Spektrum A6020 servos are humming at idle.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> JR Radio & Spektrum Radios >> Spektrum A6020 servos are humming at idle.
Page: [1]
Login
Spektrum A6020 servos are humming at idle. - 1/8/2013 12:37 AM
Kmot
Score: 168
Last Login: 6/19/2013
Status: offline
Howdy,
I have some new Spektrum A6020 servos. I have two installed in an airplane, for the elevators. I just powered them up for the first time, using a Spektrum 4-cell Rx battery. I am using a Y-harness. The servos are humming loudly when the stick is at neutral. If I move the stick slightly I can get them to quiet, but a few seconds later they hum again. I have also tried adjusting the trim.
Is it possible the Y-harness is causing this? If so, what can I do about it to cure the problem?
Is there something else I should be looking for?
Thanks!
_____________________________
~Tom~
Hide Signatures
       Post #: 1
RE: Spektrum A6020 servos are humming at idle. - 1/8/2013 12:50 AM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: Kmot
Howdy,
I have some new Spektrum A6020 servos. I have two installed in an ai. Digital servos Whinerplane, for the elevators. I just powered them up for the first time, using a Spektrum 4-cell Rx battery. I am using a Y-harness. The servos are humming loudly when the stick is at neutral. If I move the stick slightly I can get them to quiet, but a few seconds later they hum again. I have also tried adjusting the trim.
Thanks!
It is more likely the noise is due to the servos you chose then it is the receiver. Analog servos Hum, and while Digital servos Whine. YHarnesses can and do cause issues with servos. If you have to use a Y Harness, choose ones with 20-22ga wire and Gold plated connectors. If this is a foamies, and you would obviously use a smaller Guage wire.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to Kmot)
       Post #: 2
RE: Spektrum A6020 servos are humming at idle. - 1/8/2013 12:52 AM
Len Todd
Score: 100
Status: offline
Digital HV High  torque servos make a lot of noise at idle. The first time you run into that, you could swear they were just screamin'.  Just make sure your input voltages and current readings are correct and drive 'em. Current reading should be very close to zero at idle (e.g. .000 to.008 amps). Holding up the elevators takes just a little bit of current. Also, I do not run Digital servos with a Y harness. I put them in separate channels, on separate circuits and mix. Do not forget to activate the trim in the mixed channel, if you mix.
33% Extra DLE 111, DX8
33% Extra for 3D, DX8
Hide Signatures
(in reply to Kmot)
       Post #: 3
RE: Spektrum A6020 servos are humming at idle. - 1/8/2013 5:05 AM
Kmot
Score: 168
Status: offline
Man, old habits die hard! I could do that Len, and I will. Out goes the Y-harness. Thanks!
~Tom~
Hide Signatures
(in reply to Len Todd)
       Post #: 4
RE: Spektrum A6020 servos are humming at idle. - 1/8/2013 5:41 AM
BuschBarber
Score: 104
Status: offline
I would not run a 4cell (4.8v) battery with any 2.4 receiver. They are very sensitive to voltage drops. You do not want a Brownout if you can avoid it. Use a voltage regulator if you have servos that are not compatible with 6v. I run 2cell LiFe Rx batteries (6.6v). Digital servos can draw much more current than Analog servos, especially when Stalled.
I prefer Channel Mixing when using Dual Ailerons, Dual Elevators, Dual Flaps, etc. If that is not possible, I use a JR Matchbox or the Futaba Servo Syncronizer. Never use a Reversing Y Harness if you can help it.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to Kmot)
       Post #: 5
RE: Spektrum A6020 servos are humming at idle. - 1/8/2013 7:27 AM
Kmot
Score: 168
Status: offline
Thanks Rich!
The 4.8V batt was only for the purposes of testing the servos. I am in the middle of installing equipment and trying to figure out where everything will go. I currently plan on running dual 6.0V batteries in this model because it will have five digital servos and it is 1/4 scale.
~Tom~
Hide Signatures
(in reply to BuschBarber)
       Post #: 6
RE: Spektrum A6020 servos are humming at idle. - 1/8/2013 12:09 PM
BuschBarber
Score: 104
Status: offline
quote:
ORIGINAL: Kmot
Thanks Rich!
Sounds like a plan. For some servos, the Dead Band is so narrow, that it does not take much to cause them to Buzz or Whine. If the linkage is not Bound up and is moving freely, I usually do not worry about it. You can use a H9 Current Meter or a Wattmeter, between the Servo and the Rx or between the Rx and the Rx battery, and determine how much Current is being drawn. You can Stall the servo, momentarily, to see what the Worst Case Scenario is.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to Kmot)
       Post #: 7
RE: Spektrum A6020 servos are humming at idle. - 1/8/2013 2:46 PM
BarracudaHockey
Score: 280
Last Login: 6/18/2013
Status: offline
Those are made my Savox and even other digital servos call Savox servos noisy, its no big deal, its just them finding center while holding the weight of the elevators.
