RE: OK, what's the deal with Rx switches?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> RE: OK, what's the deal with Rx switches?
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: OK, what's the deal with Rx switches? - 1/13/2013 5:19 PM
ZAGNUT
Score: 111
Last Login: 5/25/2013
Status: offline
decent switches can be had at digikey for less than a dollar and the really good ones can cost 2-3 dollars....only problem is you have to solder them up into a harness by yourself, something it seems most aren't willing to do.
_____________________________
"I'll take the money- and you can have the rope"
Hide Signatures
(in reply to sidgates)
       Post #: 26
RE: OK, what's the deal with Rx switches? - 1/13/2013 5:43 PM
Kmot
Score: 168
Status: offline
What I get from all the responses is that the standard 3-wire switch included in complete radio systems for decades, are prone to failure and not to be trusted.
In order to be more self assured, a stout industrial quality switch should be substituted and wired into place using the Rx plug.
The last option is to not use a switch at all, and plug in the Rx battery when ready to go fly.
Thanks everyone, for your thoughts and comments.
~Tom~
Hide Signatures
(in reply to ZAGNUT)
       Post #: 27
RE: OK, what's the deal with Rx switches? - 1/13/2013 11:57 PM
vicman
Score: 189
Status: offline
Wow! It's Zagnut! Haven't seen you in a while brother Is you kid old enough to shave yet?
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
(in reply to Kmot)
       Post #: 28
RE: OK, what's the deal with Rx switches? - 1/14/2013 12:08 AM
ZAGNUT
Score: 111
Status: offline
no shaving yet...we have to get past the 1st grade fart jokes first
and he's got two sisters to beat on now[>:]
Hide Signatures
(in reply to vicman)
       Post #: 29
RE: OK, what's the deal with Rx switches? - 1/14/2013 12:18 AM
vicman
Score: 189
Status: offline
Those jokes make that age the best part of parenthood.
I see you have been a little busy with other nocturnal activities keeping you away from RCU
Hide Signatures
       Post #: 30
RE: OK, what's the deal with Rx switches? - 1/14/2013 1:15 AM
mattokeol
Score: 100
Last Login: 1/14/2013
Status: offline
Switches have always been a problem in RC.
Hide Signatures
       Post #: 31
RE: OK, what's the deal with Rx switches? - 1/19/2013 8:20 PM
JL1
Score: 106
Last Login: 5/24/2013
Status: offline
I have used these for several years without a failure
http://www.qualityrcproducts.com/products_switches.html
Hide Signatures
(in reply to mattokeol)
       Post #: 32
RE: OK, what's the deal with Rx switches? - 1/21/2013 1:05 PM
AA5BY
Score: 153
Status: offline
Yep... switches have always been a source of failures and concern and hence why redundancy is the choice for most giant aircraft.
One scheme used many years ago was phono jacks and plugs wired so that inserting the plug disconnected the battery.
Hide Signatures
(in reply to JL1)
       Post #: 33
RE: OK, what's the deal with Rx switches? - 1/21/2013 1:11 PM
JL1
Score: 106
Status: offline
FWIW, I would not trust a Phone jack for this application. They have a small contact area and are not meant for high current applications.
Hide Signatures
(in reply to AA5BY)
       Post #: 34
RE: OK, what's the deal with Rx switches? - 1/21/2013 4:23 PM
pilotpete2
Score: 120
Status: offline
I have used the 1/8" phone jacks as an on/off switch only once. It was on an .049 powered hand launch sailplane. The big red tag hanging from the phone jack hopefully would keep you from launching without powering up the radio . That was in another Galaxy and long, long ago I hate to tell you how many guys in our club tossed their .049 powered sailplane, only to realize "I ain't got it"
Pete
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
(in reply to AA5BY)
       Post #: 35
RE: OK, what's the deal with Rx switches? - 1/22/2013 1:59 AM
Mikecam
Score: 120
Last Login: 5/18/2013
Status: offline
Electro Dynamics switch, the original all others have been copied from.
http://www.electrodynam.com/rc/usw/index.shtml
See what the difference is. http://www.electrodynam.com/rc/usw/compare.shtml
Hide Signatures
(in reply to pilotpete2)
       Post #: 36
RE: OK, what's the deal with Rx switches? - 1/22/2013 4:36 PM
Four Stroker
Score: 104
Last Login: 3/28/2013
Status: offline
Some people are suckers to marketing.
Hide Signatures
(in reply to Mikecam)
       Post #: 37
RE: OK, what's the deal with Rx switches? - 1/22/2013 5:11 PM
pilotpete2
Score: 120
Status: offline
Exactly what I'm using these days
I only wish they had an LED indicator built right into the switch plate to indicate when power is on.
FWIW, I did have a solder joint failure in one of MPI's similar switches some years ago, almost lost my 4 Star 60, luckily it was intermittent and I was able to land safely.
Pete
Hide Signatures
       Post #: 38
RE: OK, what's the deal with Rx switches? - 1/23/2013 3:25 PM
Four Stroker
Score: 104
Status: offline
A good switch should have:
1) knife action
2) redundancy - at least 2PDT
3) soldering by orphans that are not on meth
Often overlooked are the crimps on the connectors.
I have not found the aftermarket stuff to be any better than JR or Futaba.
