Patriot XL Conversion    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Glow to Electric Conversions >> Patriot XL Conversion
Page: [1]
Login
Patriot XL Conversion - 1/5/2013 7:15 PM
fun2fly
Score: 100
Last Login: 5/12/2013
Status: offline
I am getting ready to build a GP Patriot XL (.60-.90 glow) and I am considering building it as an electric versus a glow. I am having trouble determining the proper size motor for it. I am trying to keep it in the limits with my current charging capabilities which caps out at a 6s pack. I have looked at the Rim Fire 50-50-500 and the Turnigy SK3 50-45-500 both which will handle a 6s pack and throw the right size prop. Once built the plane should come out to around 9 to 10 lbs depending on the equipment and landing gear setup. I want to make sure I get a motor that will give me good performance considering the type of plane the Patriot is. Any and all advice welcomed.
_____________________________
Fun2Fly
Hide Signatures
       Post #: 1
RE: Patriot XL Conversion - 1/5/2013 8:08 PM
blvdbuzzard
Score: 123
Last Login: 5/11/2013
Status: offline
Here is .60 sized motor that runs well on 6s. Turning a 18X8 prop pulls 1200 watts and 188 ounces, 11 3/4 pounds of thrust.
http://www.hobbypartz.com/96m606-bigfoot60-4030-400kv.html
If you use different props you can get different prop speeds.
Running a 15X10 prop takes the prop speed up to 87 mph, 252 ounces, 15 pounds of thrust, but is 7 amps over the rating and it says the prop may stall, so at low speed the prop may not be as efficient as it could be.
Here is a free online calc program
http://www.s4a.ch/eflight/motorcalc_e.htm
Buzz.
Hide Signatures
(in reply to fun2fly)
       Post #: 2
RE: Patriot XL Conversion - 1/9/2013 3:11 AM
fun2fly
Score: 100
Status: offline
Thanks for the calculator.. I have been running different setup through it.. Have used it to set up a plane? If so how accurate was it?
Fun2Fly
Hide Signatures
(in reply to blvdbuzzard)
       Post #: 3
RE: Patriot XL Conversion - 1/10/2013 4:02 AM
blvdbuzzard
Score: 123
Status: offline
Well I found it was about 10% or so. I used it to get the numbers for my 60 sized low wing trainer, 46 sized Giles 202, Ace Mach None, Formula 3D, and almost every other plane I have. I find I get about 2 to 3 times longer flights then they say. I find I have let the magic smoke out a lot less with the calc program then before I used it.
Buzz.
Hide Signatures
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.234RCU1
