Recast Tornado S30 No Longer Starts    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Recast Tornado S30 No Longer Starts
Page: [1]
Login
Recast Tornado S30 No Longer Starts - 1/6/2013 11:54 PM
sjrdr
Score: 100
Last Login: 1/13/2013
Status: offline
We broke in the new car and followed directions to the T.
It ran for a couple days no issue, and today, it no longer starts
We notice that when we prime the fuel by putting a finger over the exhaust, that the fuel no longer travels to the carb.
We pulled off the high speed needle and noticed that it has to line up perfectly. We tried every angle but no dice.
We put a little fuel in the carb directly and it fires up, then dies. I think it is not pulling fuel.
Its our first time with a RC car. Any thoughts.
Hide Signatures
       Post #: 1
RE: Recast Tornado S30 No Longer Starts - 1/7/2013 12:09 AM
Dads like rc too
Score: 540
Last Login: 6/18/2013
Status: offline
Turn your LSN out- too lean.
_____________________________
Caldera 10e : Volcano EPX : Monsoon XTR : Sumo x2 :
Hide Signatures
(in reply to sjrdr)
       Post #: 2
RE: Recast Tornado S30 No Longer Starts - 1/7/2013 12:11 AM
nitrosportsandrunner
Score: 296
Last Login: 6/19/2013
Status: offline
quote:
ORIGINAL: sjrdr
not sure what you mean when you say " high speed needle and noticed that it has to line up perfectly. We tried every angle but no dice."
but if you are having trouble screwing it in, then the threads could be damaged and there could be bits in the carb blocking fuel from getting in.
Id take the carb off the truck, fully disassble it and clean it.
SC10 brushless, Thunder Tiger Phoenix XB Brushless, 1/5 custom rock crawler, Slash 4x4, Atomik Barbwire
Hide Signatures
(in reply to sjrdr)
       Post #: 3
sjrdr
Score: 100
Status: offline
turned the LSN out two turns using 1/4 increments, but still will not start after 50+ cranks
i am guessing there is something in the carg clogging it.
never pulled it before as i'm a noob just pull that one 6mm bolt and ite carb should pop off, hopefully
Hide Signatures
(in reply to Dads like rc too)
       Post #: 4
RE: Recast Tornado S30 No Longer Starts - 1/7/2013 1:00 AM
Score: 296
Status: offline
quote:
ORIGINAL: sjrdr
on most you just have to loosen the nut and the carb can be pulled off. The throttle linkage has to come off as well.
but you must have either damage to the carb or something stuck inside it.
Hide Signatures
(in reply to sjrdr)
       Post #: 5
RE: Recast Tornado S30 No Longer Starts - 1/10/2013 4:56 AM
u4iia
Score: 100
Last Login: 1/10/2013
Status: offline
Ummm.....some other thoughts.  Did you check the fuel tank to make sure it is sealed i.e. no cracks and check the the line from the muffler to the tank for air leaks.
Hide Signatures
(in reply to sjrdr)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.203RCU1
