Yak 55SP 2.6M converted to Turboprop!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Yak 55SP 2.6M converted to Turboprop!!!
Page: [1] 2 3   next >   >>
Login
Yak 55SP 2.6M converted to Turboprop!!! - 1/6/2013 4:20 PM
geh3
Score: 100
Last Login: 6/10/2013
Status: offline
I like turboprops and planes that land and takeoff easy and those that are "groovy"
SO the YAK fits this bill perfectly. SO I am in the process of installing a vintage but very good
WREN 54 TurboProp into a Comp-Arf 2.6M YAK 55SP + adding a smoke system as well
This TP puts out way over 50 lbs static thrust so the plane should be a spectacular vertical performer!
the color scheme will be very close to that seen below. It WILL be a challenge to fit this particular TP in as it requires
enlarging the firewall and it will protrude into the fuse quite a bit.. but this hobby always has challenges so I am going to do it.
I like showing up at an airfields with unique planes that fly well so here goes.  The plane will be decorated like the pics below
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
WREN TURBINES USA...GO GREEN!
ALSO SEE: http://www.rcaircraft-specialties.com/
Hide Signatures
       Post #: 1
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/6/2013 4:32 PM
geh3
Score: 100
Status: offline
The TP unit is a heavy duty one with a 12mm propshaft and large bearings
so it should stand up to some agressive flying!  I will modify the exhausts so they
are re-routed out the bottom of the cowl under and to the rear somewhat to maintain the
scale appearance of the nice cowl and louvers. I will use a russian ply mount piece
from another project to get the correct distance from the firewall and to add strength..
I also converted the TP to Kero Start using the available conversion kit listed on the Wren website
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 2
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/6/2013 5:06 PM
geh3
Score: 100
Status: offline
The first of many cuts!  not for the squeamish  HAH
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 3
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/6/2013 8:40 PM
gene6029
Score: 120
Last Login: 6/18/2013
Status: online
Subscribed
Hide Signatures
(in reply to geh3)
       Post #: 4
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/6/2013 10:07 PM
Texastbird
Score: 150
Status: offline
Kind of a Russian "turbo Raven", awesome concept!
Hide Signatures
(in reply to gene6029)
       Post #: 5
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/6/2013 11:44 PM
geh3
Score: 100
Status: offline
HAH yes Russian turbo raven
good one..it should be a screamer
Hide Signatures
(in reply to Texastbird)
       Post #: 6
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/7/2013 3:09 PM
geh3
Score: 100
Status: offline
OK I had to "redo" the Lg mounts to allow clearance for the TP starter motor..
nothing is ever easy when you put a TP in a non-TP plane.
BUT all of the wood I'm using for the various transition pieces are RUSSIAN
plywood! the stuff is really strong.. SO russian ply going intio a russian model... works for me...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 7
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/7/2013 4:30 PM
geh3
Score: 100
Status: offline
moving on, there has to be some air intakes for any turboprop
I'm using one of the extra louvers supplied by C-Arf with this
plane!  It will be pusitioned on the fuse bottom with the vents pointed forward so it can direct some air
inside the plane. Also I'm adding some robust russian ply gussets and some CF to the back sides
of the frp LG leg supports. This will vastly increase the strength here as these supports are only
held in by the bottom skin and a thin ply doubler...
and the beat goes on...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by geh3 -- 1/7/2013 5:04 PM >
Hide Signatures
(in reply to geh3)
       Post #: 8
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/8/2013 12:05 AM
geh3
Score: 100
Status: offline
Ok the TP install is done at least from a mounting standpoint. I have
to give Wren some credit here, the radial mount is quite simple to do
compared to the other brands on the market that require front and rear mounting...
Now I have to do something with the exhaust...hmmmmmm
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 9
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/8/2013 10:24 PM
geh3
Score: 100
Status: offline
Moving on, I am converting the rudder from cable push-pull to direct servo action
I'm doing this because the TP I'm using weighs a tad more that the typical 100 cc gas engine
so having servos in tha back make balancing easier + I had a cable break once, making landing HAIRY!!!!!
so cutting holes for the servos as shown, using the same length servo arms as the C-Arf
phenolic ones were + I'm putting wood backers inside the fuse...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 10
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/9/2013 12:10 AM
gene6029
Score: 120
Status: online
I have been following along & have a question. Is it possible to direct the exhaust down & under the plane, instead of exiting what looks like right in front of the wing? I'm thinking of a possible heat problem on the leading edge of the wing. From your picture it appears to be exiting between the two cutouts for the louvers & thats directly in front of the leading edge....Gene
Hide Signatures
(in reply to geh3)
       Post #: 11
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/9/2013 5:20 AM
nitro wing
Score: 125
Status: offline
Thats how you keep the covering nice and tight
Hide Signatures
       Post #: 12
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/9/2013 1:18 PM
geh3
Score: 100
Status: offline
I'm planning to add a short section of manifold on each side to direct the exhaust down yes.
