Houston, I have a problem!!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Houston, I have a problem!!!! Page: [1] 2 3 4 5   next >   >>
Login
Houston, I have a problem!!!! - 1/3/2013 1:11 AM
Gray Beard
Score: 314
Last Login: 5/22/2013
Status: offline
Not being a float plane guy this is a perplexing problem and I have no answers. I got the Swoose in the water today to check it for leaks and see how well it floated. Well, all is well except fot the stance. It really lists to the right float? I have brought it home and checked the lateral balance again, it's really good, if anything it's just a bit off to the left, not the right and not enough to bother trying to set it any better. The floats measure perfectly even to the fuse and wing. Go figure. Will the plane level out on take off when it comes on step? Not a clue. Funny thing is the right listing side is floating /sinking like the photos Mr. Ziroli took of the plane. Knowing nothing about float planes I have no clues. All I know is I'm not happy with how it sits in water. No leaks though, one out of two isn't too bad!!
Gene
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Gray Beard -- 1/4/2013 1:19 AM >
_____________________________
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 1
RE: Houston, I have a problem!!!! - 1/3/2013 1:14 AM
sensei
Score: 176
Status: offline
If you lift up and look at it from a side view are the floats in rig with one another? I swear they look out of rig in the side view picture. I mean the far float looks really high compared to the left side. In the front view it appears that L/H float is riding in the water up front lower than the other side. Maybe it's just me.
Bob
Fly It Like You Stole It!!!
Hide Signatures
(in reply to Gray Beard)
       Post #: 2
RE: Houston, I have a problem!!!! - 1/3/2013 1:20 AM
Zor
Score: 181
Status: offline
Hello Gray Beard and best wishes to you and family for the New Year.
Looking at the two pictures it appears to me that the right float is at a different angle than the left one.
The front of the right float is up higher above the water surface and its rear end is dipped in further down than the left one.
Since the rear part of the floats has less volume then the front it would go deeper in the water and create this condition even though the lateral balance is good.
Just my impession.
Zor
Hide Signatures
       Post #: 3
RE: Houston, I have a problem!!!! - 1/3/2013 1:24 AM
eddieC
Score: 249
Last Login: 5/21/2013
Status: offline
I agree with sensei.
Did you happen to weigh each float before assembly?
I might not be very good, but I am fun to watch!
Hide Signatures
(in reply to sensei)
       Post #: 4
RE: Houston, I have a problem!!!! - 1/3/2013 1:27 AM
Zor
Score: 181
Status: offline
I was typing while others were posting.
I think you have your answer.
Zor
Hide Signatures
(in reply to eddieC)
       Post #: 5
RE: Houston, I have a problem!!!! - 1/3/2013 1:34 AM
Live Wire
Score: 6329
Status: online
Gene
The floats are off alignment under power all it will do is try to run in circles. If you get it in the air, when you land you will be going fishing.
Larry K
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
(in reply to Zor)
       Post #: 6
RE: Houston, I have a problem!!!! - 1/3/2013 1:43 AM
Gray Beard
Score: 314
Status: offline
I will have to take a look and more measurements later or in the light of day but I do know one float is a little more forward then the other, like a couple inches. I was just out in the shop and measured to make sure they were both hanging the same distance from the fuse to the water, that was good. Looks and sounds like I will be bending more wire again. When I did it originally I was so sure I had everything set perfectly. So much for that thinking crap. Need to re-stock my wire anyway and I'm out of epoxy. Road Trip!! Back across town to the LHS! I just hate driving. Glad I only mounted the skirts with silicone so I can get them off. Thanks for the input Bob. First try with floats, what a pain in the hinderpoo!!
Hide Signatures
(in reply to Zor)
       Post #: 7
RE: Houston, I have a problem!!!! - 1/3/2013 2:02 AM
Live Wire
Score: 6329
Status: online
Great job building I have been watching the build. One thing I have learned, wheels and skies you can have a little off and not have to much problems. But floats are a different ketle of fish. They must be about perfect or you are going to be drying out a plane every time you try and fly it.
