Hitec X2-400 charger question?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/4 & 1/3 scale built lasers types gas engine - ARF
Seller:  joebiplane
Details:   $500.00   |  6/7/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Hitec X2-400 charger question?
Page: [1]
Login
Hitec X2-400 charger question? - 1/2/2013 11:08 PM
flyer2488
Score: 100
Last Login: 4/3/2013
Status: offline
 I just received my Hitec X2-400. The charger is capable of putting out 20 amps of current for charging. The cables that go from the charger to the battery are 18 gauge wire. Seems a bit small to me?  Are they capable of supporting the full 20 amp charge rate?
Hide Signatures
       Post #: 1
RE: Hitec X2-400 charger question? - 1/2/2013 11:13 PM
guver
Score: 174
Last Login: 6/19/2013
Status: offline
Maybe those are the balance wires rather than the main lead? Most main leads are at least 14 gage.
_____________________________
and airplanes were in
Hide Signatures
(in reply to flyer2488)
       Post #: 2
RE: Hitec X2-400 charger question? - 1/2/2013 11:30 PM
flyer2488
Score: 100
Status: offline
No they are indeed the wires that attach to the battery. One red, one black. It says 18awg on the side of the wires. Would you suggest making my own charge wires or contacting Hitec and asking them this question?
Hide Signatures
(in reply to guver)
       Post #: 3
RE: Hitec X2-400 charger question? - 1/2/2013 11:43 PM
guver
Score: 174
Status: offline
Depending upon which chart you use and the material and strand count , they may be just fine. At 20 amps 18 gage will probably warm up somewhat , but the worst thing might just be an artificial voltage increase read by the charger. I know I do 30 amps thru 14 gage and it's fine for < 7 minutes.
One chart I have shows 18 gage doing 16 amps for chassis wiring and 2.3 amps for power transmission. I would have trouble with it for sure because of the voltage drop.
Hide Signatures
       Post #: 4
RE: Hitec X2-400 charger question? - 1/3/2013 12:27 AM
flyer2488
Score: 100
Status: offline
Thanks for the advice, I actually dropped an email to Hitec asking this question and they said its fine and there is nothing to worry about.  Very timley response from them, I am impressed.
Hide Signatures
(in reply to guver)
       Post #: 5
RE: Hitec X2-400 charger question? - 1/3/2013 12:58 AM
Dr Kiwi
Score: 120
Last Login: 6/1/2013
Status: offline
For 18 AWG, a chart I have says: Max current @ 75 CM/A = 21.654A
How often are you going to need the full 20A for charging your pack(s)? For 1C charge rate, that is ten 2000mAh packs at once.
Dr Phil Millener, Chattanooga, TN
Hide Signatures
       Post #: 6
RE: Hitec X2-400 charger question? - 1/3/2013 1:46 AM
guver
Score: 174
Status: offline
I like your chart better, is there a link?
Hide Signatures
(in reply to Dr Kiwi)
       Post #: 7
RE: Hitec X2-400 charger question? - 1/3/2013 5:36 AM
flyer2488
Score: 100
Status: offline
I will possibly need 15 amps for a 3c charge rate on a 5000 mAh 6s battery.  I don't plan on charging at a 3C rate all the time but I bought that charger because if its capabilities to do so.  My main concern is safety obviously. I just don't need to burn the house down, wouldn't want my helicopter harmed.
A link or a picture of that chart would be awesome if you could post. Thanks
Hide Signatures
(in reply to guver)
       Post #: 8
RE: Hitec X2-400 charger question? - 1/3/2013 9:21 AM
4*60
Score: 116
Last Login: 6/20/2013
Status: offline
http://www.powerstream.com/Wire_Size.htm  indicates 16 amps for chassis wiring but I imagine that might be for a few feet??
"Of course, that''''s just my opinion. I could be wrong." the other Dennis Miller
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
