2oz cloth    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> 2oz cloth
Page: [1]
Login
2oz cloth - 1/5/2013 1:25 PM
Joe Westrich
Score: 105
Last Login: 5/18/2013
Status: offline
Ok, recently I just asked about Kevlar cloth and got a little education on it. I am now going to 2oz fiberglass, but I just had one more question. What would be the difference between single weave and double weave cloth? What would be the best for our RC application? I have fiberglassed a few airframes before, so I'm not new. I just want a better education.
Thanks!
_____________________________
Cincinnati Jet Club
Hide Signatures
       Post #: 1
RE: 2oz cloth - 1/5/2013 1:37 PM
Bob_B
Score: 100
Status: online
Joe i have never used heavier tha 3/4 ounce cloth for finishing. Why 2ounce cloth?
Cincinnati Jet Club, Team Futaba, Wren Turbines USA
Hide Signatures
(in reply to Joe Westrich)
       Post #: 2
RE: 2oz cloth - 1/5/2013 1:53 PM
Joe Westrich
Score: 105
Status: offline
50+ lb jet with a P200
I use 3/4 on my 1/5 prop warbirds
I may go lighter than 2oz on the tail surfaces
Cincinnati Jet Club
Hide Signatures
(in reply to Bob_B)
       Post #: 3
RE: 2oz cloth - 1/5/2013 2:03 PM
thunderchief
Score: 100
Last Login: 2/28/2013
Status: offline
Joe, Check out this web site for cloth selection. They are out side of Dayton. If you use 2 oz I would consider vacuum bagging it.
Glenn
http://www.fibreglast.com/
Hide Signatures
       Post #: 4
RE: 2oz cloth - 1/5/2013 2:07 PM
invertmast
Score: 193
Status: offline
I have never heare of single weave and double weave.. You typically have
Unidirectional
Tow
Plain weave
4HS (crowsfoot)
8HS
Thayercraft.com has good info on glass, along with good prices
Thomas W.
Euro-sport Evo, Scratch built 1/7 F-14D Tomcat, 26.5% Gee Bee R2
Hide Signatures
       Post #: 5
RE: 2oz cloth - 1/5/2013 2:37 PM
Robrow
Score: 100
Status: offline
I think double=Twill where the warp fibres go over/under two of the weft, better drapability for getting into awkward corners and conforming to compound curves, etc. It has a front and back.
Rob.
UK distributor: Jets Munt Merlin 90, 140 & 160. Jet Central UK. FADEC ECU''''s UK
Hide Signatures
(in reply to invertmast)
       Post #: 6
RE: 2oz cloth - 1/5/2013 3:00 PM
invertmast
Score: 193
Status: offline
Oh ok, i forgot about twill weave
Thomas W.
Hide Signatures
(in reply to Robrow)
       Post #: 7
RE: 2oz cloth - 1/5/2013 3:09 PM
sidgates
Score: 100
Status: offline
I have gotten better answers about cloth, resin and mold making on this thread
http://www.rcuniverse.com/forum/forumid_97/tt.htm
SidGates
Web: http://www.sidgates.us
Hide Signatures
       Post #: 8
RE: 2oz cloth - 1/6/2013 2:52 AM
Joe Westrich
Score: 105
Status: offline
quote:
ORIGINAL: invertmast
Unidirectional
Tow
Plain weave
4HS (crowsfoot)
8HS
That's kind of what I was looking at. Why the different formats and what applications would they be used for?
Cincinnati Jet Club
Hide Signatures
       Post #: 9
RE: 2oz cloth - 1/6/2013 2:55 AM
Joe Westrich
Score: 105
Status: offline
quote:
ORIGINAL: thunderchief
Glenn
A friend told me of that site too.
Is it manageable without vacuum bagging it. I don't have one.
