help! which radio to buy? 8fg or 8j.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
HS-7954SH SERVOS
Seller:  hi joe
Details:   $480.00   |  6/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> help! which radio to buy? 8fg or 8j.
Page: [1]
Login
help! which radio to buy? 8fg or 8j. - 1/9/2013 9:45 PM
cloudancer03
Score: 122
Last Login: 6/14/2013
Status: offline
i presently own 2 7c 2.4 systems.i haven'tused one of them either.now that i am getting into gas i really can use more channels. I am torn between the fast 8fg and the less expensive 8J..several years earlier i had the of 2 brownouts using a dx7.so i am atad leary with the 8J. I likey wont use all the extra channels comingwith the 8J. can you give me some advice..i try to stay ahead of the curve and plan to fly many more years.i also have alot of rx 617sand really dont want tosell themoff and just keep them and buy new 8ch rx. are the 617 compatible.?
Hide Signatures
       Post #: 1
RE: help! which radio to buy? 8fg or 8j. - 1/9/2013 9:47 PM
cloudancer03
Score: 122
Status: offline
actually meant wont be using all the addtional ch.on 8fg.lol
Hide Signatures
(in reply to cloudancer03)
       Post #: 2
RE: help! which radio to buy? 8fg or 8j. - 1/10/2013 5:25 AM
Chuck54sd
Score: 100
Last Login: 6/18/2013
Status: offline
I had a 7C.... great radio..... but I upgraded to the 8FG & 8FG Super..... it is an awesome radio plus I can use the same receivers as the 7C.
Without question go with the 8FG Super.... you will be impressed.... and never look back... FASST Rules !!!!
-Chuck
Hide Signatures
       Post #: 3
RE: help! which radio to buy? 8fg or 8j. - 1/10/2013 12:36 PM
DougV
Score: 110
Status: offline
+1. Go with the 8FGS, but if you can afford the new 14SG even better because then you have telemetry if you want to use it and it's also comparable with Futaba's S-FHSS receivers.
Doug.
< Message edited by DougV -- 1/10/2013 3:54 PM >
Hide Signatures
(in reply to Chuck54sd)
       Post #: 4
RE: help! which radio to buy? 8fg or 8j. - 1/10/2013 4:41 PM
pilotpete2
Score: 120
Status: offline
+1 on the 8FG!!
The fact that you already have some R617FS receivers is a very good reason to go with the 8FG, since they will not work with the T8J. FASST compatible receivers from FrSky have a good reputation and are very attractively priced as an alternative to the Futaba models.
http://www.alofthobbies.com/radio-gear/futaba-fasst-compatible.html
Best of luck,
Pete
_____________________________
"If the woman don''''''''t find you handsome, they should at least find you handy"
Hide Signatures
       Post #: 5
RE: help! which radio to buy? 8fg or 8j. - 1/11/2013 6:55 PM
ronwc
Score: 100
Last Login: 6/17/2013
Status: offline
About 8 months ago, I was ready to retire my 15 year old Futaba Super 8, it was a great radio but was time to move on. I started looking at all the different makes and models. I had seen way too many Spektrum crashes so that was not on my list. Came across the 8J when it first came out and it got my attention right away. $239 with coupon from Tower with 2 rx's, and very important to me was that I could get the Futaba 6 channel FHSS rx's for $35 shipped, about 1/2 the cost of Fasst rx's. I generally keep about 15 + planes RTF so rx cost is a big factor. The tx had everything I needed and then some, 20 model memory, backlight display, all the normal programing and no external antenna. I have been using and flying the 8J a lot in the last few month, never any kind of problem. I fly mainly glow, but have 5 or 6 nice electric also, see some pics below -
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Ron - AMA 1025 - Largo, FL
Hide Signatures
(in reply to pilotpete2)
       Post #: 6
RE: help! which radio to buy? 8fg or 8j. - 1/12/2013 3:29 AM
cloudancer03
Score: 122
Status: offline
ron do you fly at sparks? maybe you know ken and tom elder.your review was helpful .love to see the system working. i want the extra channel for igntion.right now i have the 7c and have to piggy back and really need that extra ch. i also fell victum to dx7 browouts and destroyed 2 expensive. 3dhobby planes.have used futaba foryears. dennis
Hide Signatures
(in reply to ronwc)
       Post #: 7
RE: help! which radio to buy? 8fg or 8j. - 1/12/2013 3:41 AM
cloudancer03
Score: 122
Status: offline
ouch! thanks for that info.i have 5. 617s rx i would prefer not have to replace them do youhave re-program. to make the tx reconize the 7 chrx from the 8ch
Hide Signatures
(in reply to ronwc)
       Post #: 8
RE: help! which radio to buy? 8fg or 8j. - 1/12/2013 3:43 AM
cloudancer03
Score: 122
Status: offline
Hide Signatures
(in reply to ronwc)
       Post #: 9
RE: help! which radio to buy? 8fg or 8j. - 1/12/2013 3:45 AM
cloudancer03
Score: 122
Status: offline
just to be clear is there 2 8fg's on the market? specifically is an 8fg and a 8fgsuper?
Hide Signatures
       Post #: 10
RE: help! which radio to buy? 8fg or 8j. - 1/12/2013 2:35 PM
GAToland
Score: 100
Last Login: 6/16/2013
Status: offline
Just 1, The original 8FG was upgraded to the 8FGS which is a 14 channel radio (12 proportional and 2 switched) It is really a nice radio and you can still use your R617FS receivers with this transmitter in 7CH mode.