Hide Signatures
       Post #: 39
RE: OK, what's the deal with Rx switches? - 1/23/2013 4:07 PM
flyallday
Score: 115
Status: offline
Don't see it mentioned here but the Powersafe RX's have a fail - on switch.
Harry
Hide Signatures
(in reply to Four Stroker)
       Post #: 40
RE: OK, what's the deal with Rx switches? - 1/23/2013 7:06 PM
Kmot
Score: 168
Status: offline
For $300 bucks it better do something!!
~Tom~
Hide Signatures
(in reply to flyallday)
       Post #: 41
RE: OK, what's the deal with Rx switches? - 1/23/2013 7:34 PM
pilotpete2
Score: 120
Status: offline
Sure, with the Powersafe receivers you add the extra complexity of the solid state switching in the receiver, and while more uncommon, a switch harness can possibly short closed. For my money, I'll take two switches, such as the ones from Electro Dynamics in parallel, to a solid state logic switch in the receiver, or one of the popular add-on's that are available (I don't like the parasitic battery drain bit). The failure rate of one of the simple switches such as the ED ones is very low, put two in parallel and the odds of loosing power gets really low. I like simple
Pete
Hide Signatures
       Post #: 42
RE: OK, what's the deal with Rx switches? - 1/23/2013 7:42 PM
baronbrian
Score: 105
Status: offline
I have used the JR gold switches for the better part of 20 years exclusively without incident on lots of planes from .60 to 1.80 size, fast charging, and high power servos. The extra six or seven dollars is worth it and I always replace a switch after a bad crash. If someday I ever switched radio brands, I would stick with this switch no matter what.
Contest Director for the AMA
Grand Forks, North Dakota- Where time stands still but the air is always moving.
Hide Signatures
(in reply to Kmot)
       Post #: 43
RE: OK, what's the deal with Rx switches? - 1/23/2013 8:18 PM
flyallday
Score: 115
Status: offline
quote:
ORIGINAL: Kmot
I payed $230 from my LHS for the AR12120 and just got another for FREE with a DX18QQ - oh wait - guess that wasn't free after all
Harry
BTW, have not heard of one failing closed..
Hide Signatures
(in reply to Kmot)
       Post #: 44
RE: OK, what's the deal with Rx switches? - 1/24/2013 3:12 PM
MX240
Score: 115
Status: offline
quote:
ORIGINAL: Four Stroker
The Noble switch also had a very strong detent ball. The Futaba Heavy Duty switch is knife action DPDT wired in parallel. The detent is a stupid spring thing.
I agree, When I get a new Futaba product their poor quality switch gets thrown in the trash and replaced with a good JR heavy duty switch.
Hide Signatures
       Post #: 45
RE: OK, what's the deal with Rx switches? - 1/24/2013 5:56 PM
Kmot
Score: 168
Status: offline
quote:
ORIGINAL: flyallday
DX18QQ
Harry you kill me!
~Tom~
Hide Signatures
       Post #: 46
RE: OK, what's the deal with Rx switches? - 1/24/2013 11:59 PM
baronbrian
Score: 105
Status: offline
As a side note, I always mount switches inside the model as to prevent dirt, dust, exhaust residue and moisture from entering the mechanism and fowling the contacts. Personally, I would not turn a plane on and off by plugging in a external lead as in the picture of the quickie plane seen earlier in this thread because of how easy the contacts could become dirty and cause a poor connection. I now always use a pushrod with the pull on/push off convention to activate the switch. Using the same method in every model prevents accidents and confusion. In the few planes that I have had with a switch mounted in the fuse side, I always make sure the switch is mounted so that moving it towards the tail, not the nose, turns the plane on, thus preventing accidental switching off in flight due to the "bug strike theroy" Lastly, anytime a switch is involved in a crash and I suspect that the leads or connectors have been put in any type of strain, I throw away the switch and replace it. I don't make it my job to evaluate wires, connectors, or solder joints that have been subject to a hard hit or shock. I am not a expert in this and i don't take chances. Taking care of your equipment is the biggest part of reliability.
Hide Signatures
(in reply to Kmot)
       Post #: 47
RE: OK, what's the deal with Rx switches? - 1/27/2013 10:10 PM
Kmot
Score: 168
Status: offline
A push-pull rod is how I normally operate my Rx switch also, which is mounted inside the fuselage. And I routinely install toggle switches for on-board glow. I suppose I could do the same for the Rx switch.
Click to see fullsize image.
Click for fullsize
~Tom~
Hide Signatures
(in reply to baronbrian)
       Post #: 48
RE: OK, what's the deal with Rx switches? - 1/27/2013 10:21 PM
BuschBarber
Score: 104
Status: offline
I have used JR and MPI Switch Harnesses with the molded in charge Jack that has a door on it. I have never had one fail, they can be used to Bind a Spektrum Rx, and the door keeps the dirt out of the charge jack.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to Kmot)
       Post #: 49
RE: OK, what's the deal with Rx switches? - 1/28/2013 6:46 AM
4*60
Score: 111
Status: offline
Guys...go to rctimer.  Look at the switches with charge jack and led.  They work.  Look at the price.
"Of course, that''''s just my opinion. I could be wrong." the other Dennis Miller
Hide Signatures
(in reply to BuschBarber)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
