Fiberglass Phoenix 7    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Pattern Universe - RC Pattern Flying >> Classic RC Pattern Flying >> Fiberglass Phoenix 7
Page: [1]
Login
Fiberglass Phoenix 7 - 1/8/2013 9:24 PM
hutchinstuff
Score: 100
Last Login: 4/19/2013
Status: online
 On the other site, members told me this is a Phoenix 7 with anhedral horizontal.
It will be my first pattern bird, but the air up/down retracts are already installed.
I would like to get some more information on it, manual/tips/tricks etc...
thanks in advance.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: Fiberglass Phoenix 7 - 1/8/2013 10:10 PM
impalas
Score: 100
Last Login: 4/25/2013
Status: offline
Hanger 9 is producing an arf called the Pheonix 8, a direct reproduction of Don Lowe's original. If you go to their site you can copy off their manual. But, without that, they give you alot of specs on the planesuch as throws and C.G. I flew one in the 70s with kraft retracts. They were a great airframe. The photo you show definitely looks like a Pheonix. The nose wheel takes a beating off of grass fields. Hope the hanger 9 manual helps you out. Impalas
Hide Signatures
(in reply to hutchinstuff)
       Post #: 2
RE: Fiberglass Phoenix 7 - 1/8/2013 10:16 PM
PatternPilot
Score: 125
Last Login: 5/25/2013
Status: offline
Horizon / Hanger 9 is producing the Phoenix 7 ARF...
s.
_____________________________
Scott Anderson - CPA #2 - www.ClassicPatternAssociation.com - Team Airtronics SD10G - NSRCA 529 - VRCS 236
Hide Signatures
(in reply to impalas)
       Post #: 3
RE: Fiberglass Phoenix 7 - 1/9/2013 2:27 PM
MMcConville
Score: 100
Last Login: 5/24/2013
Status: offline
Yes that does look like a Phoenix 7 with anhedral in the stab. Likely built from the Airborne Associates kit. Same fuselage that Done Lowe gave me that was used to start the Hangar 9 ARF Phoenix 7 (not Phoenix 8 BTW).
Mike McConville
Horizon Hobby
Hide Signatures
(in reply to PatternPilot)
       Post #: 4
RE: Fiberglass Phoenix 7 - 1/9/2013 5:41 PM
hutchinstuff
Score: 100
Status: online
quote:
ORIGINAL: MMcConville
Mike, I assume the pushrods from the 7 ARF would work with this kit then?  $12 seems better than trying to make up my own elevator pushrod setup.  If there is anyway a guy could get a servo bay from Hangar 9, that would be great too!   But I can always make my own with the scroll....
Hide Signatures
(in reply to MMcConville)
       Post #: 5
RE: Fiberglass Phoenix 7 - 1/9/2013 5:48 PM
MMcConville
Score: 100
Status: offline
They could be made to work. You'll need to be sure pushrod exits and the servo tray are in the same location, and also add support the the rudder pushrod guide tube. That method wasnt typically done in the day, but works well.....slop free.
Unfortunately the servo tray isnt available seperately. Its built into the fuse. Should be easy enough to cut one out.
Mike McConville
Horizon Hobby
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
