Best Compound/Product for Exhaust Bolt Threads?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Best Compound/Product for Exhaust Bolt Threads?
Page: [1] 2   next >   >>
[Poll]
Red Loc-Tite
  30% (11)
Blue Loc-Tite
  38% (14)
Other; post name
  30% (11)
Total Votes : 36
(last vote on : 1/30/2013 9:15 PM)
(Poll will run till: -- )
Login
Best Compound/Product for Exhaust Bolt Threads? - 1/7/2013 11:47 PM
dasintex
Score: 126
Last Login: 5/25/2013
Status: offline
To Stop Exhaust Bolts on DLE55 from Vibrating Loose what is the Best Compound/Product to use on the Exhaust Bolt Threads: Blue Lock-Tite, Red Lock-tite, etc; I will be using Wire Lockable Socket Head Cap Screws, appreciate your suggestions!
_____________________________
P-40 Brotherhood #3
Spitfire Brotherhood #29
Hide Signatures
       Post #: 1
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 12:26 AM
GaryHarris
Score: 168
Last Login: 5/19/2013
Status: offline
I voted "Other". Other meaning anti seize, never seize etc. Loctite is never a good idea when used with dissimilar metals with differing thermal coefficients and the possibility of galvanic reaction. Anti seize offers a better lubrication in threaded fasteners when thermal expansion and contraction happens when steel is threaded into cast aluminum. The aluminum will expand and contract much quicker with extreme thermal changes than the steel fasteners adding an extra axial load on the threads in the aluminum not to mention the radial load between the fastener and the host.
Then there is the controversial galvanic/electrolysis argument. But Ill leave that to the Engineers. I'm just a lab tech with 30 years experience.
Sig Kadet Brotherhood #1
Ultra Sport Brotherhood #105
Hide Signatures
(in reply to dasintex)
       Post #: 2
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 12:46 AM
badger5964
Score: 110
Last Login: 5/24/2013
Status: offline
I do not have a gas engine but finding that loctite broke down in the heat and would not hold on some 0.60 glow engine mufflers, I used red silicone on the screw. It held up well and was easily removed. I use it now instead of loctite.
Scott
Hide Signatures
(in reply to GaryHarris)
       Post #: 3
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 12:56 AM
dasintex
Score: 126
Status: offline
It was suggested to use Grey Permatex RTV or the Red Permatex RTV; any opinions or experience with either of these?
P-40 Brotherhood #3
Hide Signatures
(in reply to badger5964)
       Post #: 4
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 12:57 AM  1 votes
kwblake
Score: 110
Status: offline
I am going with Gary on this.  I have also been around the block two or three times.  I am a ticketed Machinist, Tool and Die Maker, and Construction Millwright ( yea I know, I couldn't keep a job ) with 35 years experience.  I worked in an aircraft engine overhaul facility for 12 years, and although I worked as a Tool Maker there,not a  mechanic, I cannot think of an instance where both lockwire and threadlocker was used. It may have been done, I'm not 100% sure. If done correctly, the lockwire is enough.  Also, there are more kinds of Loctite than just 242, and 271.  If you go to the Loctite site, and up at the top of the homepage, you will see industrial products.  There are high temp. products available.  Loctite 242 and 271 will both cure and release with very little heat, so they will not be much use.  Of the high temp. products, I would think that 243 would be the best choice.  You don't want to use anything high strength in aluminium.  The threads will not make it.  But again I would go with what Gary said.  Lockwire and some neversieze.
Kevin
Hide Signatures
       Post #: 5
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 1:02 AM
dasintex
Score: 126
Status: offline
Interesting, I never thought to use 'Anti/Never Sieze'; does the high heat of the exhaust affect this stuff, or would the high temp RTV work the same or as good as the 'Anti/Never Sieze'?
P-40 Brotherhood #3
Hide Signatures
(in reply to kwblake)
       Post #: 6
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 1:05 AM
Gray Beard
Score: 314
Status: offline
Other, just heat is good. I run the engine up to temp by flying it then land and tighten up the bolts. That does the trick on most any type of engine. Anything that will stand up to the heat could cause a problem when you want to remove the bolts. Stripped threads are always a thrill.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 7
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 1:10 AM
GaryHarris
Score: 168
Status: offline
quote:
ORIGINAL: dasintex
Heat has no effect on anti seize in the temperature ranges were dealing with plane engines.
RTV is just rubber, silicone whatever. I don't even use it for gaskets, I'll use grease.
Hide Signatures
       Post #: 8
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 1:12 AM
GaryHarris
Score: 168
Status: offline
quote:
ORIGINAL: kwblake
Thank you.
Hide Signatures
       Post #: 9
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 1:19 AM
GaryHarris
Score: 168
Status: offline
quote:
ORIGINAL: Gray Beard
Seems like we were talking about this the other day Gene.
