flyinwalenda
Joined: 10/28/2009 Last Login: 5/18/2013 From: Hunlock Creek, PA, USA Status: offline
Understood about trying to keep it stock but if you do nothing else right now, at the least change out the plug. You can always put the new ring in later on down the road...or runway ! Here is Frank Bowman's info: Frank Bowman at Bowman Rings. Email: ringmaster46 AT msn DOT com Reproduction Model Engine Rings Quality at a fair honest price. Making a good ring is a Skill. Making a fine ring is an Art! Last Revised 7 - 19 -12 I will reproduce nearly any model engine ring. If not available, I’ll need a good piston and cylinder to measure, or send motor. Send return postage, insurance is extra. For orders outside of USA, ask for shipping costs? Priority postage is extra. Ring cost & shipping charges for USA listed below. Please Note: If you send me an engine for new rings that I don't currently make there will be No labor charge to do this. If you send me the stripped down engine block ( Block, piston liner and rod assy.) for rings, that I Do currently make No extra charge. If you send me a complete engine to disassemble, clean, and install the ring(s) and reassemble there will be a minimum charge of $25.00 per hour. ATTENTION : NEW MEXICO CUSTOMERS WE HAVE TO CHARGE YOU 7.125% TAX, please add the extra tax to your orders. Standard ring up to .29 size $9.00 ea. N.M tax rate (1) .64 (2) $1.28 Standard ring .30 to .65 engines: $10.00 ea. " (1) .71 (2) $1.43 Standard ring .66 to engines up to 1.999 bore: $11.00 ea. " (1) .78 (2) $1.57 Standard ring with 2" bore to 2.999 bore $12 ea. " (1) .86 (2) $1.71 Dykes ring up to .29 size $10 ea. " (1) .71 (2) $1.42 Dykes ring .30 to .65 engine: $11.00 ea. " (1) .78 (2) $1.57 Dykes ring .66 to engines up to 1.999 bore: $12.00 ea. " (1) .86 (2) $1.71 Dykes ring 2" bore to 2.999 bore $13.00 ea. " (1) .93 (2) $1.85 Shipping per order $4 First Class anywhere. Priority in USA only $5.90, both with delivery conformation. For out of US shipping charges other than First Class, email for more options. Canadian Postal Money Orders Fine, US Dollars, or Paypal. For Paypal payments use my email address, or I can invoice you thru Paypal. I also accept Checks or Money Orders if they are from a US Bank. ** I also make special rings to order, ask for prices** Abatar 120 4/C Ace Twin .64 Aero .35 Aerrow 100 (pin) Quadra Aerrow 200 (pin) Quadra Aerovat 65 CC (pin) Aircom M61 (pin) Air-O .45 Anderson Spitfire .65 Area 51CC (pin) Asp .52 4C, .61 (pin), .65 4/C, .80 4/C, .91 4/C Atomic 60 Don Sohr Atwood .49, .51, .63 Avion Mercury 1.609 Avistar .60 (pin) Bantam .16 Bat .19 Bennelli 65 CC (pin) motorcycle Berilli 36 CC (Pin) BME 3.5 Twin (pin), 105 (pin), 110 twin (pin) Brillelli 60 CC (pin) Brison 2.4 (pin), 3.2 (pin) Brown Jr. .60 cylinder sizes vary (send Piston & cylinder for proper fit & correct ring) Brownie .29 Bushwacker 