Tell us more about what you're doing, what airplane, radio etc.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
       Post #: 8
RE: Spektrum A6020 servos are humming at idle. - 1/8/2013 4:40 PM
Kmot
Score: 168
Status: offline
http://www.rcuniverse.com/forum/m_11293390/tm.htm
I have a DX7s radio system. There is nothing attached to the servos yet. I just plugged them in (with y-harness) to see if they worked or not.
I am thinking about using this switch:
http://www.horizonhobby.com/products/dual-i-o-3-wire-switch-harness-SPM9531
And a pair of NiMh Rx packs.
~Tom~
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 9
RE: Spektrum A6020 servos are humming at idle. - 1/9/2013 12:47 AM
Kmot
Score: 168
Status: offline
Hey guys,
I just finished pulling the servos out of the plane and removing the Y-harness. I then tested each servo individually, and they did not hum.
Going through the manual, I learned the DX7s (new to me) has a "Tail Type" just like a Wing Type my DX7 had. So I figured out where to connect both servos and cycled them for a while. All good. Once they find center, the calm down and don't hum.
So thanks again for the heads up about the Y-harness!
~Tom~
Hide Signatures
(in reply to Kmot)
       Post #: 10
RE: Spektrum A6020 servos are humming at idle. - 1/9/2013 5:19 AM
Kmot
Score: 168
Status: offline
quote:
ORIGINAL: Kmot
I have come across an issue. I do not think I will have two ports on my Rx available for dual battery input, with all the other stuff I have planned.
So I have been snooping around, and came across a company called 'Smart Fly'. They have uber cool electronics stuff for large planes, much more than I would need. But I saw something very interesting, and might be just what I need. It is called "Batshare" and it allows two individual batteries and switches on the input side with only one output to the Rx. Might be the answer to my problem!
https://www.smart-fly.com/Products/BatShare/batshare.htm
~Tom~
Hide Signatures
(in reply to Kmot)
       Post #: 11
RE: Spektrum A6020 servos are humming at idle. - 1/9/2013 5:59 AM
rcflyn4fun
Score: 100
Last Login: 1/9/2013
Status: offline
Hey Tom,
Give a look to these and see what you think. I think this is exactly what you're looking for. This eliminates the switch and the BattShare and is an all inclusive setup. I have one of these and have dealt with Mike and Kurt and have found that you will be hard pressed to find any other company out there to provide a customer service as good as theirs. Just give them a call and tell them what you have for batteries so they know what connectors to put on them and tell them you only need a single output and it is all done. Problem solved!!! They are a little pricey but they are a magnificent piece of equipment and the support you'll recieve is part of the price as well. I don't want to take away anything from Smart-Fly, they have great products and great customer support as well. I use a Smart-Fly PE and Fromeco Wolverine switch and 6030 servos in my DPM Extra 330L.
http://www.fromeco.org/Products/04FRCWO-430s/
Mike
I wish I may, I wish I might, I wish for today a beautiful flight!!!
Hide Signatures
(in reply to Kmot)
       Post #: 12
RE: Spektrum A6020 servos are humming at idle. - 1/9/2013 8:15 AM
Aerocal
Score: 105
Status: offline
As you move to larger models you most definitely dont want to rely on one servo type connector to carry all the current no matter how large the lead is.If you dont have open ports on the Rx you can Y them in with a servo and supply power that way. The servo type connector is the weakest link in a power supply system.You need more than one if you expect to use more than 3 amps/5amps max.If your using more current 2 may not be enough.You may need some kind of power bus arrangement.
Using the water analogy its kind of pointless to have a huge tank and multiple inch plus hoses going to the destination and then necking them all into a drinking straw and then scratching your head because you cant figure out why you can pee faster than the water will come through.The servo type connector is the drinking straw.Electrically it is resistance.
Hide Signatures
(in reply to Kmot)
       Post #: 13
RE: Spektrum A6020 servos are humming at idle. - 1/9/2013 1:09 PM
Len Todd
Score: 100
Status: offline
I just went thru this jump to giant scale this year.  looked at Smartfly's, Futaba's and Spektrum's solutions to giant scale planes. For receivers/power distribution systems, I chose Spektrum's AR9210s. I have a couple of them. They have 3 redundant receivers that can pe positioned differently to best capture the transmitter's signal as the plane turns and inverts, etc. They also will use one or two batteries, will pick the best battery, and will isolate a bad battery. They have 9 channels and also already split out some of the commonly used ports(e.g. Aileron, etc..) They have built in 6 Volt regulators and will runoff 2S lipos. They accept Spektrum's telemetry which is quite expansive and their receivers log the flight data which simultanionsly shows up on the transmitter. Flight data allows you to see realtime if one of the receivers is not positioned at optimum, or if you are flying too far away, etc. There are other solutions out there. But this is the one I chose because none of the others offered all of the above.