Cincinnati Jet Club
Hide Signatures
(in reply to thunderchief)
       Post #: 10
RE: 2oz cloth - 1/6/2013 3:14 AM
thunderchief
Score: 100
Status: offline
Sure, you can treat 2 oz cloth just like you would 3/4 oz or 1/2 oz cloth. When I lay up a mold my first layer is always a 2 oz layer of cloth because it is very easy to work with. It just takes more resin to fill the weave then 3/4 oz..
Glenn
Hide Signatures
       Post #: 11
RE: 2oz cloth - 1/6/2013 3:55 AM
invertmast
Score: 193
Status: offline
quote:
ORIGINAL: Joe Westrich
Unidirectional
Tow
Plain weave
4HS (crowsfoot)
8HS
Uni-directional is a fabric that has all of the glass strands going in one direction. This works well for needing strength in one direction only (spar caps for instance).
Tow is a non woven cord
Plain weave can be easy to work (conforms easier) with if it is loosely woven.. If its tightly woven (which is what I would suggest for glassing) it doesn't conform as well, but requires less filling of the weave. It also provides a consistent surface due to how it is woven.
4HS and 8HS is a bit stronger (less thread crimp) and offers greater conform-ability than plain woven fabric. I've never heard of anyone using this outside of a molded part.
Twill is kind of in between Plain and 4HS and 8HS in how it is woven. Typically when you see a "pretty" Carbon Fiber part, it is a twill weave carbon.
Thomas W.
Hide Signatures
       Post #: 12
RE: 2oz cloth - 1/6/2013 4:57 AM
sidgates
Score: 100
Status: offline
I use 2oz or 3.2oz crowfoot for my first layer in a mold. Below is a quote from WyoWindWorks on crowfoot.
Style 120 and 220 are good choices. The 120 will be slightly more flexible while the 220 is a little stronger. Either will work well.
Crowfoot is the same as a Harness Satin 4. The yarns go over 3, under 1, over 3, under 1, etc. This weave allows the fabric to be more conforming than a plain weave. It also allows the yarns to lay flatter. This is theoretically stronger since the frequency in the crimp of the fiber is reduced.
SidGates
Hide Signatures
       Post #: 13
RE: 2oz cloth - 1/6/2013 6:19 AM
mr_matt
Score: 116
Status: offline
How would he vacuum bag? Isn't this going to cover the outside of a wood structure?
Matt
Hide Signatures
(in reply to sidgates)
       Post #: 14
RE: 2oz cloth - 1/6/2013 1:49 PM
invertmast
Score: 193
Status: offline
You either vacuum bag with a foam core wing, or in a mold. Theres really no good way of vacuum bagging any other type of build structure
Thomas W.
Hide Signatures
(in reply to mr_matt)
       Post #: 15
RE: 2oz cloth - 1/6/2013 2:51 PM
thunderchief
Score: 100
Status: offline
Right,, to vacuum bag it would have to be a foam wing. Vaccuum would probably damage a build up part
Glenn
Hide Signatures
       Post #: 16
RE: 2oz cloth - 1/6/2013 4:48 PM
sidgates
Score: 100
Status: offline
I don't find any need to vacuum bag when doing one layer of cloth on a sheeted surface..
SidGates
Hide Signatures
       Post #: 17
RE: 2oz cloth - 1/6/2013 5:12 PM
mr_matt
Score: 116
Status: offline
quote:
ORIGINAL: sidgates
Exactly
Matt
Hide Signatures
       Post #: 18
RE: 2oz cloth - 1/6/2013 10:28 PM
invertmast
Score: 193
Status: offline
quote:
ORIGINAL: sidgates
If you use some waxed mylar sheet (.014" thick) you can paint the mylars, the put a layer of wet out glass or carbon on the mylars. Then blot up the excess resin with a paper towel, then while wet you can vacuum bag this to a wing or tail surface. Once it cures, the mylars peel away leaving a painted part. This only works in simple surfaces though. Any compound curves makes it impossible to do.
Thomas W.
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
