mount crrc 26 at 90 degrees    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> mount crrc 26 at 90 degrees
Page: [1]
Login
mount crrc 26 at 90 degrees - 1/8/2013 11:29 PM
shane55
Score: 100
Last Login: 3/30/2013
Status: offline
  I am putting a crrc 26 (v1 with standoffs) into a blackhorse glasair 120 and I cant mount it inverted without doing a major hatchet job on the cowl. Is it ok to  mount the engine at 90 degrees? If I do so, I will need  to extend the pipe on the muffler for it to exit the side of the cowl . Can I extend the pipe by 2 or 3 inches without causing running problems? Thanks
< Message edited by shane55 -- 1/9/2013 12:48 PM >
Hide Signatures
       Post #: 1
RE: mount crrc 26 at 90 degrees - 1/9/2013 12:54 AM
Checklst
Score: 115
Last Login: 5/23/2013
Status: offline
Silicon Tubing might do the trick it can handle 356F or 180C temp. I'm just about to try some on my canisters, as the vary hard white silicon connector leaks even using rtv sealant.....the SS pipe is so slick its hard to get a seal unless the tubing is softer.
http://www.ebay.com/itm/Silicone-Vacuum-Hose-Pipe-Radiator-Rubber-Silicon-Vac-Tubing-Air-Dump-Valve-Tube-/260859756315?pt=UK_DIY_Materials_Plumbing_MJ&var=560052959803&hash=item3cbc73ff1b
Just a thought good luck
Hide Signatures
(in reply to shane55)
       Post #: 2
RE: mount crrc 26 at 90 degrees - 1/9/2013 12:46 PM
shane55
Score: 100
Status: offline
right thanks, but does anyone know if the engine can be mounted at 90 degrees or side mounted as I was perhaps incorrectly calling it
Hide Signatures
(in reply to Checklst)
       Post #: 3
RE: mount crrc 26 at 90 degrees - 1/9/2013 1:38 PM
acerc
Score: 221
Last Login: 5/24/2013
Status: online
Yes the engine can be mounted in any orientation you like. The engine does not know which way is up, down, sideways, backwards, etc.
_____________________________
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
       Post #: 4
RE: mount crrc 26 at 90 degrees - 1/9/2013 1:56 PM
shane55
Score: 100
Status: offline
Thanks, thats what I was thinking, just that I dont think I've ever seen one mounted on its side
Hide Signatures
(in reply to acerc)
       Post #: 5
RE: mount crrc 26 at 90 degrees - 1/9/2013 2:17 PM
shane55
Score: 100
Status: offline
scrap that! mounting at 90 degrees will mean a worse hatchet job on the cowl!
Hide Signatures
       Post #: 6
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> mount crrc 26 at 90 degrees
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.469RCU1