37.7 CC (pin) Sears Bunch .45, .49 Cameron .15, .19 Cave Cobra Chung Yang 29CC (pin) Cleveland Tom Thumb .45 Comer 50CC (pin) Como .29 (pin), .40 (pin), .51 (pin), .90 (pin) Contestor D.60 CRRC Pro 26CC offset pin notch, CRRC 26 centered pin notch, 40 CC (pin), Pro 45 CC (pin), GF 50 i (pin), GF 55 Twin (pin) CS .53 (pin) Cub Cadet 25CC (pin) DA 50 (pin)1.681 Bore, 50R (pin)1.678 Bore, 60 (pin), 75 (pin), 85 (pin), 150 Twin (pin), 170 Twin (pin) DL 50 CC (pin) DLA 32 CC (pin), 56 CC (pin), 112 CC Twin (pin) DLE 20 CC (pin), 30 CC (pin), 55 CC (pin),110 Twin (pin), 170 Twin (pin), 222 4 cylinder (pin) DME 100 Twin (pin) Dooling .29, .61, Yellow Jacket DZY 48 CC Twin (Pin) Echo 16CC (pin), 21CC (pin), 21.2 CC (pin), 24.4 CC (pin), 30 CC (pin), CS-3000 (pin), 50 CC (pin), 65 CC (pin) Edco Sky Devil .64 Old or New (RJL) state which one? Elf Andrea Heine Repo Enya 3.5 (pin), .30 SS (pin), .35 X (pin), .40 X Dykes (pin), .40 Dykes model 6002, .40 4/C, .45, .45SS (pin), .46 4/C,.49 X (pin), 50SS (pin),.53 4/C, .60 4/C, .60 X (pin), .60 standard, .61 CXLR rear Ex.(pin), .61CXRS side Ex.(pin), .80 X (pin), .80 4/C, .90 4/C, 120 4/C, 120 R 4/C, 1.55 4/C, 240 4/C Twin ETA .29 EVO 150 Twin (pin) EVRA 190 Forster .29, .31, .88, .99 Fox 36 Sand Cast (pin), .40 Sch., .45, .50, .59 .047 thick ring and .030, .59 long shaft Ign., .60 Blue Head, .60 Eagle, Eagle II .60 (pin), Hawk Red Head .60 (pin), .74, .78, 120 Twin (pin), Gas Bore 1.439 ? (pin) FPE 4.2 69CC (pin) FTL 52 CC (pin) Fuji 32CC (pin), 43 CC EI (pin), BT50 SB (pin) GMS .61 (pin), .61 Dykes (pin), .76 Dykes (pin),.76 Std. (pin), 1.20 Dykes (pin) GP 88 single (pin), GP 176 Twin (pin) Hassad Blue Streak .64 HB .21 Dykes,.25 Dykes, .40 PDP Dykes, .40 Black Head (pin), .50 Dykes, .61 (pin), .61 Dykes Hiller (Car) Hirobo 36 (pin) HK 24 (pin) Homelite HK-24 (pin), 25 CC, 30 CC (pin) old .060 thick pin centered (press in ) , 30 CC newer .030 thick (pin), 30 CC new style Off set pin, 33 CC (pin), 38 CC (pin), 40.6 CC Super EZ Chain Saw, Super Mini Chainsaw Dykes (pin), 45 (pin), 50 CC (pin) Honda SA 50 (pin) Horner 3.7 Twin (pin) Hornet .19, .60 Howler .60 (pin) HP .21 4/C Dykes ,.40 (pin) ,.61 R.I. Silver Star (pin), .61 Dykes (pin) Blk Case Gold Hd. Hurluman 60 Husqvarna 2100 (pin) Chainsaw Pin needs pressed in 1/2 way Irvine .20 Dykes, .25 Dykes, .36, .40 Pylon Dykes (pin), .40 Standard (pin), .46 MKII Q46 Dykes, .61 Dykes, 120 Dykes, 150 standard non pin. JBA 15 CC (pin) JC Evo 23 CC (pin), 28 CC (pin), 30 CC (pin), 60 CC (pin), 1.20 CC (pin) John Deere 100 G Kavan MK 50 Kaw T5A 60 CC (pin) Artic cat Snowmobile Kawasaki 22 CC (pin) KDC Kioritz 21.2 CC (pin), 23.6, 25 CC (pin), 30 CC (pin), 58 CC (pin) K&B .35 Dykes, .40 Dykes, .40 S Dykes (pin), .61, .61 Dykes (Lee Custom), 1.35 (pin), 1.5 (pin) Kometa 29 Kraft .61 (pin) Kratmo 10 CC, 4A Ignition Laser 61 4/C Lewis 60 Magnum .52 RFS 4/C, .53 