Larry K
Larry K AMA 36417
Hide Signatures
       Post #: 8
RE: Houston, I have a problem!!!! - 1/3/2013 2:05 AM
Live Wire
Score: 6329
Status: online
Double post
Larry K AMA 36417
Hide Signatures
       Post #: 9
RE: Houston, I have a problem!!!! - 1/3/2013 2:08 AM
Gray Beard
Score: 314
Status: offline
After dinner I will be out with my ruler seeing where I messed up. I never thought a little off would create this big of a problem. Things changed when I tightened the legs up.
Hide Signatures
(in reply to Live Wire)
       Post #: 10
RE: Houston, I have a problem!!!! - 1/3/2013 2:14 AM
sensei
Score: 176
Status: offline
I am sure you will knock it out pretty fast.
Bob
Hide Signatures
       Post #: 11
RE: Houston, I have a problem!!!! - 1/3/2013 2:36 AM
vicman
Score: 189
Status: offline
I'm curious, would you set the floats on the same incidence as the wing? Then to a tip to crankshaft distance check like you would do for a tail?
FWIW, I think there is a "Master Builder" in South Carolina looking to do some "Profeshunal" work.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
       Post #: 12
RE: Houston, I have a problem!!!! - 1/3/2013 2:56 AM
Live Wire
Score: 6329
Status: online
Piano wire does have a strange way of torqueing up when tightend down. You want to make sure the floats track and are level with each other, they should have a small amount of + incidence with the center line of the fuse to keep it from nose diving. You will find it takeing off and landing are a lot different than with tires or skies, you must keep the plane level at all times till you leave the water and do not pull up to fast or you will stall or torqe out on lift off. You have the constant drag of the water the only control you have on the water is the rudder in the water thr and elv.
Larry K
Larry K AMA 36417
Hide Signatures
       Post #: 13
RE: Houston, I have a problem!!!! - 1/3/2013 3:41 AM
Gray Beard
Score: 314
Status: offline
I discovered the left float is 1.5 inches behind the right float. Other then that all is still straight and level. It doesn't seem that much off but that's what the ruler says. I question if that left side being off or behind the right side would make it float deeper on the right side that much?? Oh well, more wire to be bought and bent. That also put the step on the left side farther back. All this thinking hurts my head!!
Hide Signatures
       Post #: 14
RE: Houston, I have a problem!!!! - 1/3/2013 4:26 AM
eddieC
Score: 249
Status: offline
I find a cold, frosty beverage..., or 5, 6..., will fix me right up !!
The next day, I've forgotten what the fuss was about.
Hide Signatures
       Post #: 15
RE: Houston, I have a problem!!!! - 1/3/2013 3:10 PM
prgonzalez
Score: 110
Status: offline
Gene,
One factor no one has addressed at this point is buoyancy. Is there a way you could test each float buoyancy without being installed in the plane?
I would check each float with same weight to see if one float has more buoyancy than the other and check where the center of buoyancy is in each float. Then alignment the floats center of buoyancy with model C.G. If both floats have same buoyancy with different center of buoyancy, missalignment will cause what you are seeing because the center of buoyancy will not be in sync with model C.G. I hope I explained this correctly.
My 0.02.
Pedro
Spitfire Brotherhood #96, Ultra Sport Brotherhood #20
Hide Signatures
       Post #: 16
RE: Houston, I have a problem!!!! - 1/3/2013 3:37 PM
flyinwalenda
Score: 157
Status: online
Looking at the pictures , it appears the right float is mounted at a different angle(tip high/tail low) than the left float. Must be the right side mount is off a bit throwing the float out of alignment. Assuming both float mounts have the same dimensions,did you check the measurements between the wing saddle and the top of each float mount on each side of the fuse? .
A little bit off you might be able to work with but if it's as much as what shows in the pic then the water handling will be affected.
Brian Ray
Hide Signatures
(in reply to prgonzalez)
       Post #: 17
RE: Houston, I have a problem!!!! - 1/3/2013 6:21 PM
hrrcflyer
Score: 121
Status: offline
Gene,
It may just be the angle, but in the first picture, it appears that the front of the plane is lower than the tail and when the plane is up on step with the floats, the angle will be worse. I'm not familiar with how the swoose usually flies, but if the front of the plane is too low, the plane may never lift off the water because the motor is angled down and there may not be enough elevator authority to overcome it. I hope what I'm trying to say makes sense.
