What to do after 6 years?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> What to do after 6 years?
Page: [1] 2   next >   >>
Login
What to do after 6 years? - 1/6/2013 8:16 PM
Bocajuniors55
Score: 100
Last Login: 1/8/2013
Status: offline
 Its been 6 years since I was last in the hobby-ive forgotten a few things to say the least.  I have a .46 OS FX engine that has been sitting since 2005 in my garage. It ran perfect with low hours last time I used it.  Any steps I should take before I attempt a restart of it soon? Please use simple terminology and/or definitions as it has been a while since I was last involved.  I'm excited to be getting back in!
Hide Signatures
       Post #: 1
RE: What to do after 6 years? - 1/6/2013 8:31 PM
AMB
Score: 110
Last Login: 6/19/2013
Status: online
Take the backplate off soak in kerosene for a couple of days. that will loosen ant dried or gum on bearings then just shake out put backplate on, remove plug before doing this procedure drain and shake out kero, then put plug and backplate back and run it martin
you can also give it a good spray inside of WD 40 before putting back the back plate and plug and flip a few times
Hide Signatures
(in reply to Bocajuniors55)
       Post #: 2
RE: What to do after 6 years? - 1/6/2013 8:35 PM
Bocajuniors55
Score: 100
Status: offline
 Thanks.  Accomplish this procedure with carb installed correct?  Do I need to "brush" or agitate anything?
Hide Signatures
(in reply to AMB)
       Post #: 3
RE: What to do after 6 years? - 1/6/2013 8:43 PM
AMB
Score: 110
Status: online
If the carb barrel moves NO a squirt of WD 40 down the intake, rotate barrel, put a piece of fuel line on the fuel nipple and blow thru it to check for no clogs martin
then should be ready to go martin forgot check that glow plug lights before putting back in
Hide Signatures
       Post #: 4
RE: What to do after 6 years? - 1/6/2013 8:57 PM
1QwkSport2.5r
Score: 155
Status: online
Kerosene is petroleum based!!! Your 46FX runs on glow fuel. Use the fuel that was originally ran in the engine to remove the old oil crud. The castor and synthetic oils will not dissolve in kerosene.
If th engine turns over, at most I would disassemble the carb and soak/clean in glow fuel. Reassemble and run the engine. If the engine turns over with a gritty feel, replace the bearings before running the engine. RCBearings.com is the best place around for bearings.
Kerosene works great in model Diesel engines, but not glow engines. WD40 is bad news in a model engine for many reasons, mainly it's attraction to loosen rust which then churns through the engine.
_____________________________
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to AMB)
       Post #: 5
RE: What to do after 6 years? - 1/6/2013 9:16 PM
fiery
Score: 100
Status: offline
OS recommend kerosene as a flushing solvent for gummed up engines.
Provided is is drained out before use their is no issue.
< Message edited by fiery -- 1/6/2013 10:37 PM >
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 6
RE: What to do after 6 years? - 1/6/2013 9:20 PM
countilaw
Score: 229
Last Login: 6/18/2013
Status: offline
It's getting to the point that you can't trust any information you get in the forums.        Everything that was advised was WRONG ! ! !
10wksport gave the  correct  information.
Frank
< Message edited by countilaw -- 1/7/2013 4:53 AM >
It''s a hobby, not a job.
Hide Signatures
       Post #: 7
RE: What to do after 6 years? - 1/6/2013 9:21 PM
AMB
Score: 110
Status: online
One of my OS instruction sheets reads if engine to be stored for a long time soak in kerosene, I agree on the WD 40 loosening rust, good thing just rinse engine with glow fuel
if bearings just griity not rusty they will clean up, and yes if rusty will need to be replaced
I have several 4 strks that after last run on glow ran on model diesel fuel plug lit, took out all nitrp and alcohol thus no moisture or acid buildup
several years later no issues no bad bearings stuck valves etc, thats my procedure for 2 or 4 strk the diesel fuel is the the after run protection never any issues
That is model diesel fuel, ether,kero,castor oil not the #2 pump diesel martin
Hide Signatures
       Post #: 8
RE: What to do after 6 years? - 1/6/2013 9:30 PM
AMB
Score: 110
Status: online
Do not want to raise an issue but siding with Fiery on this one we both run diesel and glow MARTIN
Hide Signatures
(in reply to AMB)
       Post #: 9
RE: What to do after 6 years? - 1/6/2013 9:46 PM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: fiery
OS recommend kerosene as a flushing solvent for gumme dup engines.
