WrongWay RC 2500Mah A123 Rx Packs    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> WrongWay RC 2500Mah A123 Rx Packs
Page: [1] 2   next >   >>
Login
WrongWay RC 2500Mah A123 Rx Packs - 1/6/2013 7:58 PM
BarracudaHockey
Score: 280
Last Login: 5/24/2013
Status: offline
Thought I'd share this.
WrongWayRC now has 2500 Mah genuine A123 cell 2 cell reciever packs in stock and I purchased one for my 50cc MSX-R.
He wired it up to my specs with heavy duty wires and a deans plug for my reciever and a servo plug for my ignition. In addition he now has 3 wire blance charge leads that plug directly into a cell pro. Couple that with an external charge jack and now I dont even have to pull the canopy to balance charge my A123's. I like these three lead charge harnesses better because I've had the pins on the balance board on my cell pro degrade after time when running 4 amp charge rates through them.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 1
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/6/2013 8:54 PM
rmh
Score: 252
Last Login: 5/23/2013
Status: offline
Nice setup - we make our onw A123 packs -but basically th same as you show -
I won't use the regulated 7.2 Lipo tho some of the pattern guys think they are somehow preferrable to a pair of A123
Can't see how -
Libby is still watching you
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 2
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/7/2013 7:29 PM
Four Stroker
Score: 104
Last Login: 3/28/2013
Status: offline
Dick; where do you get the A123 cells ? with tabs ?
Hide Signatures
(in reply to rmh)
       Post #: 3
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/7/2013 7:59 PM
rmh
Score: 252
Status: offline
quote:
ORIGINAL: Four Stroker
I bought up a bunch of the 1100 batteries B&D sold for their little drill- which proved to be a dud in th market.
I solder to the shell or end as needed. I have a good 60 watt iron and solder /flux which makes a instant bond .
Hide Signatures
(in reply to Four Stroker)
       Post #: 4
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/16/2013 5:58 PM
kenair
Score: 100
Last Login: 5/22/2013
Status: offline
Is anyone using dual or parallel Life RX packs wires as shown by Red http://www.hangtimes.com/parallel_packs.html
Do you charge both LiFe RX packs at the same time?
thanks -ken
my sites at www.mustang51.com and www.spitfire9.com
Hide Signatures
(in reply to rmh)
       Post #: 5
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/16/2013 6:43 PM
pilotpete2
Score: 120
Status: offline
Yes, been doing it for the last 4 years with great results.
No, the common ground between the two batteries will be an issue with most chargers.
With the fast charging that A123's allow, topping off the two batteries separately hasn't been a problem for me.
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
(in reply to kenair)
       Post #: 6
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/16/2013 8:03 PM
BarracudaHockey
Score: 280
Status: offline
+1 ^^
www.JaxRC.com
Hide Signatures
(in reply to pilotpete2)
       Post #: 7
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/16/2013 9:02 PM
ROBCAR
Score: 100
Last Login: 5/15/2013
Status: offline
So Barracudahockey, Are you running a 50cc plane with only 1 2500mah battery and that one batt powers your servos and ignition? Only 2 cells for the entire plane? Are you running a battery eliminator for igniton?
Hide Signatures
       Post #: 8
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/16/2013 10:32 PM
BarracudaHockey
Score: 280
Status: offline
Yes
No
The battery has dual outputs, one goes to the reciever through a JR HD charge switch. The other goes to a switch, RC Excel ignition kill, then to a drop down diode then to the ignition.
www.JaxRC.com
Hide Signatures
(in reply to ROBCAR)
       Post #: 9
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/17/2013 12:16 AM
ROBCAR
Score: 100
Status: offline
OK, I have a 100cc yak and I plan on running 2 a123 packs through 2 jr chargeswitches and will use a tech aero battery elim for the ign. I want to be able to re-charge through the jr chargeswitches though. Similar to the diagram up a few posts. Just not sure what wiring to get on my packs. I charge with a cellpro multi 4.
