RE: do ailerons provide lift?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
42% Radiocraft Extra 330 with DA 150 and mufflers - RTF
Seller:  hatstien
Details:   $1,750.00   |  5/8/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> RE: do ailerons provide lift?
Page: <<   < prev  1 2 3 4 5 6 [7] 8   next >   >>
Login
RE: do ailerons provide lift? - 1/26/2013 1:15 PM
charlie111
Score: 100
Last Login: 5/19/2013
Status: offline
In a nuetral position they do! or when down like a flap.But only as a control surface It's not lift.You loose lift when you loose wing working surface area
_____________________________
Charlie111 Looking for two h.p. motors with single channel speed control.High Performance maybe equal to o.20 or 0.49
Hide Signatures
(in reply to MTK)
       Post #: 151
RE: do ailerons provide lift? - 1/26/2013 5:14 PM
sensei
Score: 176
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: charlie111
How about when the aileron is up,
but your inverted... I just couldn't help myself. LOL
Bob
Fly It Like You Stole It!!!
Hide Signatures
(in reply to charlie111)
       Post #: 152
RE: do ailerons provide lift? - 1/26/2013 5:41 PM
rctech2k7
Score: 115
Last Login: 4/16/2013
Status: offline
This seems a very good discussion, I saw this topic earlier but nothing I can share because I' ve got the same answer as most of us here. Good job for bringing it into aerodynamics, I learn something I can use for my hornet. I'm planning to use it as added lift devices. The last time I used it works but the problem was pitching effect that looks like it won't adding lift at all while drag might cause an impending control issue. Hopefully it will help by removing some of the weight in the nose.
More than just sports, hobby and recreation, it’s technology…
Hide Signatures
(in reply to sensei)
       Post #: 153
RE: do ailerons provide lift? - 1/26/2013 6:45 PM
charlie111
Score: 100
Status: offline
 You win some and loose some.When turning which is what airlerons are for you would get some lift as a flap would on one side and loose winglift surface area on the other loosing lift on that side!
Hide Signatures
(in reply to rctech2k7)
       Post #: 154
RE: do ailerons provide lift? - 1/26/2013 8:28 PM
BMatthews
Score: 247
Last Login: 5/14/2013
Status: offline
The simple error that so many make is thinking that the control surfaces are something separate. They are not. They are part of the airfoil for good or bad. Adding strip ailerons to an existing wing which did not have ailerons before isn't simply adding ailerons. Instead it changes the airfoil to a new one. The new airfoil has to be considered in total.
Deflecting a control surface does not simply move that one part. Instead it alters the overall airfoil to change the camber value and angle of attack. This is why we get adverse yaw or even tip stalls in some designs if the ailerons are used strongly during slow flight. The downward deflected aileron increases both the angle of attack and the camber of the airfoil. If near but not at the stall point the new AoA and camber can make the resulting airfoil shift up to the high lift but also higer drag portion of the lift/drag operating range. The extra drag can overcome the wing and cause it to drag back and lose lift instead of banking the airplane as intended. In the extrem case where flying very near the stall the downard aileron can push the change to where the resulting high camber and positive angle of attack increase exceed the stall angle. Then you get a tip stall and drop off which needs some altitude for recovery.
Flaps of various sorts do the same thing. They alter the area of the flapped portion to massively increase the camber and angle of attack for that portion of the wing. In the case of wide chord inboard flaps and outboard ailerons this typically forces the outer wing panels to fly at a low or even negative angle of attack. Thus you get gobs of lift and drag but keep the ailerons working very positively as the outer wing portions are flying at a low Cl and thus low Cd value well below the stall. This can work out very nicely with heavy scale models as it acts like adding a LOT of washout to the tips on command. Even if the model doesn't require any extra lift the safety from tip stalling with the flaps down is worth the addtion for heavy wing loading models.
Witty saying to be plagarized shortly.....
Hide Signatures
       Post #: 155
RE: do ailerons provide lift? - 1/29/2013 7:21 PM
DwightMann
Score: 105
Last Login: 5/11/2013
Status: offline
Trim the plane to fly straight and level.
Remove one aileron and fly again.
