OS .61FX Prop Size Question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
AT-6 Texan
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Airplanes >> RC Scale Aircraft >> OS .61FX Prop Size Question
    Page: [1]
    Login
    OS .61FX Prop Size Question - 1/4/2013 9:35 AM
    Jeremyjsm
    Score: 100
    Last Login: 1/5/2013
    Status: offline
    im building the Top Flite 60 size AT-6 Texan & im using the OS .61FX engine i was wondering if  a master airscrew 14x6 nylon propellar is a good choice or is it way to big for the engine everywhere i look i get mixed reviews on it some say you can some say you cant, if not what would you recomend
    thank you for the help in advance
    Hide Signatures
           Post #: 1
    RE: OS .61FX Prop Size Question - 1/4/2013 12:55 PM
    Scar
    Score: 126
    Last Login: 5/22/2013
    Status: offline
    I'm using a 14X6 APC on my .91FX engines, because they provide a bit more braking than the recommended 13X7 and the 15X6 provides a bit too much braking. The 13X7 was really fast, and I had trouble slowing the Sukhoi down, the 14X6 provided all the speed I wanted, and would slow down the plane on approach.
    You can try the MA 14X6, but I think your .61 will want to spin a bit faster than your prop will allow. If it works to suit you for power, it will probably slow the plane down on approach for landing, and that can be a good thing.
    I think I'm using 12X6 and 13X6 on my .61 Zero. Enjoy your plane!
    Dave Olson
    _____________________________
    The true soldier fights not because he hates what is in front of him, but because he loves what is behind him GKChesterton
    Hide Signatures
    (in reply to Jeremyjsm)
           Post #: 2
    RE: OS .61FX Prop Size Question - 1/4/2013 3:37 PM
    scale dail
    Score: 115
    Last Login: 5/21/2013
    Status: offline
    Good advice. I run 12x6 wood props with my 61FX. For peak power you need to get to the max power RPM. Also the engine will run cooler with less load. If power and cooling are no issue, then bigger props are fine. The nylon Master Airscrews and APCs are heavy and will give you flywheel effect for lower idle.
    It does NOT have to be GIANT to be scale!
    Hide Signatures
    (in reply to Scar)
           Post #: 3
    RE: OS .61FX Prop Size Question - 1/4/2013 9:20 PM
    Jeremyjsm
    Score: 100
    Status: offline
    thank you for your input... the smaller props just look so weird on it... its like a giant with small feet... cooling will deffinately be a problem in the summer seeming how i live in las vegas hahaha
    Hide Signatures
    (in reply to scale dail)
           Post #: 4
    RE: OS .61FX Prop Size Question - 1/6/2013 9:39 PM
    vertical grimmace
    Score: 149
    Last Login: 5/23/2013
    Status: offline
    Generally, 11-7, 12-6 is the typical sized prop for a .61.
    "let''''s just say, they will be satisfied with less" Ming the Merciless
    Hide Signatures
           Post #: 5
    Page:   [1]
    Page: [1]
    AT-6 Texan
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.250RCU1