Hide Signatures
       Post #: 10
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/17/2013 1:52 AM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: ROBCAR
With a 100cc size aircraft, why would you tap off one of the Rx batteries to power the Ignition. Another A123 for the Ignition is not going to add significant weight. These batteries charge so fast it should not be a big inconvenience to have to charge another battery.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 11
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/17/2013 1:57 AM
ROBCAR
Score: 100
Status: offline
You dont "tap off" one of the batteries. It plugs into a open channel on the RX and and the other end to the ignition. Lots of giant scale guys using it with very good results.
Hide Signatures
(in reply to BuschBarber)
       Post #: 12
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/17/2013 2:40 AM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: ROBCAR
You dont ''tap off'' one of the batteries. It plugs into a open channel on the RX and and the other end to the ignition. Lots of giant scale guys using it with very good results.
So the Tech Aero device draws power from the Receiver and also acts as an Electronic Kill Switch? If your receiver were to Brownout wouldn't that shut down your motor as well? Doesn't it put an extra load on your Rx batteries? I am just asking because I had not seen that product before. I have seen some use the Rx battery for both the Rx and the Ignition. In an aircraft that can handle the extra weight, I would feel safer with a separate Ignition battery and a FiberOptic Kill Switch.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 13
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/17/2013 2:56 AM
ROBCAR
Score: 100
Status: offline
Watch this video from the beggining. It probably has more info than I can give you since I am new to this product myself. This is another version of it. There a a few companies that make one. It does get assigned to a channel on your radio and can be used as a kill switch.
http://www.troybuiltmodels.com/items/WRCIBEFV2.1.html
Hide Signatures
       Post #: 14
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/17/2013 3:02 AM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: ROBCAR
Thanks!!
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 15
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/17/2013 3:45 PM
rmh
Score: 252
Status: offline
The larger SPEKTRUM/ JR rx have beefy pins and soldered lands - you can draw lots of current momentarily thru them but alas never more than 4 amps at a steady rate - the wire ends in the plastic housings melt.
so hook in the ignition wherever you like
as long as it all comes from same source - there is the same power losses seen by the rx and the same dirty information which MAY happen.
My Personal preferrence is to divorce ignition from radio - completely
makes trouble shooting much easier
I once saw a guy loose his plane because he had those old clamped caps on the spark plugs .
One got loose creating intermittant grounding and resultant high "noise" in the model
I Don't want any feedback in my systems .
Hide Signatures
       Post #: 16
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/17/2013 3:53 PM
BarracudaHockey
Score: 280
Status: offline
quote:
ORIGINAL: BuschBarber
quote:
ORIGINAL: ROBCAR
Actually my Pawnee is setup that way, and you're right, other than the convenience of only charging two batteries there's no other good reason.
Two batteries, one to the reciever, the other to the reciever and ignition.
The only reason I did it is so I would only need two batteries and two switches. Though the power safe reciever has a soft switch.
www.JaxRC.com
Hide Signatures
       Post #: 17
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/17/2013 9:59 PM
rlmcnii
Score: 100
Status: offline
ROBCAR,
Have the A123 packs wired with 3-wire JR pigtails. Use the signal wire (orange or white) as the balance wire for the pack. If the switch has a 3-wire output you must disable the signal wire (orange or white) going to the receiver so that the receiver does not get balance voltage in the signal wire. You may charge through the charge-port in the switches with an FMA connector mated to the 3-wire JR pigtail. FMA shows the wiring protocol on their website.
I have used this method very successfully with a Cell Pro charger.
There is one consideration that I do not fully grasp: That is that many switches, when open (turned off), only open the hot wire (red) and the ground remains closed. There is concern about the two separate packs sharing a common ground through the receiver. The problem with this shared common ground I do not understand.