I do however run Smartfly's Equalizer IIs on the ailerons because I have two servos on each aileron. An Equalizer II would also run your two elevator servos off one channel. It is kind of like a Y.  But it allows onboard adjustments and reversing etc. so that you can pair the servos up off one channel. An Equalizer II could get you back to only using one port for the elevators. However, then the trimming of each elevatior would best be done at the linkage or the Equalizer, which is a bit more of a pain. But, if you do not have the ports to run the second elevator half off a mix, then you go to do what you got to do.
Also, once you tie those servos to a horizontal control surface, they may buzz a bit. They have to hold up the surface's weight, so they are working a bit. Sometimes you can flip the stick a bit and they will quiet down. But, the buzz is normal. The bigger you go with the plane, the louder they may buzz.
< Message edited by Len Todd -- 1/10/2013 3:07 AM >
Hide Signatures
(in reply to Aerocal)
       Post #: 14
RE: Spektrum A6020 servos are humming at idle. - 1/9/2013 5:23 PM
Kmot
Score: 168
Status: offline
Hey guys, thanks for all this info!!
The plane I am putting together is a 28% Fly Baby. I have read it is basically a Piper Cub with the wing on the bottom.
I will not be doing 3D, or anything strenuous with it. I just want to fly it in a prototypical fashion, and be able to use my ASP radial engine. All this is new to me, about using double batteries or redundant systems because of digital servos and long servo leads.
I am also on a fairly tight budget, being on a fixed pension check. So I look for solutions, that are also inexpensive.
In my researching, I came across a device that is built in China. It allows use of two batteries, even LiPo. It also has a UBEC, and the output voltage to the servos can be adjusted. However, the servo plugs are still just 'servo plugs'. If a typical Rx plug is the bottleneck, I don't know how you get around that? Or is it just a worry at the battery end of things?
Here is the device I was looking at:
http://en.rccskj.com/products/Aircraft%20Accessories/77.php
~Tom~
Hide Signatures
       Post #: 15
RE: Spektrum A6020 servos are humming at idle. - 1/9/2013 9:33 PM
Kmot
Score: 168
Status: offline
quote:
ORIGINAL: rcflyn4fun
Hey Tom,
Mike
Hi Mike,
I checked out all the Fromeco products. Very cool stuff!
Thanks!
~Tom~
Hide Signatures
(in reply to rcflyn4fun)
       Post #: 16
RE: Spektrum A6020 servos are humming at idle. - 1/30/2013 8:57 PM
chuckk2
Score: 106
Status: offline
Servos, particularly digitals, introduce noise on the receiver power buss.  That can be enough to cause servo buzzing,
You might try adding some capacitors and see if that helps.    Some of the RX NiCads have internal resistance that limits
current "spikes", and causes the output voltage to droop.
Hide Signatures
(in reply to Kmot)
       Post #: 17
RE: Spektrum A6020 servos are humming at idle. - 1/30/2013 10:38 PM
Len Todd
Score: 100
Status: offline
quote:
ORIGINAL: chuckk2
Seems like you are talking about two different conditions. 1.) using caps to filter off the "RF noise" the servos may introduce in certain situations and 2.) using caps to compensate for using too small of a battery, defective battery, or running the battery too low.
For 1.) The servo buzzing described above is audible noise (versus stray RF). Audible noise is what the OP was inquiring about. Just because you have servo's buzzing a bit, does not mean you have stray currents on the servo line. If you take an O-scope and check it out you will be hard pressed to find that stray current you are thinking about. I did it to mine when they were buzzing with a 400 Mhz scope and all that showed up was the current that was consumed moving the servos and the current consumed to hold up large control surfaces (e.g. Ailerons on a Giant, .etc.) I have seen a range of .002 to .008 Amps used to hold up an aileron. Again, he was not talking about stray RF and buzzing does not mean there is stray RF.
For 2.) If you need caps to hold up your voltage to operational levels, your power supply, connections and or distribution bus may be inadequate. Or you could have a servo about to fail. What I have seen is people trying to use large (HV or high torque) servos directly on a receiver buss. When you get to the point of using HV/High torque servos you need a power distribution system versus connecting the servos directly to the Rxer. With a power distribution system, the Rxer provides input to the power distribution system and the distribution system feeds the servos accordingly. This ensures all the power that is needed for the servo to function is delivered. This arrangement also provides buffering between the servo circuit and the Rxer buss. This buffering also precludes stray  RF signals from getting back down into the receiver.
