RE: do ailerons provide lift?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> RE: do ailerons provide lift?
Page: <<   < prev  1 2 3 4 5 6 7 [8]
Login
RE: do ailerons provide lift? - 2/7/2013 6:12 PM
eddieC
Score: 249
Last Login: 5/21/2013
Status: offline
quote:
As you can see from BMatthews post, you can still get lift at negative A0A.
I suspected as much, from playing with undercambered airfoils.
Fortunately, mankind has progressed since the Wright Flyer and its ilk. For more conventional, efficient airfoils, I believe my original statements still are true. My bad, thinking we were talking about present day technology.
_____________________________
I might not be very good, but I am fun to watch!
Hide Signatures
(in reply to mr_matt)
       Post #: 176
RE: do ailerons provide lift? - 2/7/2013 9:58 PM
mr_matt
Score: 116
Status: offline
quote:
ORIGINAL: eddieC
Positively cambered airfloils can produce lift at negative angles of attack, they don't necessarily have to be undercambered.
Matt
Hide Signatures
(in reply to eddieC)
       Post #: 177
RE: do ailerons provide lift? - 2/7/2013 10:14 PM
rmh
Score: 252
Last Login: 5/19/2013
Status: offline
There is no lift at zero or negative angles
Libby is still watching you
Hide Signatures
       Post #: 178
RE: do ailerons provide lift? - 2/7/2013 10:58 PM
mr_matt
Score: 116
Status: offline
quote:
ORIGINAL: rmh
Didn't you see BMatthews curves?
Unless you defined angle of attack to be reference to the zero lift line and not the chord line, you still have lift at negative AoA.
Click to see fullsize image.
Click for fullsize
Matt
Hide Signatures
(in reply to rmh)
       Post #: 179
RE: do ailerons provide lift? - 2/7/2013 11:53 PM
rmh
Score: 252
Status: offline
Yes, I saw that - The definitions of zero lift line and the chord line - are the problem.
You can NOT have lift if the effective AOA is zero or less
The concept of a lifting surface is simple
it is any shape which may develop unequal pressure- Typically higher pressures under the shape - lower pressures above
How efficiently it does this is quite a different matter . The shape may be perfectly flat -and simply forced to hold an angle of attack
OR it may be a flat sheet - curved and forced to move at a given angle of attack
OR it may be a rather involved combination of curves
IF you change the angle it is moving , such that pressure above and below are equal- THAT is a zero lift path draw that line -
it is the zero lift line .
Hide Signatures
       Post #: 180
RE: do ailerons provide lift? - 2/8/2013 12:20 AM
mr_matt
Score: 116
Status: offline
Let me see if I understand.
"When an airfoil is set to its zero lift AoA, it creates.....wait for it.....zero lift"
I found this on the internets:
quote:
As a wing moves through the air, the wing is inclined to the flight direction at some angle. The angle between the chord line and the flight direction is called the angle of attack and has a large effect on the lift generated by a wing.
And from the same webpage
quote:
Notice on this plot that at zero angle a small amount of lift is generated because of the airfoil shape. If the airfoil had been symmetric, the lift would be zero at zero angle of attack.
Matt
Hide Signatures
(in reply to rmh)
       Post #: 181
RE: do ailerons provide lift? - 2/8/2013 12:36 AM
mr_matt
Score: 116
Status: offline
oops almost forgot the website was
www.nasa.gov
Matt
Hide Signatures
       Post #: 182
RE: do ailerons provide lift? - 2/8/2013 1:48 AM
rmh
Score: 252
Status: offline
Good ol NASA
This is simply an exercize in logic
If No lift is produced was by the moving airfoilthere was no effective angle of attack
stated differently - -there was no effective pressure difference top to bottom
- the wing must be held at some angle to acheive an effective AOA
depending on the shape utilized the appearance of the effective AOA can be misleading . as soon as you throw in"chord line ", things get cloudy
If your idea of the chord line is different than someone elses idea of chord line the AOA will be a different number.
wings ar all about getting effective pressure difference - in the most efficient manner .
How can we as poor model builders know when we have selected the optomized shape?
it's tricky as once yo u change weight - speed and load and speed range- the best shape changes - as does the the necessary shape use to prevent the wing from twisting /bending.
It's all a SWAG- and trying for some "perfect" shape is simply a make work project.
Hide Signatures
       Post #: 183
RE: do ailerons provide lift? - 2/8/2013 4:42 AM
Lnewqban
Score: 163
Last Login: 5/6/2013
Status: offline
http://en.wikipedia.org/wiki/Angle_of_attack
http://en.wikipedia.org/wiki/Zero_lift_axis
Lnewqban - "The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge." - E. H.
Hide Signatures
(in reply to rmh)
       Post #: 184
RE: do ailerons provide lift? - 2/8/2013 2:11 PM
rmh
Score: 252
Status: offline
paragraph 2 says it
< Message edited by rmh -- 2/8/2013 7:29 PM >
Hide Signatures
       Post #: 185
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.516RCU1
