elevator hinging    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> elevator hinging
Page: [1]
Login
elevator hinging - 1/2/2013 5:43 PM
kaczonion
Score: 100
Last Login: 5/8/2013
Status: offline
I'm putting together an old kit I've had stashed in the attic for years, a 1/2 version of a dirty birdy, this one called a baby birdy and wondering what to hinge the elevator/rudder with. The kit had no hardware and the wood is only 3/32" thick. I painted the horizontal and vertical stab fearing that monokote would distort the thin wood. Tape hinge?
Hide Signatures
       Post #: 1
RE: elevator hinging - 1/3/2013 2:25 AM
Steve Steinbring
Score: 116
Last Login: 5/20/2013
Status: offline
You could use stitched hinges in a figure 8 pattern, be sure to round the stab and control surfaces where they meet to get full movement.
Hide Signatures
(in reply to kaczonion)
       Post #: 2
RE: elevator hinging - 1/3/2013 4:27 AM  1 votes
countilaw
Score: 219
Status: offline
CA hinges will work well.    Get the  medium and cut them in to two.   Or just get the small size.
Frank
_____________________________
It''s a hobby, not a job.
Hide Signatures
(in reply to Steve Steinbring)
       Post #: 3
RE: elevator hinging - 1/3/2013 5:05 AM
jester_s1
Score: 233
Status: offline
+1 on CA hinges. They will cost you no wood strength and there's nothing more permanent.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to countilaw)
       Post #: 4
RE: elevator hinging - 1/3/2013 3:06 PM
DIVERHERB
Score: 105
Last Login: 5/12/2013
Status: online
I used monokote hinges on a Pitts I built. It was just a test to see how they would work. Actually they held up very well and as a benifit there was no gap between either surface. Should work great when the material is very thin and it was very easy to do. After hinging I just finished covering the plane with the monokote. It turned out great, and was really simple.
Hide Signatures
(in reply to jester_s1)
       Post #: 5
RE: elevator hinging - 1/3/2013 5:21 PM
kaczonion
Score: 100
Status: offline
thanks for the info. I thought about the CA hinges but I don't know if my great planes hinge cutter would cut a pocket in the thin wood without making a mess.
Hide Signatures
(in reply to DIVERHERB)
       Post #: 6
RE: elevator hinging - 1/3/2013 5:44 PM
gene6029
Score: 120
Status: offline
I.m not so sure the GP hinge slotter is the tool for this job. Try useing an x acto blade & take your time. Or try the slotter first on a piece of scrap wood the same thickness.......Gene
Hide Signatures
       Post #: 7
RE: elevator hinging - 1/4/2013 4:28 AM
jester_s1
Score: 233
Status: offline
I ground a hook blade for my xacto and it's perfect for CA hinges. It's actually not sharp anywhere since what you actually need is for it to dig out the wood, not cut it.
Hide Signatures
(in reply to gene6029)
       Post #: 8
RE: elevator hinging - 1/4/2013 5:47 AM
Gray Beard
Score: 314
Status: offline
I convert a lot of the little 1/2A kits to electric and for hinges I just use covering for hinges then cover over them. Works great. Better then trying to cut hinge slots in that very thin sheeting. I have one of the Ultimates I will be building real soon. Using covering hinges on a plans built plane right now that has too thin wood for normal CA hinges.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 9
RE: elevator hinging - 2/7/2013 5:41 PM
kaczonion
Score: 100
Status: offline
Well I tried the ca hinge method which worked ok until I got in a hurry and the last slot poked out the bottom using the hinge slotter. Some sanding and filling and I cleaned it up. In this case I should of used the monokote method. Thanks all for the hints.
Hide Signatures
       Post #: 10
RE: elevator hinging - 2/7/2013 6:27 PM
BalsaBob
Score: 100
Last Login: 5/16/2013
Status: offline
I have used pieces of Monokote Trim Sheet in the past with great results. I think the trim sheet is a bit thicker/stronger that regular Monokote ..... and it is self-adhesive.
Bob
" This plan is way too ingenious to fail for the fourth time ..... "
Hide Signatures
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