Good luck.
David
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
(in reply to flyinwalenda)
       Post #: 18
RE: Houston, I have a problem!!!! - 1/3/2013 7:09 PM
VincentJ
Score: 145
Status: online
Sounds like you have a good handle on correcting the problem Gene.  Check out this link Post #5, you're not the only one that had problems with it in the water.
http://www.rcuniverse.com/forum/m_758722/tm.htm
VJ
Hide Signatures
(in reply to hrrcflyer)
       Post #: 19
RE: Houston, I have a problem!!!! - 1/3/2013 8:10 PM
Gray Beard
Score: 314
Status: offline
Thanks for the info and help with this. Having a handle on it would be stretching the truth by a big bunch. I spent a lot of time running in and out of the shop last night taking measurements and just sitting down and looking at it. This morning I went out and looked at it some more and I'm noticing a lot of little things. I have built a couple of planes for friends that ended up as float planes but I didn't install the floats for them. Well, I did bend and set up the wires for the #2 plane I built for a friend. I have never done a float plane for myself and this is my first and only. All I have to go by are the photos of the original build article Nick Ziroil did in 89. At this point I do see some minor things that may be causing the problem. The most blatant is the left float being one and five eights behind the right float and that really puts the step back a lot farther then the right float. My plan is to just remove the left float and match it up to the right float because how the right float looks is how both floats look in Nicks photos
As to weight, this one is fully sheeted and glassed and with the land gears on it the weight is right at 8 pounds. Nicks came in at 8.5 pounds with a .50 engine. This one has a YS 1.10 in it. The build article said he needed over a pound of lead in the nose so I went with the heavy over sized engine and spinner. Still needed about 2 ounces of lead up front. Before I make any changes I will set the plane out on the concrete and take more photos and post them. If anyone else spots any problems please point them out before I start to make the changes.
As for flight, it is really a nice plane but way over powered. Just flying around I never go over 1/4 throttle and have only gasses it a couple times doing huge loops and a high speed pass or two. Without any gear in the plane it is very light weight. I think the one I built for my friend to go electric is only 3.5 pounds without any covering on it. I did really watch the weight on them. Anything aft of the CG I made as light as I could knowing the tail heavy problem.
Floats are a mystery to me and I know of no one close to me to ask for help. Thanks for all the input.
The alignment between them measures good but they are off just a tad in the back. I will need a trip to the LHS for a lot more wire in the next few days. I just hope the three LHS has re-stocked sense I bought them out several months ago.
Thanks for the input!!
Gene
Hide Signatures
(in reply to VincentJ)
       Post #: 20
RE: Houston, I have a problem!!!! - 1/3/2013 8:40 PM
eddieC
Score: 249
Status: offline
GB, great attitude. Open to suggestions, pretty rare.
Good luck, you'll figure it out.
Hide Signatures
       Post #: 21
RE: Houston, I have a problem!!!! - 1/3/2013 8:44 PM
flyinwalenda
Score: 157
Status: online
It doesn't take much difference in measurement to move them out of vertical alignment and the longer the floats the more "out" they will be in relation to the attachment point.
Brian Ray
Hide Signatures
       Post #: 22
RE: Houston, I have a problem!!!! - 1/3/2013 9:11 PM
erik valdez
Score: 115
Status: offline
I belive thats "Houston".
Hide Signatures
       Post #: 23
RE: Houston, I have a problem!!!! - 1/3/2013 9:35 PM
eddieC
Score: 249
Status: offline
I thought he meant John, or Angelica. Maybe Danny?
Hide Signatures
(in reply to erik valdez)
       Post #: 24
RE: Houston, I have a problem!!!! - 1/3/2013 9:39 PM
Live Wire
Score: 6329
Status: online
Gene
It would be great if some of us lived a little closer to each other. This is like going to school on a PC
Larry K AMA 36417
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.797RCU1
