Piper Cub engine question.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
1/5 Scale Don Smith's Henschel HS-129B - RTF
Seller:  Dumb Thumb
Details:   $2,750.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> Piper Cub engine question.
Page: [1] 2 3 4   next >   >>
Login
Piper Cub engine question. - 1/7/2013 11:07 PM
mniesen89
Score: 102
Last Login: 4/6/2013
Status: offline
 I just got my GP Piper Cub 81" today and am starting to think about how I'm going to mount the engine.
I bought this engine for the plane:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKF97
my question is, can I mount this inverted to where the muffler will run underneath the plane? Im worried that the muffler will be to big in the aspect that it
would look horrible as far as scale goes and also that it may be to close to the ground.
Is there a better looking aftermarket muffler that can be used?
this is my first build so I may be wrong in both cases.
< Message edited by mniesen89 -- 1/7/2013 11:28 PM >
_____________________________
Mike
Hide Signatures
       Post #: 1
RE: Piper Cub engine question. - 1/7/2013 11:31 PM
dignlivn
Score: 136
Last Login: 5/19/2013
Status: offline
Have you thought about mounting it sideways ?
Is this Cubs wing span 81 inches?
Bob
Hide Signatures
(in reply to mniesen89)
       Post #: 2
RE: Piper Cub engine question. - 1/7/2013 11:42 PM
mniesen89
Score: 102
Status: offline
You mean like this?  http://www.tjdmodels.com/black-horse-piper-cub-120-artf-p-1564.html
If so, that's what I want to do....I just hate the idea of how much the muffler sticks out or if its even possible for me to do it.
Yes, the wing is 81" total.
Mike
Hide Signatures
(in reply to dignlivn)
       Post #: 3
Warbird40
Score: 105
Last Login: 5/22/2013
Status: offline
I would have personally used a 4 stroke, but you chose a great running and reliable 2 stroke. I would mount it sideways with a pitts muffler......plus a pitts muffler would make it sound a bit more scale (at least for a 2 stroke). Good luck with it, it seems to be a nice Cub!
Best regards,
Ed
Hide Signatures
       Post #: 4
RE: Piper Cub engine question. - 1/7/2013 11:47 PM
Warbird40
Score: 105
Status: offline
That's what it would look like with the 2 stroke mounted sideways and original muffler
Hide Signatures
(in reply to Warbird40)
       Post #: 5
RE: Piper Cub engine question. - 1/7/2013 11:49 PM
mniesen89
Score: 102
Status: offline
Right, and I don't mind it so much but I still don't like the muffler hanging out like that. Call it the future scale builder in me but that muffler would keep me up at night. Do you by chance have a link to "Pitts muffler" that works for a thunder tigre?
is there any reason I should be worried about the engine being mounted sideways such as life of the engine or dependability issues?
Mike
Hide Signatures
       Post #: 6
RE: Piper Cub engine question. - 1/7/2013 11:57 PM
Warbird40
Score: 105
Status: offline
Check on GravesRc.com or Bisson, they should have them. Im also 99% sure that pitts mufflers that fit the OS FX and OS SF .46 should also fit the TT Pro .46
And NO you shouldn't be worried about engine issues mounted sideways. The most important thing on any engine weather is mounted straight or sideways is to run it dry after done flying and use afterun oil or air tool oil to keep it from rusting.
Hide Signatures
       Post #: 7
RE: Piper Cub engine question. - 1/7/2013 11:59 PM
mniesen89
Score: 102
Status: offline
Cool, thanks for the help, much appreciated.
Mike
Hide Signatures
       Post #: 8
RE: Piper Cub engine question. - 1/8/2013 12:00 AM
CCFPILOT
Score: 100
Status: offline
There are no problems with side mounted engines.  It will not effect the life of the engine at all.
If this is your first build, I would be more concerned about your first flight.  You don't say if you have flown RC before or not.  If not you should get some local help if possible.
Hide Signatures
       Post #: 9
RE: Piper Cub engine question. - 1/8/2013 12:01 AM
Warbird40
Score: 105
Status: offline
Anytime!
Hide Signatures
       Post #: 10
RE: Piper Cub engine question. - 1/8/2013 12:02 AM
Warbird40
Score: 105
Status: offline
quote:
ORIGINAL: CCFPILOT
+1
Hide Signatures
(in reply to CCFPILOT)
       Post #: 11
RE: Piper Cub engine question. - 1/8/2013 12:04 AM
mniesen89
Score: 102
Status: offline
CCF, this is my second plane( first is an alpha .40). I have been getting flight time in and won't be flying this cub without instruction either as I've heard takeoffs are different and require good rudder control.
Just like my first plane, I'll allow a more experienced pilot take it for the maiden.
Thanks for the concern.
Mike
Hide Signatures
       Post #: 12
RE: Piper Cub engine question. - 1/8/2013 12:06 AM
Warbird40
Score: 105
Status: offline
That's a great plan.
Hide Signatures
       Post #: 13
RE: Piper Cub engine question. - 1/8/2013 12:38 AM
dignlivn
Score: 136
Status: offline
quote:
ORIGINAL: mniesen89
Mike
It's great to see people still doing it the right/smart way,
enjoy your Cub.