Gary
Goldberg Tiger Club #55
Hide Signatures
       Post #: 11
RE: help! which radio to buy? 8fg or 8j. - 1/12/2013 9:31 PM
baronbrian
Score: 105
Status: offline
quote:
ORIGINAL: cloudancer03
I are confused.. your 7 channel radio didn't have enough channels but you won't likely use all 8 on the new transmitter?? I'm missing something here.
Contest Director for the AMA
Grand Forks, North Dakota- Where time stands still but the air is always moving.
Hide Signatures
       Post #: 12
RE: help! which radio to buy? 8fg or 8j. - 1/13/2013 4:05 PM
cloudancer03
Score: 122
Status: offline
You are right .but there areprogramming features and upgrades that are important to me as well.since I have an extra radio that I use I will keep that anyway.
Hide Signatures
(in reply to baronbrian)
       Post #: 13
RE: help! which radio to buy? 8fg or 8j. - 1/14/2013 1:17 AM
mattokeol
Score: 100
Last Login: 1/14/2013
Status: offline
Hide Signatures
       Post #: 14
RE: help! which radio to buy? 8fg or 8j. - 1/16/2013 9:40 PM
cloudancer03
Score: 122
Status: offline
after hearing all the comments and thinking this over I am going to stretch my budget and go with the super 8fg ..I can continue with 617s rx and just add the 8ch for the few gassers I have .theres just too many good reasons in favor of that system.the 12 ch is well beyond my means and frankly my needs but the 8fgs is the right fit for me.I am and remain a futaba proud owner.
Hide Signatures
(in reply to mattokeol)
       Post #: 15
RE: help! which radio to buy? 8fg or 8j. - 1/16/2013 9:46 PM
ROBCAR
Score: 100
Last Login: 5/15/2013
Status: offline
Not to hijack the thread but what does anyone think about flying a 100cc yak with a futaba 8J. I am now beginning to think I should of bought a 8FG. Let me have your 2 cents on this question. Thanks
Hide Signatures
       Post #: 16
RE: help! which radio to buy? 8fg or 8j. - 1/16/2013 10:06 PM
cloudancer03
Score: 122
Status: offline
I am likely not the person to advise you..I ended up with the 8 fg in large part for its compatability with all my current 617s rceivers.some of the other guys here that fly those big boys can chime in and give a honest answer.and as I said earlier I am leary to a degree with the technology supporting the 8j.I had the pleasure to experience 2 very expensive brownouts with earlier spectrum dx7. so I went back to futaba and never looked back,
my only personal thought is you probably have a huge investment in your yak and if it were me I would look seriously at least the 8fg or better. but let others with real experince state their thoughts.
Hide Signatures
(in reply to ROBCAR)
       Post #: 17
RE: help! which radio to buy? 8fg or 8j. - 1/17/2013 3:08 PM
Bax
Score: 169
Status: offline
It's not the size of the airplane that should determine your purchase, but the features of the system. You can fly any size airplane with the Futaba 8J transmitter and the receivers available for it. Check the features. For many, the 8J will have the features they desire for the type of flying they do. For others, the 8FG Super's programming offers the options they need.
You can compare the features here: http://www.futaba-rc.com/systems/feature-compare.html
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
       Post #: 18
RE: help! which radio to buy? 8fg or 8j. - 1/17/2013 3:30 PM
ROBCAR
Score: 100
Status: offline
Features are not what concernes me. It's the difference between fasst and fhss that make me feel like the fhss is just for parkflyers and small .40 .60 size planes
Hide Signatures
(in reply to Bax)
       Post #: 19
RE: help! which radio to buy? 8fg or 8j. - 1/17/2013 3:53 PM
ronwc
Score: 100
Status: offline
quote:
ORIGINAL: ROBCAR
I bought the 8J about 6 months ago after retiring my 15 year old Futaba Super 8UAFS. I have flown about 15 different planes with the 8J, all types, 100's of flight - absolutely rock solid. And I have stretched the boundries far out and low - very happy with purchase. You can see soem of my planes above, mostly twins, bipes and 90/120 size stuff.
Hide Signatures
       Post #: 20
RE: help! which radio to buy? 8fg or 8j. - 1/17/2013 10:52 PM
darrolair
Score: 100
Status: offline
I bought the 8J last summer. I use it on my .40, .60, 50cc, and 100cc planes. Absolutely no problems. Really like the programming. Buy the radio that suits your needs.
Good luck,
Darrolair
Hide Signatures
(in reply to ronwc)
       Post #: 21
RE: help! which radio to buy? 8fg or 8j. - 1/18/2013 2:47 AM
cloudancer03
Score: 122
Status: offline
darn he said it right.and thats why I am going fasst and getting the add on's that the super8fg has.I think for an average sunday sport flyer the 8J is fine.but again having had spectrum I am not a fan of the other frequency tecnology.just my personal preference .if futaba says its good I trust it.I havent had one single brown out and have flown my fasst hundreds of flights.and having flown over 30 years I love the software and programming options of super 8 over 8J.
Hide Signatures
(in reply to darrolair)
       Post #: 22
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.734RCU1