The difference in trim is due to the lift " contribut
ion" of the aileron
There WILL be a change
Hide Signatures
(in reply to BMatthews)
       Post #: 156
RE: do ailerons provide lift? - 1/30/2013 1:26 AM
BFoote
Score: 100
Last Login: 5/10/2013
Status: offline
Hey, lazy dumb ass here who can't be bothered to do a simple search or read a book but love to post my ignorance and then argue about what I don't have a clue and act as if I do. Got a question.
If I take all the feathers off a birds right wing, can it still fly?
Hide Signatures
       Post #: 157
RE: do ailerons provide lift? - 1/30/2013 3:16 AM
rmh
Score: 252
Status: offline
If it is a left wing type, it can -
Libby is still watching you
Hide Signatures
(in reply to BFoote)
       Post #: 158
RE: do ailerons provide lift? - 1/31/2013 9:35 AM
gerryndennis
Score: 106
Status: offline
Hey BFoote,
I'm looking for posters like you for a new thread I'm thinking of starting. I can't decide wether to discuss how lift is produced, down wind turns or airplanes taking of from treadmills. What wold you suggest.
Sorry couldn't help myself.
Dave
Ultra Sport Brotherhood #89
Hide Signatures
       Post #: 159
RE: do ailerons provide lift? - 1/31/2013 1:34 PM
charlie111
Score: 100
Status: offline
 From looking at all the replys I think you now understand how air effects an airplane.The Airleron on the left side in a right turn does lift the wing! But not from anything other than a deflection of the Airflow.The same applys to the right side.It applys forces downward from deflection.Lift and deflection are totally seperate.Only in a neutral possition does an airleron contribute to lift being part of the wing as a Whole!
Hide Signatures
(in reply to gerryndennis)
       Post #: 160
RE: do ailerons provide lift? - 1/31/2013 5:15 PM
da Rock
Score: 265
Status: offline
You should re-read the post 5 posts before yours. It gives a fairly concise description of what happens.
It's good you mention the ailerons on both sides. Lots of people miss that detail. But otherwise, you're saying a number of things that aren't right.
Ailerons change the amount of lift generated by their sections of the wing. They do that when neutral or deflected. They do that by changing the airfoil of their sections. The resulting airfoil created then changes the amount of lift being generated and sometimes the direction of that lift.
There are a number of fairly inexpensive books available that explain aerodynamics for non-engineers.
Every one of them includes the ailerons as part of the wing and considers their contribution to be constant. There isn't a time they stop contributing.
Good flying wit ya today
Hide Signatures
       Post #: 161
RE: do ailerons provide lift? - 1/31/2013 5:28 PM
eddieC
Score: 249
Status: offline
More like the previous 6+ pages. Love it when folks post to a long thread, but can't be bothered to read what's already there.
I might not be very good, but I am fun to watch!
Hide Signatures
(in reply to da Rock)
       Post #: 162
RE: do ailerons provide lift? - 2/2/2013 9:53 PM
BFoote
Score: 100
Status: offline
quote:
ORIGINAL: gerryndennis
Hey BFoote,
Dave
Treadmills. Definetly treadmills.
People's lazyiness never astounds me. Its a proven fact.
What does astound me is that when lazy people get jerked up short, called to account for their blatant stupid lazyness, they get mad(affronted) and many other people get all weak kneed compassionate actually standing up for these lazy selfish people. That is what I find astounding.
Hide Signatures
       Post #: 163
RE: do ailerons provide lift? - 2/3/2013 1:38 AM
BMatthews
Score: 247
Status: offline
OK, we've all had some good fun over the past page of posts. But the original topic seems to have fallen by the wayside. Unless anyone has something worthwhile that is ON TOPIC to ask or post please leave it alone.
Hide Signatures
       Post #: 164
RE: do ailerons provide lift? - 2/3/2013 5:19 PM
rmh
Score: 252
Status: offline
It all becomes easy to understand if one grasps the basics .
Anything which produces lift -also produces drag .
You can't just pluck one aspect of air working on a solid object - and get the whole picture.
Hide Signatures
       Post #: 165
RE: do ailerons provide lift? - 2/6/2013 6:26 PM
MTK
Score: 203
Status: offline
After a month of a variety of rather amusing posts, I wonder IF the OP got his answer....
One thing certain, it is proven yet again that....that which is so obvious to so many, is not obvious to all.......