Well, that goes to show just how intelligent their owners manual writers and/or engineers are. Use a solvent that is incompatible with the oils the engine is operated with.
Good thing I don't buy OS.
I run all glow and provided I use no synthetic oil in my fuel, I have no rust or corrosion issues. I run my engines dry and rarely use any after run treatment.
Hide Signatures
(in reply to fiery)
       Post #: 10
RE: What to do after 6 years? - 1/6/2013 9:54 PM
AMB
Score: 110
Status: online
THE LUBE IN OUR MODEL ENGINES AR THE SAME CASTOR OR CASTOR/SYN COMBINED WHETHER GLOW OR DIESEL IF CONCERNED ABOUT KERO JUST RINSE WITH GLOW FUEL
regards martin
Hide Signatures
       Post #: 11
RE: What to do after 6 years? - 1/6/2013 10:05 PM
AMB
Score: 110
Status: online
Are you running FAI formula 80% alcohol 20% castor no nitro?? martin
very common in Europe Nitro very expensive or not available n some areas
Hide Signatures
       Post #: 12
RE: What to do after 6 years? - 1/6/2013 10:28 PM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: AMB
0-5% nitro in aero engines, 20-25% nitro in car engines. The car engines are all ABC, my aero engines are iron/steel, AAC, ABN, and ringed.
Don't forget that the only reason castor and PAG synthetics mix with kerosene is the Diethyl Ether. Try mixing castor with kerosene without ether. Benol is a modified castor, which is excluded from my argument as its chemically different from normal first pressing castor.
It's my opinion that petroleum solvents be used in petroleum burning engines, and vice versa with alcohol solvents.
Hide Signatures
(in reply to AMB)
       Post #: 13
RE: What to do after 6 years? - 1/7/2013 2:12 AM  1 votes
blw
Score: 655
Status: offline
Those manual writers get things wrong all the time. How about that can of worms regarding engine break in? Wrong info in engine manuals is pretty common for most brands. (Imho)
From personal experience, filling up an engine to the glow plug hole with glow fuel works like overnight magic.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
       Post #: 14
RE: What to do after 6 years? - 1/7/2013 2:37 AM
AMB
Score: 110
Status: online
Humm dirt a""s simple sound like a game plan the manual thing sounds scary wonder if they ever tried what they wrote martin
Hide Signatures
(in reply to blw)
       Post #: 15
RE: What to do after 6 years? - 1/7/2013 2:41 AM
Warbird40
Score: 105
Last Login: 6/3/2013
Status: offline
quote:
ORIGINAL: 1QwkSport2.5r
+1
Hide Signatures
       Post #: 16
RE: What to do after 6 years? - 1/7/2013 2:52 AM
1QwkSport2.5r
Score: 155
Status: online
quote:
ORIGINAL: blw
Can't argue with that. +5.
Hide Signatures
(in reply to blw)
       Post #: 17
RE: What to do after 6 years? - 1/7/2013 4:12 AM
Leroy Gardner
Score: 117
From: Coeurd'''''''''''''''''''''''''''''''' ALENE,
Status: offline
To correct some missinformation about fuel: Nitro is an oil, you could throw a lit match in a bucket of it and all it would do is put it out. Methane is a low combustional alcohol derived from corn, not wood alcohol. Methane is the ignition of the nitro which in turn produces a slower than the alcohol explosion with alot more force. because of its burn rate it causes a longer downward burn force than alcohol alone, thats why there are different %'s in the fuel used in nitromethane engines. It is not a good idea to exceed mfg. reccomended %'s as engines are made to burn those amounts only.
I'm a ex nitromethane fuel burning dragster owner / driver and the stuff you burn in your models smell just like the stuff we burned in the dragster, we just added another kicker.