If you are Hell bent on not using a power distribution system and still need some added buffering, then a short term solution to stray RF on the Rxer may be a RF Choke made from a torroid with the offending servo wire wrapped inside and around it. The material of the core and the number of turns thru it decides the RF Frequency that will be ”choked.”  But that is only a possible short term solution. Something is wrong if you are getting stray RF into the Rxer. Long term, one needs to fix the source of the problem versus trying a bandaide to divert it. If the servos are high voltage/high torque and you are getting RF into the RXer from a servo, the problem most-likely is the RXer bus may NOT be able to consistently handle the current needed. If you are seeing voltage drops on the servo, one may think they need to add caps. The real answer is to look at the total current you are using and get a distribution system that meets the planes needs. Adding caps to keep the voltage up is another bandaide. The real problem needs to be IDed and fixed or sooner or later, the caps will not be able to cover for the real problem, as it gets worse, and the plane/heli crashes. Been there! Done that!
When figuring total current used,  Digital Servos can use current all at the same time (e.g. if you have 9 servos and each can use 1 amp, then you could conceivably have an occasional 9 amp draw.) Analog servos are only addressed one at a time. Consequently the draw for Analog Servos is only whatever you highest current using servo uses. That is one of more important reasons for using a power distribution system versus trying to feed Digital HV servos directly off the Rxer.
Hide Signatures
(in reply to chuckk2)
       Post #: 18
RE: Spektrum A6020 servos are humming at idle. - 2/1/2013 4:11 AM
chuckk2
Score: 106
Status: offline
It's not "stray current" exactly. Digital servos can each draw (very short term) more than one amp. If there is not enough capacity in the servo to limit the current spike, it can go all the way back to the receiver power buss.  Since the ground side also carries the return current, It's possible that the voltage relationship between the ground and a servo signal lead might change during the current pulse.  A digital servo can buzz for more than one reason, and the first thing to assume is that something external to the servo is the cause. But, if the servo's deadband is too narrow, it just might buzz anyway, from internal or external noise.
Besides the battery pack and it's output voltage behavior under load, the various leads and connections can also add to the problems.
For instance, "Y"ing two digital servos doesn't work well with some servos. You are correct in that an O'scope can be quite useful in determining what is going on.
Decades ago, I spent many hours in engineering development labs with o'scopes and transient analysis.  If that wasn't enough, a sort of sideline when I ran out of other things to do, was overhaul, repair, and calibration of real time and sampling scopes. Anything from the old Huges Memoscopes to Tektronix storage scopes. One of the more interesting scopes was a Lecroy/Nicolet digital storage sampling scope. It had the ability to record a transient event before it actually happened.  When the event actually occurred, the first half of the scopes memory had a time interval recorded before the event caused the scope's triggering, and the second half of memory was enabled to record after the event.
Chasing down nanosecond transients wasn't any fun!
Hide Signatures
       Post #: 19
RE: Spektrum A6020 servos are humming at idle. - 2/11/2013 5:41 AM
Len Todd
Score: 100
Status: offline
I have been froggin' around with my two Giants' Hitec servos. After doing a lot of reading, I began to wonder if I could quiet down my servos by increasing the deadband width a bit. According to what is out there to read, if you have the linkages correct and the control surfaces are free there should not be much buzzing going on. The more weight of the control surface, the more buzzing. But, for a normal application the buzzing is minimal. At idle, the normal buzzing is caused by the weight of the control surface. However, if you have the deadband set too tight, the servo could be "hunting" for the correct position and this causes needless wear on the servo, current use, and more buzzing. So,...
I picked hp a Hitec programmer and took a look at the deadband setting. It was as tight as you could get it (i.e. 1). I moved the setting from a 1 to a 4 and the buzzing in the servo stopped. I cannot notice any difference in control surfaces' responses. Occasionally, one of the elevator servos still buzzes, but a quick flip of the stick and the buzz is gone. Also, I can not detect any increase in the control surfaces' freeplay.
My conclusion is that the buzzing at idle can be reduced to nothing or almost nothing by increasing the deadband width a bit. The buzz is still there when moving the control surface, but for the most part it is totally gone at idle. According to the writings out there, this increased deadband setting may also reduce the wear and tear on the servo. Now  once thiesnow melts up here, well see if I can live with a DeadBand Width of 4.
Anyone else froggin' around with this?
Hide Signatures
       Post #: 20
RE: Spektrum A6020 servos are humming at idle. - 2/11/2013 5:57 AM
Kmot
Score: 168
Status: offline
I don't have a way to program my Spektrum servos. I have discovered though, that if I jiggle the sticks a bit the humming will stop.
~Tom~
Hide Signatures
       Post #: 21
RE: Spektrum A6020 servos are humming at idle. - 2/25/2013 9:50 AM
chuckk2
Score: 106
Status: offline
quote:
ORIGINAL: Kmot
Noisy Pots, noise on the servo leads, or narrow dead band?
One or three seems more likely. Running the servos on a servo tester for a bit might help.
Hide Signatures
(in reply to Kmot)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