Always re-check your torque values after your first, and several thermal cycles when using dissimilar materials when it comes to threaded fasteners.
I gotta go though. Some dude want's to mix Nitro and Gasoline.
Hide Signatures
(in reply to Gray Beard)
       Post #: 10
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 1:20 AM
kwblake
Score: 110
Status: offline
The neverseez  will stop the bolt from "sticking" in the threaded hole.  It wil not stop the bolt from becoming loose. The regular grade is good for 1800 deg. F, while the nickel based is good to 2400 deg. F.  I kind of think you would be good with either.
The lockwire will be more than enough to stop  the bolts from coming loose, and the threads will thank-you for the neverseez.  Do some research on the lockwire though.  It should be done so that it is stopping both bolts from becoming loose.  Like anything else, there is a right, and a wrong way to do this.
Kevin
Hide Signatures
       Post #: 11
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 1:22 AM
kwblake
Score: 110
Status: offline
You are welcome Gary.
Kevin
Hide Signatures
       Post #: 12
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 1:32 AM
GaryHarris
Score: 168
Status: offline
quote:
ORIGINAL: kwblake
I like to share songs in celebration. You in?
Hide Signatures
       Post #: 13
dasintex
Score: 126
Status: offline
I've used Lock Wire Bolts and Nuts before, when I used to Race Snomobiles; seemed like the thing to use on these exhaust bolts that want to vibrate loose, just wanted to see what product/compound everyone used on the threads, from what I have read here so far, Thread Sealant/Anti Seize Products and the Lock Wire is the way to go.
P-40 Brotherhood #3
Hide Signatures
       Post #: 14
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 1:40 AM
kwblake
Score: 110
Status: offline
Gary I'm in.  Dasintex, guess you don't do much snowmobile racing in Texas.
Kevin
Hide Signatures
       Post #: 15
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 2:21 AM
Gray Beard
Score: 314
Status: offline
quote:
ORIGINAL: kwblake
The neverseez  will stop the bolt from ''sticking'' in the threaded hole.  It wil not stop the bolt from becoming loose. The regular grade is good for 1800 deg. F, while the nickel based is good to 2400 deg. F.  I kind of think you would be good with either.
I use it on every bolt when I do a engine rebuild, good stuff but I have never thought of it to keep anything tight. I was given a used bottle of it about 20 years ago from a ship fitter friend and it seems to last forever. Bet my grand kids will be using it long after I'm gone. Good stuff.
I think Gary is stuck on the same song, he has shared this one a bunch. Or maybe it's just the band?
Hide Signatures
       Post #: 16
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 2:23 AM
dasintex
Score: 126
Status: offline
Kevin;
LOL...Nope, not since I moved from Ontario to Texas in 1992, can't say I miss the Cold Winters!
P-40 Brotherhood #3
Hide Signatures
       Post #: 17
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 2:31 AM
Gray Beard
Score: 314
Status: offline
Snow??????????????
Hide Signatures
       Post #: 18
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 2:53 AM
kwblake
Score: 110
Status: offline
Snow??????????????
Yea. We do get a little here.  But only about 2 or 3 feet.  And it's a dry cold.
Kevin
Hide Signatures
       Post #: 19
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 3:06 AM
speedracerntrixie
Score: 189
Status: online
IMO if you have tried several solutions and still having the muffler bolts coming loose you may want to investigate the operating temp of your engine.
Hide Signatures
       Post #: 20
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 3:34 AM
oil_can_harry
Score: 100
Status: offline
Take the muffler holes and the bolts and wash them with plain ole gasoline. Put it back together while it is still wet. Tighten well and let it sit overnight.
Hide Signatures
(in reply to speedracerntrixie)
       Post #: 21
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 4:26 AM
Gray Beard
Score: 314
Status: offline
quote:
ORIGINAL: kwblake
Snow??????????????
We use the same line when speaking of the heat, it's a dry heat but so is fire!!
Hide Signatures
       Post #: 22
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 12:42 PM
lopflyers
Score: 140
Status: offline
High temp lock tie from the auto part. Use it once and that's it
Keep your wings level
Club Saito Member #693
Hide Signatures
       Post #: 23
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 12:44 PM
kwblake
Score: 110
Status: offline
Hey dasintex.  One thing I forgot to mention is, do not overtighten your bolts. If you torque a dry bolt and a lubricated bolt to the same torque value, the lubricated bolt will have more tension on it than the dry.
Kevin
Hide Signatures
       Post #: 24
RE: Best Compound/Product for Exhaust Bolt Threads? - 1/8/2013 12:58 PM
iflyg450
Score: 100
Last Login: 5/23/2013
Status: offline
Get drilled head bolts and lock wire them. If you are unclear of this do a web search.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.313RCU1
