No Brakes?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car Engines >> Car Nitro & Gas Engines >> No Brakes?
Page: [1]
Login
No Brakes? - 1/6/2013 4:29 AM
SeeMyDust
Score: 100
Last Login: 2/3/2013
Status: offline
 i crashed into a curb and i wasnt going that fast but from a visual look, the only thing thats messed  is the wheel rim is cracked but my brakes dont work as good as they did before i crashed. and will flooding the carb stop it from starting?
Hide Signatures
       Post #: 1
RE: No Brakes? - 1/19/2013 1:05 AM
bikeordie092
Score: 100
Last Login: 2/2/2013
Status: offline
not sure on the brakes question.. did u make sure the wheel nuts are still tight? and if it floods you wont be able to turn the motor over or it will be very very hard.
Hide Signatures
(in reply to SeeMyDust)
       Post #: 2
RE: No Brakes? - 1/19/2013 1:18 AM
Argess
Score: 151
Last Login: 5/25/2013
Status: offline
Sorry OP,...off topic for a moment, but wanted to congratulations to BikeOrdie. He came asking for help, and here he is on his 9th post helping someone else! Way to go BikeOrdie!
And he is right. Flooding will make the engine hard to start, and a really good flood job will keep the engine form turning over as BikeOrdie says. remove the glowplug, turn upside down, and roate engine a LOT! Try to start, but be ready to repeat the upside down thing. Sometimes it takes a few times.
On the brakes, maybe it jsut needs an adjustment. A crash can distrub lots of settings, usually by loosening things. So check everything is tight, and then adjust as necessary.
Hide Signatures
(in reply to bikeordie092)
       Post #: 3
RE: No Brakes? - 1/19/2013 6:21 PM
bikeordie092
Score: 100
Status: offline
lol thanks... i learned the flooding stuff trying to get mine running right lol... yes sometimes it takes MANY MANY times.
Hide Signatures
(in reply to Argess)
       Post #: 4
RE: No Brakes? - 1/19/2013 6:49 PM
Argess
Score: 151
Status: offline
No problem BikeOrdie.
To OP:
Another thought could be the steering is binding cause a constant load on the steering servo. This can cause the Receiver battery voltage to drop and the throttle/brake servo doesn't get enough power to fully put on the brakes. I['ve had the steering servo bind up due to internal gear stripping too. Causes same problem.
Try disconnecting the throttle/brake servo and then see how the brakes work (by pushing it along by hand and nailing the brakes).
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.125RCU1
