RE: 1/6th Scale MEMPHISBELLE    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: 1/6th Scale MEMPHISBELLE
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: 1/6th Scale MEMPHISBELLE - 1/8/2013 12:26 AM
ROGER RUSSELL
Score: 115
Last Login: 5/21/2013
Status: offline
I have flown at all those places too, and have flown with Cal at Wisconsin and Indy Warbirds.
May have you on VCR I filmed at Bloomington one year.
Good luck with the rest of the build and look foward to seeing Cal fly it!
_____________________________
Remember to FLY HARD and LAND SOFT
Hide Signatures
(in reply to MEMPHISBELLE)
       Post #: 26
RE: 1/6th Scale MEMPHISBELLE - 1/8/2013 1:37 AM
MEMPHISBELLE
Score: 100
Last Login: 3/17/2013
Status: offline
a pic of the flap, 5"x49" not your typical size
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to ROGER RUSSELL)
       Post #: 27
RE: 1/6th Scale MEMPHISBELLE - 1/8/2013 4:48 AM
77chickenhawk
Score: 105
Status: offline
With 11 inch Cowles it would be awesome to see the scale engines in it. Four of the evolution 9-90's. Or better yet for of these :-)
Click for fullsize
Just Make It Look Real !!!
Hide Signatures
       Post #: 28
RE: 1/6th Scale MEMPHISBELLE - 1/10/2013 12:36 AM
91zulu
Score: 130
Status: offline
quote:
ORIGINAL: F4u5
quote:
ORIGINAL: 91zulu
G62s ???????????????? Aint that a bit much ? Look like 35s would hall the hell out that bird.
.....you mean HAUL
Yep..
91-Zulu
Hide Signatures
(in reply to F4u5)
       Post #: 29
RE: 1/6th Scale MEMPHISBELLE - 1/10/2013 12:38 AM
jeffk464
Score: 100
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: 77chickenhawk
Just have to take out a second mortgage on your house.
Hide Signatures
(in reply to 77chickenhawk)
       Post #: 30
RE: 1/6th Scale MEMPHISBELLE - 1/10/2013 12:44 AM
91zulu
Score: 130
Status: offline
ok then
91-Zulu
Hide Signatures
(in reply to 91zulu)
       Post #: 31
RE: 1/6th Scale MEMPHISBELLE - 1/10/2013 6:24 AM
BOLTMAN
Score: 101
Status: offline
quote:
ORIGINAL: 91zulu
I have seen one of these fly on 4 x DA50's. It was not too much.
A very impressive model both on the ground and in the air.
Aussie Bolts & Bits - Small fasteners for modelers
Hide Signatures
       Post #: 32
RE: 1/6th Scale MEMPHISBELLE - 1/10/2013 6:12 PM
luckyb
Score: 100
Last Login: 5/16/2013
Status: offline
I heard the Aussie one flew well on the 50's, but the guy wanted more power and upped it to 85's. Then ( only what I heard) the tail came apart in flight. 62's should be fine. Good luck.........Doug
" We didn''t come here to drop paper"......Buzz Rickson
Hide Signatures
(in reply to BOLTMAN)
       Post #: 33
RE: 1/6th Scale MEMPHISBELLE - 1/11/2013 5:41 AM
BOLTMAN
Score: 101
Status: offline
quote:
ORIGINAL: luckyb
Not correct on the engine upgrade. How do I know? I picked up 2 broken DA 50's while helping retrieving the wreckage.
It had just been fitted with new props which did provide an increase in performance. Not that he was chasing more performance, just had broken the original Solo props and changed to something more available at the time.
The tail structure has been redesigned as a result of this aircraft being lost due to flutter of the elevators which caused the tail plane to blow apart.
Hide Signatures
(in reply to luckyb)
       Post #: 34
RE: 1/6th Scale MEMPHISBELLE - 1/11/2013 6:35 AM
Rebel Flyer
Score: 105
Last Login: 5/22/2013
Status: offline
It would not look right with the Evolution radials with enlarged blisters on the cowl.
The cowls are only 10 inches wide.
Ask the Aussies if they were flying at FULL throttle, when the stab blew off. I seriously doubt it, with DA50s on it.