On this plane, there is no wing covering, it is all fiberglass but the exhaust cools off rapidly as soon as
the propwash hits it. I will post pictures on whatever I end up with
Hide Signatures
(in reply to nitro wing)
       Post #: 13
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/9/2013 5:15 PM
geh3
Score: 100
Status: offline
Rudder servos mounted.. this provides the requires throws
without the push-pull cables, one servo under each stab
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 14
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/10/2013 2:42 PM
FBaity
Score: 100
Last Login: 6/11/2013
Status: offline
I have flown the Comp ARF Yak-55 with the Wren 54 many times, great power when the Wren is running and gear box not locked up. Beware of dead stick glides as the airframe decelerates quickly even with considerable nose down deck angle. IMO the exhaust you are trying to build will not work. The main landing gear design and TP install is a failure point. Good luck.
Frank Baity
AMA 38026
Frank Baity
Contest Director
Hide Signatures
(in reply to geh3)
       Post #: 15
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/10/2013 5:04 PM
geh3
Score: 100
Status: offline
This particular TP has been massaged by Wren to eliminate gearbox failures.. it is a MK V
so I'm not worried about that. I have mounted this TP in the same manner in other planes as this one with "o" problems..
but I am concerned about the exhaust.. the safe thing would be to just extend it through the sides of the cowl, that way
there will be no extra back pressure, I'm still mulling this over.....
I repaired another YAK LG using the exact same technique shown here quite some time ago.. it is still flying.....
Hide Signatures
(in reply to FBaity)
       Post #: 16
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/10/2013 5:07 PM
daveopam
Score: 191
Status: offline
You do great work sir, but I have a question. Just to satisfy my own curiosity. Would you say the Wren needs more or less support than a 100cc Twin. I notice you doing a lot of reinforcement. I had assumed a turbine needed less "beefing up" of the motor mount due to the lack of vibration.
Thanks, david
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
       Post #: 17
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/10/2013 5:15 PM
FBaity
Score: 100
Status: offline
The MK V will also fail the gearbox. Been there, done that.
Frank Baity
Contest Director
Hide Signatures
(in reply to daveopam)
       Post #: 18
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/10/2013 5:35 PM
geh3
Score: 100
Status: offline
I did beef up the firewall yes because this TP is quite strong for an older unit, it spins a 28X10 prop at almost
7000 rpm! SO I don't want the TP mount parting company with the plane. There is additional
support structure inside the plane that I didn't photograph. I like building unique planes that are rare
but fun to fly.. hopefully I will be posting some nice videos soon...
I forgot, my experience with TP's ( Wren 44, Jet cat SPT5 ) indicates that there is a LOT less vibration than with gas motors
especially if you are careful to balance the prop! BUT there is a LOT of thrust there so you have to build robust I believe...
< Message edited by geh3 -- 1/10/2013 6:19 PM >
Hide Signatures
       Post #: 19
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/10/2013 6:25 PM
FBaity
Score: 100
Status: offline
My experience with RC TP engines, Wren 54 all series in Tuscano, Raven, YK-55 and Wren 44 both series in J-3 cub and a Crop Duster, I know Ron Ballard well.My full size TP experience, Garrett TPE331 series in Mu-2, Merlin and Turbo Commander, Pratt and Whitney PT-6 in King Air and Platus Porter.
Frank Baity
Contest Director
Hide Signatures
(in reply to geh3)
       Post #: 20
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/10/2013 7:43 PM
geh3
Score: 100
Status: offline
The new series Wren 44TP is VERY GOOD, now with K start and amazing thrust when you consider the thrust turbine is only 10 lb
( good gearbox design ) Also the latest series Jet Cat SPT5 is also quite good, I have one in a Comp-Arf SF260 ..  see...http://www.youtube.com/watch?v=io3fADGsWI8
Overall I have had excellent luck and a LOT of enjoyable flying with Wren products, and they have exceptionally good support!!!
Hide Signatures
       Post #: 21
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/11/2013 9:26 PM
geh3
Score: 100
Status: offline
TurboProp test here>>>   http://www.youtube.com/watch?v=fGX7oicbWBY
this thing is a BEAST.. I had all I could do to hold onto the other end of the table
using my left leg and arm.. it starts and runs great with the Kstart conversion kit
which uses the newest Xicoy V.10 and quite small ECU.
Many thanks to Wren Turbines USA for the help...
Hide Signatures
(in reply to geh3)
       Post #: 22
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/12/2013 3:21 PM
daveopam
Score: 191
Status: offline
Enjoyed the video and thanks for taking the time to answer my question.
david
Hide Signatures
(in reply to geh3)
       Post #: 23
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/12/2013 3:29 PM
geh3
Score: 100
Status: offline
No problem.. I wish spring was here, this maiden should be a HOOT!!!!
Hide Signatures
       Post #: 24
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/13/2013 1:46 PM
geh3
Score: 100
Status: offline
Servos installed in 1 wing, I'm using the SWB Alu double lock ones with the
HD clevises included.. quite nice!
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
