hide Signatures
       Post #: 8
RE: Old Gasser Trying Electric - 3/16/2013 3:21 PM
DrMotor
Score: 100
Last Login: 4/21/2013
Status: offline
quote:
  ORIGINAL: jjmretired     This might be the first WW1 biplane I've had to add weight to the tail.
Just a thought,  JJ.   -May have been useful to have got a heavier motor,  then ...?
I note:
RimFire 50cc     Weight: 1250g       22x8 to 26x10 props
Diameter: 80mm    Length: 75mm    kV: 230
" ... the RimFire 50cc Outrunner Brushless Motor from ElectriFly is great for 3D planes up to 18 pounds and sport planes weighing up to 28 pounds ..."
I have Fliton 50cc Extra 260  (~8kg = ~17lb),  and I used a  Turnigy CA80-80 (50~80cc Eq) motor for this.    This motor weighs 1545g.
Here are some other motor choices: I personally (now) like the look of the Turnigy RotoMax 80cc Motor  -although I have not tried this myself
http://www.hobbyking.com/hobbyking/store/__17987__Turnigy_RotoMax_50cc_Size_Brushless_Outrunner_Motor.html
Turnigy RotoMax 50cc Size Brushless Outrunner Motor
Weight: 1080g
Suggested Prop:   24x12 Majzlik   -  26x12 APC
Diameter: 80mm    Length: 102mm     Total length:142mm
Turnigy CA80-80 Brushless Outrunner (50~80cc Eq)
Weight: 1545g
23in   -   26 in props
Diameter: 80mm    Length: 133mm    Total length: 152mm
http://www.hobbyking.com/hobbyking/store/__25410__Turnigy_RotoMax_80cc_Size_Brushless_Outrunner_Motor.html
Turnigy RotoMax 80cc Size Brushless Outrunner Motor
Weight: 1916g
26x8   -   27x12   props
Diameter: 108mm    Length: 110mm     Total length:142mm
There is also:    HACKER A60-18L (910g) ,    and    Hacker  A80-10 (1450g)   and other motors like this
    -but I guess they would be much more expensive than a  Rimfire 50cc or 65cc.
< Message edited by DrMotor -- 3/17/2013 6:22 PM >
Hide Signatures
       Post #: 9
RE: Old Gasser Trying Electric - 3/17/2013 5:09 PM
aeajr
Score: 205
Status: offline
subscribe
Long Island Silent Flyers
www.lisf.org
Hide Signatures
(in reply to DrMotor)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.485RCU1
