Aileron Twitch    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Aileron Twitch
Page: [1]
Login
Aileron Twitch - 1/7/2013 5:02 PM
Dig it
Score: 102
Last Login: 5/21/2013
Status: offline
Please see the video
https://www.youtube.com/watch?v=MRT3cV-ZtbU
I started this journey with the purchase of a used PST Panther. In good shape but needed some work. I originally had a 9303 that I was using, I've now purchased a 12X (yes it happened with both radio's). All the wiring has been replaced from the Y coming off the Rx to the servo in question and the flap servo's that seem to have something to do with the problem.
I am using brand new 2500mah, 2S, 7.4V Lipo's (2 of them) on a Smartfly regulator for power. Yes everything was freshly charged.
I don't know how to fix this.
Dale
_____________________________
Hey buddy. Thats a Kadet not an Extra 300!!!!
Hide Signatures
       Post #: 1
RE: Aileron Twitch - 1/7/2013 5:57 PM
Dr Honda
Score: 100
Last Login: 5/22/2013
Status: offline
Some digital servos don't like higher voltages. What's the output of the regulator?
Just an FYI... the elevator servos on my T-45 did the same thing. I put an inline regulator, and a toroid ring... and they stopped.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
(in reply to Dig it)
       Post #: 2
RE: Aileron Twitch - 1/7/2013 8:11 PM
basimpsn
Score: 120
Status: online
Check your TX servo monitor function to see if its coming from the radio.
It''''''''''''''''''''''''''''''''s a hobby - keep it simple
Hide Signatures
(in reply to Dr Honda)
       Post #: 3
RE: Aileron Twitch - 1/7/2013 8:12 PM
Greg Wright
Score: 102
Status: online
To me it looks and sounds as if there is a little bit of a binding issue of the control surface. As if you are trying to get to much throw out of the servo which is causing so RF noise to interfere with the receiver.
Have you tried to decrease the ATV travel a little bit to see if it goes away?
Just a thought.
Greg Wright
Not a Horizon team member/ But would love to be one!!!!!!!!!!!! BVM Jets/Jetcat
Hide Signatures
       Post #: 4
RE: Aileron Twitch - 1/7/2013 8:24 PM
Harley Condra
Score: 105
Status: offline
Dale,
You mentioned you have a "Y" harness. Could this be the problem??
2.4 radios do not like "Y" harnesses with amplifiers.
Harley Condra
BVM REP, Skymaster REP, JetCat REP
Hide Signatures
(in reply to Greg Wright)
       Post #: 5
RE: Aileron Twitch - 1/7/2013 10:47 PM
luv2flyrc
Score: 102
Status: offline
quote:
ORIGINAL: basimpsn
Yes, that's the first question that needs to be answered
mike
Hide Signatures
(in reply to basimpsn)
       Post #: 6
RE: Aileron Twitch - 1/8/2013 12:06 AM
Dig it
Score: 102
Status: offline
Well, Voltage was 5.26V on the high side.
Tx monitor was fine
Lowered the travel, no change
Removed the Y and although it gave a very slight twitch once, the problem was removed. Go figure. I guess I'll go with independent aileron channels.
Thanks much guys, much appreciated.
Dale
Hide Signatures
(in reply to luv2flyrc)
       Post #: 7
RE: Aileron Twitch - 1/8/2013 1:51 AM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: Harley Condra
Dale,
You mentioned you have a ''Y'' harness. Could this be the problem??
2.4 radios do not like ''Y'' harnesses with amplifiers.
Does not apply to all 2.4Ghz radios, but Spektrum are especially prone, admitted on their own web site.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to Harley Condra)
       Post #: 8
RE: Aileron Twitch - 1/8/2013 2:50 AM
dbsonic
Score: 100
Status: offline
This is an interesting case. Fanout load on the Y of the signal wire mainly has been a known issue in the past so I guess that's why they came up with the amplified versions. Although it sounds like newer recievers from the manufacturers have a greater drive capability but I never hear it mentioned or read just how many fanouts they can drive. The other thing is the quality of the Y and any oxidation of the plugs should they be old which can add parasitic and lower the slew rates etc. When in doubt, pitch the Y and go with decent gauge leads wherever possible.
Hide Signatures
(in reply to BaldEagel)
       Post #: 9
RE: Aileron Twitch - 1/8/2013 3:35 AM
Joe Westrich
Score: 105
Status: offline
I had a similar problem a couple years ago and the Y was the issue. I made separate channels and it was fixed.
Cincinnati Jet Club
Hide Signatures
       Post #: 10
RE: Aileron Twitch - 1/8/2013 4:36 AM
Harley Condra
Score: 105
Status: offline
quote:
ORIGINAL: BaldEagel
Dale,
Mike
He did say it was with a 9303 and a 12X.......
It is mentioned in the JR 12X manual as well.
Harley Condra
Hide Signatures
       Post #: 11
RE: Aileron Twitch - 1/8/2013 4:53 AM
Dig it
Score: 102
Status: offline
Given the interest on the topic I must state that the y was not amplified and I received the same twitch with the old existing and the newly purchased y harness. I must admit to not being as familiar with the 12x manual as I could be but it was something I have done for so long I never questioned it. This is of course why places such as RcUniverse exist.
Thanks again
Dale
Hide Signatures
       Post #: 12
RE: Aileron Twitch - 1/8/2013 7:50 AM
corndog2
Score: 100
Last Login: 1/19/2013
Status: offline
I have used Y leads (Never amplified) on almost all my planes with JR11X Zero, DSX9 and DX7 and to date I have never seen this problem so very interested in this thread
Hide Signatures
       Post #: 13
RE: Aileron Twitch - 1/8/2013 9:57 AM
Mark H
Score: 100
Last Login: 4/22/2013
Status: offline
What servo is it.?
Regards Mark H .
Hide Signatures
(in reply to corndog2)
       Post #: 14
RE: Aileron Twitch - 1/8/2013 9:58 AM
Mark H
Score: 100
Status: offline
Do both ailerons twitch, put right aileron throw in and see if it still does it, with aileron up!
Regards Mark H .
Hide Signatures
(in reply to Mark H)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.375RCU1
