tigrotto1a6
Score: 108 Joined: 1/4/2010 Last Login: 4/11/2013 From: Chieti, ITALY Status: offline
Very nice setup Dan! As samattapol posted a pan and tilt system will enhance your view, if you use the goggles, the head tracker will increase the feel of "be onboard" and let you move the camera left, right, up and down, by simply moving your head. Fatsharks let you choose 4 different frequencies, so you can use up to 4 tanks without having interferences. Each tank will only need a new camera and transmitter (a compatible one) An LCD display or every AV television shall be connect directly to the glasses using AV IN OUT connection. Or, a new receiver (that is a cheap unit) will do the job. Up to 4 cameras on the same tank can be controlled from a camera switch unit abe to do it, by using only one channel of your radio. The only problem with Dan's setup will be the 2.4GHz frequency. That frequency is the same of some radios, wifi, blutooth and so on, this will give you problems if you have someone with one or more of them near you. I changed yesterday all my things, including manually modify my fatshark goggles, to work with 5,8GHz where the band is ALMOST free. However, for home usage or for a little group of people, 2,4GHz is still good.
_____________________________
Bye Andrew
Hide Signatures
