how easy should a rc bottom out    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> how easy should a rc bottom out
Page: [1]
Login
how easy should a rc bottom out - 1/4/2013 12:46 AM
t-max97
Score: 173
Last Login: 6/18/2013
Status: offline
Im sure ill get different answers but I was wondering what you guys think on how easy should a rc bottom out as in how high should you be able to drop it without it bottoming out?
_____________________________
If you dont know what your doing, its best to do it quickly.
Hide Signatures
       Post #: 1
RE: how easy should a rc bottom out - 1/4/2013 1:32 AM
i8tweety
Score: 133
Status: offline
It really depends on the type of vehicle and what you run it on.
Let's say you run an RC10B4 on a track, a 10" drop should bottom out (as you are concerned with traction and cornering and the chassis slapping on landing from jumps isn't going to cause real damage).
1 Bad Puddy Tat
Hide Signatures
(in reply to t-max97)
       Post #: 2
RE: how easy should a rc bottom out - 1/4/2013 1:49 AM
t-max97
Score: 173
Status: offline
Im mostly wondering about my 1/8 truggy I just got for bashing, It has thick shock oil, I think its 50 front 60 rear but It bottoms out from about 3 feet.
Hide Signatures
(in reply to i8tweety)
       Post #: 3
RE: how easy should a rc bottom out - 1/4/2013 2:12 AM
nitroexpress
Score: 150
Status: offline
quote:
ORIGINAL: t-max97
Are the shock pistons stock?  Are you running maximum droop?
Hide Signatures
       Post #: 4
RE: how easy should a rc bottom out - 1/4/2013 3:02 AM
t-max97
Score: 173
Status: offline
quote:
ORIGINAL: nitroexpress
quote:
ORIGINAL: t-max97
Its all stock, and yes its max droop. I turned in those screws just enough to take pressure off the shock.
Hide Signatures
(in reply to nitroexpress)
       Post #: 5
RE: how easy should a rc bottom out - 1/4/2013 8:08 AM
Foxy
Score: 2021
Status: offline
Set the suspension to give you the best traction on the track, don't worry about bottoming out, it should not factor at all in your suspension setup, these cars are designed to slap on landing.
So, you got a smartphone. You now have virtually unlimited access to the collective acquired knowledge of the entire human race in the palm of your hand, and you use it to... play Angry Birds while sitting on the toilet. Way to go!
Hide Signatures
       Post #: 6
RE: how easy should a rc bottom out - 1/4/2013 1:50 PM
phmaximus
Score: 632
Status: offline
Agreed, if u are worried about it bottoming out u can get skid plates... Great way to save the chassis
Losi Micro SCT,5IVE,8IGHTe
Tamiya BajaKing,TA01R,TL01B
Hide Signatures
(in reply to Foxy)
       Post #: 7
RE: how easy should a rc bottom out - 1/4/2013 2:05 PM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: t-max97
do not try to stiffen the shocks to stop the bottoming out, that will result in damage to the machines suspension.... bottoming out is normal and how these machines absorb impacts..... Skidplates will help save the chassis, but will result in the skidplates catching on the lips of the jumps..I prefer to run my truggies bare and replace the chassis when it wears..I hate the handling of my truggy with a skidplate....
Neal Smith..owner Clockwork Racing Engines
Hide Signatures
       Post #: 8
RE: how easy should a rc bottom out - 1/4/2013 2:48 PM
phmaximus
Score: 632
Status: offline
I'm new to the idea of skid plates, I've only got them on my 5ive. And it's a no brainer to save a $220 part with a $25 part.
I'm keen to know more bad points about them on 1/8 scale because I've been eyeing them off for my 8ight
When u say it was catching on the lip of jumps, I instantly think some minor suspension tweaks could stop that.?
I totally inderstand u don't want it bottoming out going up the jumps, say if the op was to run a chassis saver and tweaked the suspension would u even notice the slight loss of traction when bashing?
Hide Signatures
(in reply to supertib)
       Post #: 9
RE: how easy should a rc bottom out - 1/4/2013 2:52 PM
Foxy
Score: 2021
Status: offline
Not a subject worthy of discussoin since it costs only $20 to try and see for yourself how your car feels with a skid plate on it I don't use them either.
Hide Signatures
(in reply to phmaximus)
       Post #: 10
RE: how easy should a rc bottom out - 1/4/2013 3:03 PM
phmaximus
Score: 632
Status: offline
Fair enough
I do consider them a must on stake parks, that stuff is worse than a 30grit sandpaper.
Hide Signatures
(in reply to Foxy)
       Post #: 11
RE: how easy should a rc bottom out - 1/4/2013 3:26 PM
supertib
Score: 302
Status: offline
quote:
ORIGINAL: phmaximus
Bashing I would consider using skidplates...on a track I would not
you can adjust the chassis, but then you suffer other ill effects from the stiffened suspension...the cars just handle more predictably with no skidplates......the bottom of the chassis acts like a snowboard....their ability to glide makes them handle good even if they bottom out...as soon as you put a skidplate there you now take away the chassis ability to glide easilly .... which means every time you bottom out your skidplate is digging in, and on a truggy part of what makes them handle so good is the ability to bottom out and not lose forward momentum.....where a MT would get get bucked ass over tea kettle the truggy will just glide right over.........that is untill you add skidplates tot he bottom...then the truggy no longer wants to glide nearly as easily....
Hide Signatures
       Post #: 12
RE: how easy should a rc bottom out - 1/4/2013 3:27 PM
t-max97
Score: 173
Status: offline
Thanks guys, I know its supposed to bottom out and its designed that way but I was just wondering how you guys like to have them set-up. And mine came with skids on it, its a nexx 8t basically the same as the jammin x2.
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.813RCU1