Bob
Hide Signatures
       Post #: 14
RE: Piper Cub engine question. - 1/8/2013 12:56 AM
hugger-4641
Score: 229
Status: offline
That's definitely a good idea to let an experienced pilot do the maiden. The TT .46 pro is a great engine, I have one myself, but you may be a little dissapointed if you're expecting the same kind of power you are getting with that Alpha .40.  A wing span of 81" is quite a load for a .46 engine. The TT .46 will fly that plane with the right prop and a good pilot, but it may actually be a little under powered compared to a scale cub, and definitely won't perform as well as the Alpha.
Jerry
AMA -922698 Nomal people scare me, but not as much as I scare them...
Hide Signatures
       Post #: 15
RE: Piper Cub engine question. - 1/8/2013 12:58 AM
biam
Score: 110
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: mniesen89
Right, and I don't mind it so much but I still don't like the muffler hanging out like that. Call it the future scale builder in me but that muffler would keep me up at night. Do you by chance have a link to ''Pitts muffler'' that works for a thunder tigre?
It would keep me up at night mounting any thing other than a four stroke in a cub, just my humble opinion. I would put a .70 size four stroke mounted side ways in it if it was in my hanger, btu I agree with mounting the two stroke sideways with a pitts muffler......if you have to.
Bill.
It is always better to be under the gun, than in front of it!
Hide Signatures
       Post #: 16
RE: Piper Cub engine question. - 1/8/2013 1:05 AM
mniesen89
Score: 102
Status: offline
Thanks guys, do you really think a .46 will really be that under powered? Think I should step it up a notch?
Mike
Hide Signatures
(in reply to biam)
       Post #: 17
RE: Piper Cub engine question. - 1/8/2013 1:08 AM
dignlivn
Score: 136
Status: offline
Yes.
The 70 4 stroke suggestion is what I would do. JMO
Bob
Hide Signatures
       Post #: 18
RE: Piper Cub engine question. - 1/8/2013 1:14 AM
hugger-4641
Score: 229
Status: offline
 Like I said, it will fly the plane, but don't expect any exciting climb performance. Personally, If I was set on a two stroke for that plane, I  would have put in a .61  , to .72.  But my first choice would be a .70 to .91 four stroke, probably an .82 Saito if I had my choice and the $ to do it. But, you already have the engine, so go ahead and see if it suits you after you let someone maiden it. You can always put that TT .46 in a .40 sized plane later.
Jerry
Hide Signatures
       Post #: 19
RE: Piper Cub engine question. - 1/8/2013 1:24 AM
mniesen89
Score: 102
Status: offline
Lol, now you guys got me thinkin....I don't think I'm ready to dump the money for a four stroke but I'm really considering the thunder tiger .61 and just returning the .46.
I only chose the .46 because that's what tower hobbies recommended which obviously was not a good choice.
Mike
Hide Signatures
(in reply to hugger-4641)
       Post #: 20
RE: Piper Cub engine question. - 1/8/2013 1:31 AM
dignlivn
Score: 136
Status: offline
It's a choice, just on low end of the power suggestions.
Bob
Hide Signatures
       Post #: 21
RE: Piper Cub engine question. - 1/8/2013 1:37 AM
Warbird40
Score: 105
Status: offline
quote:
ORIGINAL: mniesen89
The .46 will fly it scale like. If you have the budget, you should invest in a 4 stroke. Magnums are good 4 strokes and affordable. It would be extra work for you to put the 2 stroke and then change it after a few flights (different throttle wire location, motor mount, etc). I have 2 Magnum 4 stroke and they have been great (a .70 or .91 would be perfect)
Hide Signatures
       Post #: 22
RE: Piper Cub engine question. - 1/8/2013 1:38 AM
josonalico
Score: 100
Last Login: 1/8/2013
Status: offline
Hide Signatures
       Post #: 23
RE: Piper Cub engine question. - 1/8/2013 1:44 AM
hugger-4641
Score: 229
Status: offline
Cutting the cowl for a different muffler placement might not be desirable, but it's not that big a deal to re-position a throttle linkage or even the servo for that matter if you decide to change engines. But I have to  agree with Warbird40  that a Magnum .70 fs would be a fine choice. I have a .91 Magnum fs in a 110" Cub and I am well pleased with it, but I think a .91 would be a little more than what's needed for that 81"  GP cub. Just my opinion of course.
Jerry
Hide Signatures
       Post #: 24
RE: Piper Cub engine question. - 1/8/2013 1:45 AM
Warbird40
Score: 105
Status: offline
If you are going to return the .46, do yourself the favor and get a 4 stroke! By the time you pay for a 61 and get a pitts muffler for it, you would end up spending the same amount you would for a Magnum .70 and the .61 will never sound the same! Usually when companies recommend a range of engines, the lower number is the minimun amount of power required to fly that model while the highest number is usually perfect for sport flying. Always buy one in the middle to the upper range of the scale.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.031RCU1