XL 4/C, .61 XL (pin), .61 4/C, 70 4/C, .91 XL 4C, 120 4/C, 120 (pin) Maloney 100 (pin), 125 (pin) McCoy .09, .19, .19 Dykes B.H., .21 Dykes Car, .29 all versions, .29 Dykes B.H., .35 Dykes B.H., .36, .40 Dykes B.H., .49, .55, .60, .60 Dykes McCulloch 15 CC ? (pin) 1.024 Bore, 21 CC (pin), 21 CC 60SX (pin), 25 CC (pin) MDB 90 Leaf Blower, 28 CC, 32 CC (pin), 50 CC (pin) MDL 28 CC (pin) MDS .78 (pin), 1.48 (pin), 2.18 (pin) Merco .40, .49, .49 Dykes, .50, .61, .61 Dykes Micron 60 MLD 28 (pin), MLD 70 twin (pin) Moki M .51 (pin), .61 (pin), 1.20 (pin), 1.35 (pin), 1.50 (pin), 1.80 (pin), 2.10 (pin) MT 42CC (pin), 50CC (pin), 57CC (pin), 65CC ? Twin (pin) MVVS .40 Dykes (pin) O&R Industrial Motor 1 HP OPS Maxi .30 (pin) OS .20 FS 4C, .26 4C, .28 FH Dykes (pin), .30 fs 4/c, .32 (pin), .37 H (pin), .40 H Dykes, .40H Standard, .40 H (P) Pylon, .40 FS 4/C, .40 SF (pin), .807 bore, .40 SR (pin), .40 FSR .835 Bore (pin), .40SR Dykes (pin), .45 FSR (pin), .45 FSR Dykes (pin),.45 RSR Dykes, .46FX (pin), .46SF (pin), .46 SF-H (pin), .46 4/C, .48 4/C Surpass, Max .50 old, .50 FSR Dykes (pin) ,.50 H (pin), .50 SX & SXH (pin), .52 4/C surpass, .55 Hyper (pin), .58, Max-H .60, .60 FS 4/C, .60 FSR (pin) .9445 Bore ,.61 SF .9055 Bore (pin), .61 FS 4/C, .61 SX (pin), .61 SXH (pin), .65 RSR (pin), .70 4/C, .70 SZ-H (pin), .75 4/C Surpass, .80 H,.80 Dykes (pin), FS.90 4/C, .91Surpass 4C, .90 FSR (pin), .91 FSR (pin), .91 FX (pin), .91 SX H (pin), .95 AX (pin), 105 HZ-R (pin), 1.08 BX-1 (pin), 120 4/C, 120 twin 4/C, 120 AX (pin), 160 FX (pin), 160 4/C, BGX-1 3500 (pin) Peak .65 (pin) Pioneer Grass Trimmer Model B 440, 42CC (pin) Poulan 15 CC (pin), 25CC (pin), 25 CC Featherlite (pin), 32CC (pin), 35 CC (pin), 42 CC (pin), 42 CC Wildthing (pin), 46 CC (pin), 54 CC (pin), 60 CC (pin) Price Midget Profi .40 (pin), .61 (pin), .76 (pin) PTE 36 (pin) Quadra 35 CC , 40 CC (pin), 42 CC (pin), 50 CC (pin), 52CC (pin) ?, 100CC Aerrow (pin), 150 Twin (pin) , 200 CC Aerrow Twin (pin) Quick Draw CC (pin) RCGF 15 CC (pin), 20 CC (pin), 26 CC (pin), 32 CC (pin), 45 CC (pin) RCS 1.40 (pin) Ross .60 Dykes (pin), .60 opposed twin Dykes (pin), .61 (pin) Rossi Speed .60 old, .60 (pin) .021, .61 (pin) .023, .65 (pin) .0235, Speed .65 (pin) Rowell .60 Royal 40 (pin) Ryobi 26 mm Bore EJ 100 (pin), 31CC (pin) older .064 thick, 31 CC (pin) older .047 thick, 31CC latest model (pin) Sabre .49 Sachs 2.0 (pin), 3.2 (pin) offset, 3.2 (pin) centered, 5.8 (pin), 80B (pin) Saito FA .30 4/C, .40 4/C, FA .45 4/C, FA .50 4/C, FA .56 4/C, FA .60 Twin 4/C , FA .62 4/C, FA .65 4/C, 72 4/C, FA .80 4/C, FA 82 4/C, .90 4/C, .91 4/C, 100 4/C, 120 4/C, FA125 Golden Knight 4/C, FG 20 125 4/C, 130 TD 4/C Twin, 150 4/C .0585 thick, 150 4/C .039 thick, 180 4/C, 270 4/C Twin, 300 4/C Twin .0585 thick, & .039 thick. Sap-180 HP 1.2 (pin) Scott Thunderbird Sears Weedeater, Bushwacker,18 CC, 21 CC, 25 CC, 25 CC TWC Leaf Blower, 37.7, all pinned, 1966 Allstate Moter Cycle engine made by Puch (pin) Shindiawa 33 CC (pin) SIFK 29CC (pin) AKA CY, Chun Yang Skil chainsaw (pin) Sky Chief .53 Solo 2/C tiller approx. 