RE: How do you power your war birds?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: How do you power your war birds?
Page: <<   < prev  1 [2]
[Poll]
4 Cell Nicad for ignition and 5cell nicad for servos/reciver
  23% (25)
5cell Nicad with regulator to power opto kill switch for ignition
  3% (4)
6.6 Life with 4cell for ignition
  16% (17)
6.6 Life with regulator for ignition
  13% (14)
Other
  43% (46)
Total Votes : 106
(last vote on : 1/22/2013 8:33 AM)
(Poll will run till: -- )
Login
RE: How do you power your war birds? - 1/9/2013 3:31 PM
oliveDrab
Score: 105
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: ARUP
... with fuel powered engines! Electric motors are for servo tabs and such.
Well.........I won't get into the old "fuel vs. electric motor" debate......... but I will say the electric motors that spin my props are more reliable and more powerful than the equivalent fuel motors.
Servo tabs? Huh? Those are for full scale airplanes.
_____________________________
"Gentlemen please! There''''s to be no fighting in the war room!" - from Dr. Strangelove
Hide Signatures
(in reply to ARUP)
       Post #: 26
RE: How do you power your war birds? - 1/9/2013 5:34 PM
Spridal
Score: 100
Last Login: 5/20/2013
Status: offline
I run a single 3200 MH Life with the Aero-Tech IBEC and one switch.
Hide Signatures
(in reply to oliveDrab)
       Post #: 27
RE: How do you power your war birds? - 1/9/2013 6:32 PM
Termites Dream
Score: 100
Status: offline
quote:
ORIGINAL: wphilb
I have used several of the standard sized Hitec servos with 6.6v LiFe should be fine there, not sure about the smaller sizes, might want to test an old one? Or call Hitec.
Whit
Whit, I did call hitec and they said it was fine to run 6.6V LiFE batteries unregulated. I told them servos range from 5645 and 645 down to HS 55 sub micros. Even the submicros are OK.
"The early bird may get the worm, but the second mouse gets the cheese". David
Hide Signatures
(in reply to wphilb)
       Post #: 28
RE: How do you power your war birds? - 1/9/2013 6:53 PM
dadragon
Score: 112
Last Login: 3/14/2013
Status: offline
6v 2700mah receiver only, run mag engines only one less electrical problem to have plus need the extra weight on warbirds.
Hide Signatures
(in reply to Termites Dream)
       Post #: 29
RE: How do you power your war birds? - 1/9/2013 7:03 PM
s3nfo
Score: 120
Last Login: 5/21/2013
Status: offline
Old school, 4 cell NICAD/NMIH on ignition and 2 4 cell NICAD/NIMH on Rx via batshare. Worked 20 years ago, continues to work today.
Jerry Neuberger
L1324, HoF, LM, CD, Turbine sign-off CD, LMAI
Hide Signatures
(in reply to dadragon)
       Post #: 30
RE: How do you power your war birds? - 1/9/2013 9:17 PM
mikes68charger
Score: 106
Status: offline
 I lost my top Flight Gaint p51 to the stock 4cell nicad that came with my DX8
I should of seem the signs. I put the TX on the charger over night as I was going to a big show.
While I was trying to start my P51 DX8 low voltage warring went off. I've never seen this before so I halled my bird back to the Pitts and put the tx pack on my charger at 1.5 amps
10min later my charger said it was done and only put in 200mah
Put it all back together after flying gor 5 min while doing a high speed low las my landing gear dropped and motor shut off. After it chess he'd right in front of me I look at my DX8 and it was off. Pulled the pack out the back and 1 of the batteries had melted the plastic covering
Hide Signatures
(in reply to ARUP)
       Post #: 31
RE: How do you power your war birds? - 1/9/2013 11:51 PM
wphilb
Score: 105
Status: offline
Glad to hear it, not surprised, they are generally good servos.
Whit
quote:
ORIGINAL: Termites Dream
quote:
ORIGINAL: wphilb
Whit
Hide Signatures
       Post #: 32
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