My solution has always been to disconnect the pack that is being charged from the receiver by unplugging the switch output wire from the receiver. Perhaps such caution is totally unwarranted.
Illumination from those more knowledgeable is always welcome.
Hide Signatures
       Post #: 18
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/17/2013 11:34 PM
pilotpete2
Score: 120
Status: offline
The only issue with the common ground is in trying to charge both batteries at the same time. If you charge the batteries one at a time, no issue, and there's no need to unplug anything if you're only charging one at a time.
I've been balance charging my A123 receiver packs through the heavy duty switch/charge jack harnesses for the past four years. Y' just gotta remember to cut the signal wire in the lead from the switch to the receiver, or you'll have 3.3V going to the signal pin of the channel you're plugging into. You don't want that
I'll put in a plug for Radical here, when you order an A123 receiver pack from them, they have the option on the drop down list to have the battery built with a single 20awg servo lead with the signal wire connected to the batteries node. Perfect for those who want to balance charge through the charge jack!
Pete
Hide Signatures
(in reply to rlmcnii)
       Post #: 19
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/18/2013 1:01 AM
ROBCAR
Score: 100
Status: offline
I thought with the switch turned off power from the charger only goes to the battery being charged. Maybe I am wrong. I have a cellpro multi 4 on order and can only charge one battery at a time anyway, Right? I just need the correct harness that goes from the cellpro directly to the jr chargeswitch in the side of the fuse. I will have to look at that option Radical rc has.
Hide Signatures
       Post #: 20
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/18/2013 1:16 AM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: ROBCAR
For a normal Switch Harness, the Charge Jack is routed directly to the Rx battery when the Switch is Off. DSC compatible 3 wire Switch Harnesses have a 3rd wire going to the Rx so you can Bind a Spektrum Rx through the Charge Jack.
LiFe/A123 batteries charge through the Balance Tap, which is not connected to the Switch Harness.
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 21
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/18/2013 1:24 AM
ROBCAR
Score: 100
Status: offline
Maybe what I will do then is just use the switches for switches and not charging. I can get my packs made just the the first post of this thread and balance charge through another charge jack. The holes are already there from previous owner.
Hide Signatures
       Post #: 22
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/18/2013 2:58 AM
rlmcnii
Score: 100
Status: offline
ROBCAR,
You may charge the 123s through the port in the switch. You need three wires from the pack to the switch with the signal wire (orange or white) wired as a balance wire from the pack, The signal wire from the switch to the receiver must be cut or disabled. You must use a three-wire switch. You must obtain or make a charge cable that will mate the CellPro to a JR (or Futaba) three-wire pigtail which will fit the chargeport in the switch.
Pilotpete apparently answered my concern about a common ground through the receiver and my practice of disconnecting the output side of the switch from the receiver while charging has been not required.
http://www.usastore.revolectrix.com/Products_2/Cellpro-10s_3/Cellpro-JST-PA-Battery-Pigtail-10-5-Position is the connector required to make your own charge cable.
This: http://www.revolectrix.com/support_docs/item_1315.pdf is the wiring protocol.
Hide Signatures
       Post #: 23
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/18/2013 3:07 AM
AA5BY
Score: 153
Status: offline
Interesting discussion... can I ask a variant question? Can LiFe be regular charged a few cycles between balance charges? If so, mounting the batteries for fairly easy removal seems an option and doing the regular charging through the switch/charge. Follow up question if this is a reasonable management scheme... how many regular charges between balance charges?
Hide Signatures
       Post #: 24
RE: WrongWay RC 2500Mah A123 Rx Packs - 1/18/2013 3:41 AM
Truckracer
Score: 304
Status: online
quote:
ORIGINAL: AA5BY
I balance charge my A123 batteries about once a month and monitor the individual cells during the balance process. Rarely do I see any degree of imbalance but at least I know they are OK by going through the process.
Hide Signatures
(in reply to AA5BY)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.250RCU1