20CC (pin) Spe 25.4 (pin), 26 CC (pin), 40CC (pin), 45CC (pin) Stihl 25.4 (pin), 30CC (pin), 36CC 4/C, 028 Chain Saw 44CC (pin), 45CC (pin), Super 45 (pin), 57CC (pin), 066 (pin), 62CC (pin), MS 440 Chainsaw, MS 441 Chain saw, 70 CC (pin) Super Tigre G20.15, G20 .19, G20 X.25, S .29 (pin), G21.29 old, .34 (pin), .40 Bullring, S.40 (pin), G21.40 std., G21 .40 Dykes, G21.46 std. ,S.45 (pin), V.45, X.45 (Pin), G21 .46 wide Dykes, G.46, G .46 Bullring, V 51, G51 (pin) Italian, G51 (pin) China, V.56, V.56 Dykes, V 60 light case .044 or .047 top to bottom measurement, G24 60 Old, G 60 Bluehead, X60 (pin), V.60 wide & narrow Dykes, S.61 (pin), G.71, S.75 (pin) Italian, S.75 China, G.90 (pin) Italian, G.90 (pin) China, 2000 (pin), 2300 (pin), 2500 (pin), 3000 (pin) Italian, 3000 (pin) China, 3250 (pin) Italian, 3250 (pin) China, 4500 (pin) SV 50 CC (pin) Syncro B-30, Syncro ACE, Syncro ACE Special Tartan 1.34 (pin), Twin .77 (pin) Tech 23CC (pin) Technipower 7 Cylinder radial, B series, 9 cylinder TGY 26cc (pin) 3MM 53 TOC (pin), 150 Twin (pin) 3W 26 CC (pin), 80 CC Boxer Twin (pin), 85cc (pin), 170cc twin (pin) Thunder Tiger .39 (pin), Pro .50 H (pin), .53 Red Line Heli (pin), .54 4C, .91 FS 4C, Pro .91 2C (pin), Pro 120 (pin) Toki .40 (pin) Troy Bilt 31CC (pin) Tune Hill .36 (pin) Turnigy 30 CC (pin), 50 CC TR-50 HP pin), 52 CC (pin) Ueda .45, .61 US 25 CC (pin) Vlvatam 2.5, 5 CC Veco .19 Dykes, .21 Dykes, .50 Dykes, .61, .61 Dykes Vega 10CC, 91 4/C Webra .32 Speed Dykes (pin), 35 (pin), 10 ccm, 6.5 (pin), .40, .40 (pin), .40 Dykes (pin), .50 Dykes (pin), 52 (pin), .55C AAR Red Head Heli (pin), .61, .61 (pin), Speed .61 FS (pin), Speed .61 F Dykes (pin), .61 Dykes (pin), Speed 70 (pin), T480 4C Dykes, .91 (pin), 91 PS (pin), 120 Dykes (pin), 1.2 LS (pin), 91 T 4.90 (pin), R-145 (pin), 150 Speed (pin), 35 CC? Bully (pin) Weedeater 18 CC (pin), 21CC (pin), 25CC (pin) 1.358 Bore, 25CC (pin) 1.380 Bore, 28 CC (pin), 32CC (pin) Weedwacker 25CC (pin) Westbury Atom III XYZ 26CC (pin), 53CC STS twin (pin), 52CC single (pin) Yamaha 30 CC (pin), 50CC (pin) YS .50 ST,.61 Long Stroke (pin), .63 4/C, .80 H (pin) 2C, F.91 AC 4C, .91 2C (pin), 110 4/C, FZ-115S, F-120, 140-L, FZ-115S Crankshaft seal ring, (120 SC, 140L, DZ 160) Crankshaft Seal Ring YW 24CC single & 48CC Twin (pin) ZDZ 40 (pin), 50 NG RV (pin), 60 RV (pin), early 80 RV (pin), later 80 - J model (pin), 90 - 180 twin (pin), 1.05 single (pin) 2.10 Twin (pin) ZEN G270 (pin) AKA Chung Yang Zenoah G20 (Pin), G23 (pin), G26 (pin), G38 (pin), G45 (pin), G62 (pin), GT-80 Twin (pin)
< Message edited by flyinwalenda -- 1/6/2013 12:52 PM >
_____________________________
Brian Ray
Hide Signatures
