On/Off switch failed resulting in crash    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> On/Off switch failed resulting in crash
Page: [1]
Login
On/Off switch failed resulting in crash - 1/2/2013 8:58 PM
Warbird40
Score: 105
Last Login: 5/14/2013
Status: offline
Well I lost my favorite Sunday plane (Tiger 2) due to the On/Off switch failing. I did my preflight check, taxied and when I gave it full throttle I lost communication from tx to rx causing the plane to go full speed down the runway into a metal post. I checked my rx battery voltage it was fully charged, so I connected the rx batt pack directly to the rx and got full response on all my servos. Plugged it back thru the switch (no response). So my question is the following: Is there a switch available that fails in the on position and not in the off position? I would hate to loose another plane or worst yet have someone get hurt due to a bad $4 switch.
Ed
Hide Signatures
       Post #: 1
RE: On/Off switch failed resulting in crash - 1/2/2013 9:34 PM
flyinwalenda
Score: 157
Last Login: 5/21/2013
Status: online
I use the MPI Miracle  switch /regulatoron larger planes.
www.maxxprod.com/mpi/mpi-21.html
Fromco has a few different types of Failsafe switches  and I'm sure there are a few other manufactures
www.fromeco.org/Products/04FRCBADSW-420s/
They are electronic switches behind a normal looking slide switch. They also can be incorporated with a regulator (like the MPI) If the switch fails or the wires disconnect(not the main battery wire) the switch remains in the on position.
_____________________________
Brian Ray
Hide Signatures
(in reply to Warbird40)
       Post #: 2
RE: On/Off switch failed resulting in crash - 1/2/2013 9:42 PM
BarracudaHockey
Score: 280
Status: offline
The downside about fail on switches are the fact that they drain power (albiet a very small amount) when plugged in and off so you need to disconnect your reciever battery between flying days.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to flyinwalenda)
       Post #: 3
RE: On/Off switch failed resulting in crash - 1/2/2013 10:56 PM
Warbird40
Score: 105
Status: offline
I always charge my batt pack outside the plane due to me having a small car and transporting planes with wings off....so batt is only in the plane at the field.....I also check voltage on it before every flight right before I do my pre flight check of controls..... Thank you for the links, I will look into those.
Best regards,
Ed
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 4
RE: On/Off switch failed resulting in crash - 1/2/2013 11:22 PM
flyinwalenda
Score: 157
Status: online
I run LiPo and LiFe batteries in the planes with "failsafe" switches and honestly , although there is a drain when idle like Andy stated ,I haven't had a problem or noticed any increase in charging times as I leave the batteries  plugged in all of the time until I see they are ready to be charged again and I fly quite a bit. I'm sure it does drain them some and for a casual flier it would be a good idea to disconnect before storing the plane.
Good Luck. I'm sure you will find something.
Brian Ray
Hide Signatures
       Post #: 5
RE: On/Off switch failed resulting in crash - 1/3/2013 12:58 AM
Checklst
Score: 115
Status: offline
I have always used 2 switches,2 Batts...........I never found the extra weight was a problem.....Tiger 2...Sig 4*40 ect all flew great on duel packs. You could run NoBS battery from Hangtime Hobby.............they have 2 battery leads so only the second switch is needed on a single pack,at lease the switch has a back up.
Hide Signatures
       Post #: 6
RE: On/Off switch failed resulting in crash - 1/3/2013 2:16 AM
snuts
Score: 100
Status: offline
As posted above. I too have been using redundant power in my airborne equipment. I started using it about 1994 as I got into gas. I could see all the benifits, addapting it to my 40 glow stuff at the time. Was a good place to use up all the small factory switches at the time, and 600mah packs.
See attached. Great information from Hangtime Hobbies.
http://www.hangtimes.com/parallel_packs.html
-Snuts-
Hide Signatures
(in reply to Checklst)
       Post #: 7
RE: On/Off switch failed resulting in crash - 1/3/2013 2:41 AM
vicman
Score: 189
Status: offline
This has been a known issue in the pylon community for some time. The vibration our planes see causes cheaper switches to fail prematurely. Most use JR gold switches and mount them on rubber. This has cut down on occurance dramatically.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
(in reply to snuts)
       Post #: 8
RE: On/Off switch failed resulting in crash - 1/3/2013 4:06 AM
Warbird40
Score: 105
Status: offline
Thank you all for the tips/ advise!
Best regards,
Ed
Hide Signatures
(in reply to vicman)
       Post #: 9
RE: On/Off switch failed resulting in crash - 1/3/2013 5:36 AM
baronbrian
Score: 105
Last Login: 5/20/2013
Status: offline
+1 on the JR gold switches
quote:
ORIGINAL: vicman
Contest Director for the AMA
Grand Forks, North Dakota- Where time stands still but the air is always moving.
Hide Signatures
       Post #: 10
RE: On/Off switch failed resulting in crash - 1/5/2013 1:35 PM
JL1
Score: 106
Status: online
http://www.qualityrcproducts.com/products_switches.html
I have been using these for several years with zero problems.
Hide Signatures
(in reply to baronbrian)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.326RCU1
