RE: Yak 55SP 2.6M converted to Turboprop!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Yak 55SP 2.6M converted to Turboprop!!!
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/14/2013 4:32 PM
geh3
Score: 100
Last Login: 5/19/2013
Status: offline
I started to add some bling
the stars are from KIRBY GRAPHICS..
this IS a Russian plane so it will get a Russian treatment
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
WREN TURBINES USA...GO GREEN!
ALSO SEE: http://www.rcaircraft-specialties.com/
Hide Signatures
(in reply to geh3)
       Post #: 26
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/14/2013 5:22 PM
daveopam
Score: 191
Last Login: 5/24/2013
Status: offline
What sort of a hinge is used on those Ailes? There is sure not much of a gap.
David
"You only live once. But if you do it right,once is enough."Mae West
Hide Signatures
(in reply to geh3)
       Post #: 27
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/14/2013 5:27 PM
gene6029
Score: 120
Last Login: 5/25/2013
Status: offline
I have been following along & like your scale scheme. I did mine also off a full scale bird also. Havent run across another one yet...Gene
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 28
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/14/2013 6:13 PM
geh3
Score: 100
Status: offline
the ailerons have a "live" hinge typical of most of their planes
the rudder and elevators have a 4mm alu rod supported by sturdy
phenolic posts... all of this is done at the factory..quite nice
Hide Signatures
(in reply to gene6029)
       Post #: 29
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/14/2013 6:14 PM
geh3
Score: 100
Status: offline
Thanks, mine will resemble that pictured earlier in this post
the real one of these is a very good plane!!!
Hide Signatures
       Post #: 30
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/17/2013 4:45 PM
geh3
Score: 100
Status: offline
Started masking for the paint..ugh, lots to do here...
Click for fullsize
< Message edited by geh3 -- 1/17/2013 6:00 PM >
Hide Signatures
(in reply to geh3)
       Post #: 31
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/17/2013 5:39 PM
geh3
Score: 100
Status: offline
Exhaust extensions came in for the TP!
these will be tricky to install ( Dremel to the recsue!)
Click for fullsize
< Message edited by geh3 -- 1/17/2013 6:02 PM >
Hide Signatures
(in reply to geh3)
       Post #: 32
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/19/2013 12:58 PM
geh3
Score: 100
Status: offline
Primer goes on...
then wet sand..then color
lots of work but the final result is worth it...
This plane will be decorated with a combination of paint+Vinyl graphics
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 33
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/19/2013 10:21 PM
gene6029
Score: 120
Status: offline
Its alot of work, but you will definately have something different.....Gene
Hide Signatures
(in reply to geh3)
       Post #: 34
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/19/2013 10:27 PM
geh3
Score: 100
Status: offline
Yes thanks but the turbine install was not that difficult
re-engineering the LG mounts was a little tricky but I love to build!
esp in the winter..
Painting now...
Hide Signatures
       Post #: 35
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/20/2013 12:30 AM
gene6029
Score: 120
Status: offline
Hey, i hear ya about building in the winter. I'm a transplant from Pa & used to do all my building in between shoveling snow from snow storms! Down here we get snow overnite & by lunchtime its in the 50s! I still try & get at least one build in over the winter months though. ....Gene
Hide Signatures
(in reply to geh3)
       Post #: 36
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/20/2013 4:21 AM
speedracerntrixie
Score: 189
Status: offline
I'm curious why you are bothering with primer? I have painted directly on the Comp ARF white finish after a light scuff with great results. I can see using primer to fill the seams but not on a molded white surface.
Hide Signatures
(in reply to geh3)
       Post #: 37
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/20/2013 12:44 PM
geh3
Score: 100
Status: offline
Yes I could probably do that but I like following directions and the paint i'm using
suggests primer so I give it some light coats and then wet sand..you can't go wrong following the directions!!!
 THANKS   BUT  I will keep that in mind for the next time...
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 38
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/21/2013 2:45 PM
geh3
Score: 100
Status: offline
Bling being added WOW this will look OK!
The Kirby Graphics are GREAT!!!!!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 39
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/21/2013 4:02 PM
gene6029
Score: 120
Status: offline
Beautifull work!.......Gene
Hide Signatures
(in reply to geh3)
       Post #: 40
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/21/2013 4:08 PM
geh3
Score: 100
Status: offline
Thanks, the final result should be highly visible in the air..
that's what I like and it is an attempt to be scale...
< Message edited by geh3 -- 1/21/2013 4:40 PM >
Hide Signatures
       Post #: 41
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/23/2013 3:41 PM
geh3
Score: 100
Status: offline
In oder to make the 54TP function properly, I have decided to change the exhausts as shown.
This is a straight shot out of the TP so it shouldn't affect performance and it will be easy to install..
intereasting hobby this is !!!
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 42
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/23/2013 4:58 PM
geh3
Score: 100
Status: offline
I called upon my favorite surgeon Dr. DREMEL
and we consulted and then operated, preliminary installation here
I think it will be UNIQUE to say the least. Dr. Dremel says the patient will
live to fly soon (comon spring)
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 43
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/23/2013 5:22 PM
geh3
Score: 100
Status: offline
I forgot, the canopy assy is all done.
I SMOKED it...
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 44
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/23/2013 10:21 PM
gene6029
Score: 120
Status: offline
Nice work on the canopy, i like the tint......Gene
Hide Signatures
(in reply to geh3)
       Post #: 45
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/23/2013 10:50 PM
geh3
Score: 100
Status: offline
Thanks, I installed it by placing magnets all around outside and inside and then used
foam safe CA all around. Whan that cured, I put a bead of Areopoxy  on the inside.. it is nice and tight to the frame!
The tint is TAMIYA # PS-31 "smoke" and boy it gives off a lot of fumes when applying... I had to evac
my worksop for a few hours... HAH
Hide Signatures
       Post #: 46
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/30/2013 8:22 PM
geh3
Score: 100
Status: offline
More bling added..all Vinyl...
this approximates what the full sized one has as far as I coudl tell from the
AIRLINERS.NET photos...
more to come..white stripes on the bottom..
hey it WILL be very VISIBLE!!!!!
Click for fullsize
Hide Signatures
(in reply to geh3)
       Post #: 47
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/31/2013 11:00 AM
gene6029
Score: 120
Status: offline
When i was researching photo information for my SP-55m, i contacted the photographer that took the photos on airliners.net & told him what i was doing. He responded by sending me a 360 degree walk around set of photos & only asked that i send him pics of my finished model. Something to consider on future projects.......Gene
Hide Signatures
(in reply to geh3)
       Post #: 48
RE: Yak 55SP 2.6M converted to Turboprop!!! - 1/31/2013 1:40 PM
geh3
Score: 100
Status: offline
NICE, thanks
for this particular plane I wasn't so much interested in 100% scale fidelity
as I was in high visibility in most cloud conditions.. I'm not entering it in any scale events
but I just want to wring it out and have fun...SO I made it as "Russian" themed as possible
with the correct stars, YAk logos, russian text etc.... fun stuff...
Hide Signatures
       Post #: 49
RE: Yak 55SP 2.6M converted to Turboprop!!! - 2/1/2013 7:56 PM
geh3
Score: 100
Status: offline
Ok onto final assy and CG determination, in the meantime I put it together
to get some Pics! WOW it WILL be highly visible and is does look Russian like... HAH
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by geh3 -- 2/1/2013 8:23 PM >
Hide Signatures
(in reply to geh3)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