Regards,
MattK
Hide Signatures
(in reply to rmh)
       Post #: 166
RE: do ailerons provide lift? - 2/6/2013 9:20 PM
chadxp1
Score: 105
Status: offline
just  remember guys, this did start out in the BEGINNERS forum. Not everyone knows as much about aerodynamics as you.  I can read that many here don't know either. Yes I could have picked up a book and read about it.  I was only looking for a YES or NO answer.
THANKS to everyone for the knowledge. I had a nice time reading everyone's thoughts.
Hide Signatures
(in reply to MTK)
       Post #: 167
RE: do ailerons provide lift? - 2/6/2013 9:39 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: chadxp1
It did? Interesting!
Well.......in a word..... YES!!
Regards,
MattK
Hide Signatures
(in reply to chadxp1)
       Post #: 168
RE: do ailerons provide lift? - 2/7/2013 1:18 AM
mr_matt
Score: 116
Status: offline
quote:
ORIGINAL: eddieC
Sorry, but AOA is required for any wing to poduce lift. Zero AOA is the definition of no lift, no matter what airfoil. I suggest a bit more research for a better understanding of AOA.
Are you speaking of the AOA as measured from the chord line to the relative wind?
Matt
Hide Signatures
(in reply to eddieC)
       Post #: 169
RE: do ailerons provide lift? - 2/7/2013 1:37 AM
eddieC
Score: 249
Status: offline
Mr. Matt,
Yes.
Hide Signatures
(in reply to mr_matt)
       Post #: 170
RE: do ailerons provide lift? - 2/7/2013 1:45 AM
mr_matt
Score: 116
Status: offline
OK I thought there are plenty of airfoils that generate positive CL at 0 ( or even negative) AOA?
Is that not the case?
Matt
Hide Signatures
       Post #: 171
RE: do ailerons provide lift? - 2/7/2013 2:32 AM
eddieC
Score: 249
Status: offline
Could you explain how lift is created at a negative AOA? I'm not an aero engineer, so anythings possible.
Hide Signatures
       Post #: 172
RE: do ailerons provide lift? - 2/7/2013 2:37 AM
BMatthews
Score: 247
Status: offline
I've always seen the AoA referenced to the airfoil center line.
Eddie, what you're referring to is the zero lift angle of attack. Which for cambered airfoils is often a negative angle since the standard is to use the center line (line between the forward most point of the leading edge to the apex of the trailing edge) as the reference for the physical angle of attack to the oncoming airflow.
We see this in the charts attached for the NACA 4412. Note that at a 0 angle of attack that there's still a lot of lift. Depending on which Rn you are looking at the zero lift angle of attack is anywhere from -1 to -5 degrees
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 173
RE: do ailerons provide lift? - 2/7/2013 3:32 PM
rmh
Score: 252
Status: offline
Those good old charts are gibberish to many-
The AOA is is also a meaningless referrence to many people.
What is a true, zero angle of attack?
It is the angle IN FLIGHT, where the wing is producing no lift - just drag.
Can you draw this imaginary line on all airfoils ?
No-
You can guess at it for lots of shapes and get pretty close but once the shape of a perfectly symmetrical foilis altered, the true zero line shifts
A very common, flat bottom , curved top shape - is often thought of as having the zero line along the bottom .
That is a easy referrence line - but not a zero AOA line.
Why?
if the wing moves along on that line . the pressure change under the wing will be very low and above that line - it will be very high.
It will "lift" -simply because the pressure is unbalanced .
You can twist that shape OR force it to travel at a different angle - and ecventually reduce the difference in pressures -above and below the shape- to zero -that is the true zero AOA.
Hide Signatures
       Post #: 174
RE: do ailerons provide lift? - 2/7/2013 5:45 PM
mr_matt
Score: 116
Status: offline
quote:
ORIGINAL: rmh
If you define AOA with reference to the zero lift line, then BY DEFINITION, 0 degrees AOA will not produce lift (that is what the zero lift line is).
That is why I asked eddieC what he meant. He seemed pretty definitive when he said that airfoils cannot produce lift at 0 AOA. I asked if he was referring to the angle of the chord line with respect to the relative wind, which is the only way I have ever seen the AOA reference defined.
As you can see from BMatthews post, you can still get lift at negative A0A.
Matt
Hide Signatures
(in reply to rmh)
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.156RCU1
