Why isn't it called a P-105 RXi ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Why isn't it called a P-105 RXi ?
Page: [1]
Login
Why isn't it called a P-105 RXi ? - 1/6/2013 6:57 PM
highhorse
Score: 116
Last Login: 5/24/2013
Status: offline
If or puts out more power than the 100, why give it a model number that implies it makes less?
This isn't keeping me awake at night, but I'm curious. Anyone have a solid answer?
Thx,
Don.
_____________________________
RCU Rocks, I''d hate to be without it !!
Hide Signatures
       Post #: 1
RE: Why isn't it called a P-105 RXi ? - 1/6/2013 7:16 PM
Ruizmilton
Score: 100
Status: offline
I would think it's only conservative ratings to cover for variations on output for each individual engine, plus you also have variations due to altitude etc, this would have the actual output close to the rating and if possible never less than the rating . Or it could be so that JetCat buyers will not get disappointed just kidding, as far as I have seen every manufacturer does the same...
Hide Signatures
(in reply to highhorse)
       Post #: 2
RE: Why isn't it called a P-105 RXi ? - 1/6/2013 7:17 PM
Jeremy300
Score: 100
Status: offline
Nothing against Jetcat...I think they are great engines but didn't they get caught a few years ago with the 120 not producing the thrust they claimed. Maybe they are playing it safe this time and giving min thrust numbers instead of max thrust numbers like most of the other manufacturers.
Hide Signatures
       Post #: 3
RE: Why isn't it called a P-105 RXi ? - 1/6/2013 7:19 PM
jason
Score: 111
Status: offline
Same goes for the P200 which is 230N
Hide Signatures
       Post #: 4
RE: Why isn't it called a P-105 RXi ? - 1/6/2013 7:20 PM
jason
Score: 111
Status: offline
quote:
ORIGINAL: Jeremy300
can't be that as they still quote the higher figure in the specs.
Jason
Hide Signatures
(in reply to Jeremy300)
       Post #: 5
RE: Why isn't it called a P-105 RXi ? - 1/6/2013 8:34 PM
FalconWings
Score: 121
Status: offline
As far as I know, it is only a model number representative of a thrust class, not necessarily a thrust rating. Not all engines are equal.
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
(in reply to jason)
       Post #: 6
RE: Why isn't it called a P-105 RXi ? - 1/6/2013 8:38 PM
Justflying1
Score: 105
Status: offline
+1 why is donkey called a donkey and not a horse, and a horse called a donkey.  Its only a number, Only a name.   What does count is that number after the word thrust.
If you have to borrow, you cant afford it
Hide Signatures
(in reply to FalconWings)
       Post #: 7
RE: Why isn't it called a P-105 RXi ? - 1/6/2013 9:34 PM
Dave Wilshere
Score: 108
Status: online
When the turbine was first developed (in case pump and valves etc) with was going to be set under 100N. The P80SE produced way more than 80N but it was still called a P-80. The P-90RXi is much heavier than a P-100RX, so power to weight its probably a little behind...
The higher power is from the higher RPM setting over the old P-80 types. Guess a P-80SE could be set to the same thrust cranked at 130,000
Its just a number Real world with all our turbines is a different thing altogether
Dave
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to Justflying1)
       Post #: 8
RE: Why isn't it called a P-105 RXi ? - 1/6/2013 10:14 PM
TimD.
Score: 100
Status: offline
Just for understanding how thrust is measured. 100 Newtons of force equals 22 lbs thrust / 1lb. force = 4.55 newtons / 1kg. force =10.04 newtons.
Most manufactures started using this to give a designation to their engines. IE "P-80 = 17.6 lbs thrust" / "Kingtech-140 = 30.8 lbs thrust"
From Vision to Reality !!!
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 9
RE: Why isn't it called a P-105 RXi ? - 1/6/2013 11:01 PM
Justflying1
Score: 105
Status: offline
 I could be wrong, but if 1 Newton =0.224808943 to my calculation.
Than going by the calculations on what the number on the turbine is it will be this
P80 = 17.9
Kingtech 140 = 31.4 which is advertised at 31 pounds of thrust.
Correct me if I'm wrong.
Hide Signatures
(in reply to TimD.)
       Post #: 10
RE: Why isn't it called a P-105 RXi ? - 1/7/2013 1:24 AM
joeflyer
Score: 105
Status: offline
You're right.  Or the way I prefer to remenber it is 1 lb. force = 4.448 newtons.  Which means that 100 newtons = 22.5 lbs.  Also 1 kg. force = 9.807 newtons.
Hide Signatures
       Post #: 11
RE: Why isn't it called a P-105 RXi ? - 1/7/2013 1:44 AM
smchale
Score: 115
Status: online
Personally, I wouldn't get too hung up on the naming convention equalling the tested thrust output. My BF Turbines B100 puts out 127.6N according to the test certificate that accompanied the purchase. And I'm Ok with that.
Sean McHale
"Strive for simplicity. You never have to repair what you leave out." - Bill Lear
Hide Signatures
(in reply to joeflyer)
       Post #: 12
RE: Why isn't it called a P-105 RXi ? - 1/7/2013 3:38 AM
TimD.
Score: 100
Status: offline
Ok I was not exact on the #'s. Guess I should have googled it first " did not expect riddicule". I was just giving an explanation for newbie onlookers trolling through postings.
Hide Signatures
(in reply to smchale)
       Post #: 13
RE: Why isn't it called a P-105 RXi ? - 1/7/2013 3:52 AM
Justflying1
Score: 105
Status: offline
 Hello TimD,
was not trying to put you down friend.
The whole reason I jumped on and rectified it so when newbie's jump on they can get more accurate information.
I hope that some one will do the same to me if I post information which was not correct.
My apologies is you felt offended.
Ivan
Hide Signatures
(in reply to TimD.)
       Post #: 14
RE: Why isn't it called a P-105 RXi ? - 1/7/2013 3:20 PM
drdoom
Score: 130
Last Login: 5/23/2013
Status: offline
RXI refers to the Pump being installed in the front housing. Not just the valves.
AMA #70046 Jet Junkie!
Without Gravity, Your Lockout Jet becomes Space Junk.
Hide Signatures
       Post #: 15
RE: Why isn't it called a P-105 RXi ? - 1/7/2013 3:26 PM
robersteam
Score: 100
Status: offline
maybe you´re such a better pilot than me,but i can´t feel the difference from 100 to 105 on the sticks.do you? LOL.
Hide Signatures
(in reply to drdoom)
       Post #: 16
RE: Why isn't it called a P-105 RXi ? - 1/7/2013 3:30 PM
drdoom
Score: 130
Status: offline
robersteam I agree.
Hide Signatures
(in reply to robersteam)
       Post #: 17
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.562RCU1