Buy the way when we cleaned up parts of the fuel systems we used laquer thinner because when blown out there was no resadue left behind.
Leroy Tiger Club # 53, TF 1/5th P-51 mustang
Eagle 2'' bashed Tiger 60
Hide Signatures
       Post #: 18
RE: What to do after 6 years? - 1/7/2013 4:28 AM
Quikturn
Score: 118
Status: offline
I've rebuilt many glow engines over the years. My personal preference would be to disassemble, clean and reassemble. The o-rings could be brittle at this point and require replacement anyways.
But for a quick cleanup, I agree with those who say to flush with glow fuel. Alcohol and compressed air would help too. I'd stay away from kerosene and WD-40.
My 2 cents.
Ultrasport Brotherhood #45
P-40 Brotherhood #35
Hide Signatures
       Post #: 19
RE: What to do after 6 years? - 1/7/2013 4:53 AM
brockettman
Score: 105
Status: offline
Bocajunior,
Welcome to the RCU forums! Is your engine seized up? If not pull the glow plug squirt a little glow fuel in the cylinder, open the carb, squirt a little glow fuel in there too. Spin the engine and make sure it turns free and smooth. Dry out the engine, put in the glow plug and fire it up.
If it's not turning over soak with glow fuel until you can turn it over, then you should probably tear it down and check bearings and bushings.
There's my nickel's worth! Welcome back!
Ben
Club SAITO Member #565
Hide Signatures
       Post #: 20
RE: What to do after 6 years? - 1/7/2013 4:57 AM
NM2K
Score: 161
Status: offline
Me, if it doesn't feel gritty when turning it over with a few drops of oil in it, I'd throw it on the engine test stand and run it. Then evaluate its condition. I'm confident that you would have a ready-to-fly engine after a few minutes of running.
It amazes me how we human beings can think of twenty ways to accomplish the same task. Just watch getting petroleum products on rubbery material that has been designed to handle alcohol. The two do not usually get along chemically.
Ed Cregger
"Practice makes prefect"
Hide Signatures
(in reply to Quikturn)
       Post #: 21
RE: What to do after 6 years? - 1/7/2013 4:59 AM
countilaw
Score: 229
Status: offline
I've seen  instructions that claim if you break in your  engine with   10% nitro,   you would always need to use  10% in the engine.     You can't always follow the   instructions   in the box.    I think it has something to do with    Japanese to English translation maybe.     I think they call it
    Japanenglish?
Frank
Hide Signatures
(in reply to brockettman)
       Post #: 22
RE: What to do after 6 years? - 1/7/2013 11:59 AM
pmerritt
Score: 172
Status: offline
quote:
ORIGINAL: AMB
You really have to be careful getting all those dried ants out also!  They can really mess up the combustion chamber if the whole colony camps out and croaks in there.
(had to do this, sorry)
Intelligence is similar to a dress code. Dont attend a black tie affair wearing cutoffs and a tank top. Know your facts
Hide Signatures
(in reply to AMB)
       Post #: 23
RE: What to do after 6 years? - 1/7/2013 1:33 PM
rgburrill
Score: 136
Status: offline
3 words: Marvel Mystery Oil.
Hide Signatures
(in reply to pmerritt)
       Post #: 24
RE: What to do after 6 years? - 1/7/2013 3:24 PM
whoopee
Score: 110
Status: offline
quote:
ORIGINAL: rgburrill
Gotta go with this one some of the best oil out there take the back plate off put some in there put some in the plug hole and a little down its throat  turn her over a couple times and rinse with a little glow fuel if your gonna start it soon after this like that day but if its gonna be a day or two just blow the marvel out with compressed air and let it go.
And as we all say just my 2 cents. Oh and remember have fun
Whoopee
Proud member luvtruck.com, isuzupup.com, ncrccrawlers.com, and rccrawler.com. Proud owner of a 1981 Chevy Luv 4x4 whoopee
Hide Signatures
(in reply to rgburrill)
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> What to do after 6 years?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.109RCU1