Rebel
Hide Signatures
       Post #: 35
RE: 1/6th Scale MEMPHISBELLE - 1/11/2013 8:18 PM
MEMPHISBELLE
Score: 100
Status: offline
starting the cockpit
Click for fullsize
Hide Signatures
(in reply to Rebel Flyer)
       Post #: 36
RE: 1/6th Scale MEMPHISBELLE - 1/12/2013 12:15 AM
luckyb
Score: 100
Status: offline
I stand corrected. I knew they had changed something. The vid was breathtaking. I do think the 62's make the same or even less power, but weigh more. We will be watching the progress. I always wanted one but size was a limiting factor. Transport was difficult. It was a wallet breaker........Doug
Hide Signatures
       Post #: 37
RE: 1/6th Scale MEMPHISBELLE - 1/12/2013 12:28 AM
luckyb
Score: 100
Status: offline
By the way, I had a Don Smith ( 1/9 scale) with Zenoah G-23's. It was good but not overpowered.........Doug
Hide Signatures
       Post #: 38
RE: 1/6th Scale MEMPHISBELLE - 1/14/2013 2:06 AM
MEMPHISBELLE
Score: 100
Status: offline
worked all day getting the cowling set up.
Click for fullsize
Hide Signatures
       Post #: 39
RE: 1/6th Scale MEMPHISBELLE - 1/14/2013 2:09 AM
MEMPHISBELLE
Score: 100
Status: offline
and the other side
Click for fullsize
Hide Signatures
       Post #: 40
RE: 1/6th Scale MEMPHISBELLE - 1/14/2013 2:23 AM
FireBee
Score: 100
Status: offline
Wes, she is looking great.
I once drove 30 miles on short notice just to see the real Memphis Belle refuel and take off enroute to an air show. It was so cool as they started all 4 engines and then taxied, then took off. Priceless memory!
I used to use Enviro-tec epoxy. I loved it as no smell. Where do you find it these days?
R,
Mike
Mike P.
Hide Signatures
       Post #: 41
RE: 1/6th Scale MEMPHISBELLE - 1/14/2013 3:10 AM
MEMPHISBELLE
Score: 100
Status: offline
local true value has it in stock. I got hooked when I went for a ride and was able to sit in the pilots seat for 10 minutes and make 4 turns in it.
Hide Signatures
(in reply to FireBee)
       Post #: 42
RE: 1/6th Scale MEMPHISBELLE - 1/14/2013 2:06 PM
tardster
Score: 100
Status: offline
Damn, I will go for a ride the next chance I get, I missed it the last 2 times because of work. I've dreamed of sitting in the pilots seat but to actually turn the plane would make me wet myself in a good way lol....
Lower, Lower, Ah Damnit
Ed P-40 Brotherhood # 61
Hide Signatures
       Post #: 43
RE: 1/6th Scale MEMPHISBELLE - 1/14/2013 6:38 PM
MEMPHISBELLE
Score: 100
Status: offline
I had to pay 585.00to go for the ride and fly it. ride was 1 hour and 10 min in the pilots seat. I did take my cam corder and camera. I have some great shots from in the nose. They had a raffle the same day for the same ride at a dollar a ticket. My dad was along with my brother who had a broken foot, dad bought a ticket and then had to leave so he gave it to my brother and guess what, he won the ride. He had received the call the same night and thought I was playing a joke on him. I went back the next day to watch him go for his ride. I was for my 30th birthday. Something I will never forget.
Hide Signatures
(in reply to tardster)
       Post #: 44
RE: 1/6th Scale MEMPHISBELLE - 1/15/2013 5:12 AM
tardster
Score: 100
Status: offline
I talked to Scott today at libertyfoundation.org and asked for this years schedule and about military discounts. He told me they are actually working on the new schedule and that being in the military I get a $100.00 discount so the first chance I get I hope to be sitting up there in the pilots seat. Dude I'm like a kid right before christmas now since I know they will be here in my area twice this year...
Hide Signatures
       Post #: 45
RE: 1/6th Scale MEMPHISBELLE - 1/15/2013 8:20 PM
Cal Branton
Score: 100
Status: offline
WOW! Those cowls look really good Wes.
Hide Signatures
       Post #: 46
RE: 1/6th Scale MEMPHISBELLE - 1/19/2013 4:45 AM
MEMPHISBELLE
Score: 100
Status: offline
added the fairing on the rear of the fuse.
Click for fullsize
Hide Signatures
(in reply to Cal Branton)
       Post #: 47
RE: 1/6th Scale MEMPHISBELLE - 1/19/2013 4:47 AM
MEMPHISBELLE
Score: 100
Status: offline
more
Click for fullsize
Hide Signatures
       Post #: 48
RE: 1/6th Scale MEMPHISBELLE - 1/19/2013 4:50 AM
MEMPHISBELLE
Score: 100
Status: offline
cut the top open for access to the bombbay and assembly
Click for fullsize
Hide Signatures
       Post #: 49
RE: 1/6th Scale MEMPHISBELLE - 1/21/2013 7:02 PM
MEMPHISBELLE
Score: 100
Status: offline
put the bird on the scale last night. wings are 38 lbs each and the fuse and tail feathers are 34 lbs.
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.547RCU1
