yeah, it's another what starter thread.    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> yeah, it's another what starter thread.
Page: [1] 2   next >   >>
Login
yeah, it's another what starter thread. - 1/9/2013 10:11 PM
Cougar-RCU
Score: 100
Last Login: 4/6/2013
Status: offline
OK gang. I want advise on a really nice starter for my larger OS 4S engines like my 155 etc.
my little Sullivan is kinda dieing or just doesn't have enough ummff anymore well it really never did LOL
I don't want a huge one but want more power !!
Thanks for any info.
Jeff
_____________________________
** CUB BROTHERHOOD ** #90
Hide Signatures
       Post #: 1
RE: yeah, it's another what starter thread. - 1/9/2013 10:44 PM
Ed Vollmer
Score: 105
Last Login: 5/25/2013
Status: offline
http://pacaeromodel.com/FieldEquipment/PowerPanel/PP.htm
The PAM-1002B will do what you want.
The 6:1 ratio will start a 150cc gasser. That is what I have now. I run it on a 5 cell LiPo pack.
Hide Signatures
(in reply to Cougar-RCU)
       Post #: 2
RE: yeah, it's another what starter thread. - 1/9/2013 10:54 PM
Cougar-RCU
Score: 100
Status: offline
Looks Perfect ED thanks I noticed the PAM-1002PP $109 has the battery already.
so you got the other one $59 then added a battery? would you happen
to have a picture of it on how you mounted it?
Also the links to order do not work on that site.
Thanks much
Jeff
Hide Signatures
(in reply to Ed Vollmer)
       Post #: 3
RE: yeah, it's another what starter thread. - 1/9/2013 11:11 PM
Cougar-RCU
Score: 100
Status: offline
ED would somthing like this work for the power?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXLH8&P=7
Hide Signatures
       Post #: 4
RE: yeah, it's another what starter thread. - 1/9/2013 11:38 PM
Ed Vollmer
Score: 105
Status: offline
I actually have the larger 6:1 ratio unit now. At the time it was available without the battery for around $100. I got it and added the 5 cell LiPo. I previously had the smaller one and sold it to get the larger one.
That battery should work fine on the smaller, 3:1 ratio starter.
Hide Signatures
       Post #: 5
RE: yeah, it's another what starter thread. - 1/9/2013 11:41 PM
Cougar-RCU
Score: 100
Status: offline
Thanks ED , so the PAM-1002B will do what I need it to do much
better then my older type starters then. thanks much!
Jeff
Hide Signatures
       Post #: 6
RE: yeah, it's another what starter thread. - 1/9/2013 11:46 PM
Cougar-RCU
Score: 100
Status: offline
ED I just noticed one more thing there is also the PAM-1002 with a bit smaller cone on it. is that the same>? they both say 3.1
I always use smaller spinners anyways and it cost less
Hide Signatures
       Post #: 7
RE: yeah, it's another what starter thread. - 1/10/2013 1:02 AM
Ed Vollmer
Score: 105
Status: offline
Same starter. The rubber insert is reverseable for smaller spinners. I would get the large cone in case of larger spinners later.
Hide Signatures
       Post #: 8
RE: yeah, it's another what starter thread. - 1/10/2013 2:27 AM
Checklst
Score: 115
Status: offline
Hear is my starter....it vary versatile, around the house. and it starts all my gas motors including my DLE55,the cone shaft was taken off an old dead Sullivan starter. I was surprised it would turn over the DLE55 with authority....this Bosh has 600in pounds torque some go higher, a lot go lower. It came with 2 18v lith Ions charger and case.
Hide Signatures
       Post #: 9
RE: yeah, it's another what starter thread. - 1/10/2013 2:30 AM
Checklst
Score: 115
Status: offline
sorry did not mean it to post twice
Hide Signatures
       Post #: 10
RE: yeah, it's another what starter thread. - 1/10/2013 2:55 AM
MTK
Score: 203
Status: offline
I've been using the Dynatron from Sullivan on 6s Li-Po. It works great for up to a 50cc gassie...
If you check eBay every now and then, they pop up for cheap. I got mine new for 99 but a friend got one off eBay for 40, nearly new. Wished I wooda beat'im to the punch. But I'm very pleased with the Dynatron's performance so 100 bucks +around 40 for the 6s Li-Po is no biggie
Regards,
MattK
Hide Signatures
       Post #: 11
RE: yeah, it's another what starter thread. - 1/10/2013 9:35 AM
Cougar-RCU
Score: 100
Status: offline
Checklst,, I have that drill love my Bosch stuff. I am looking for a smaller way to go I think.
MTK ,, I almost won a Dynatron on ebay a few days ago for $49 bucks looked brand new.
I have been carrying this heavy flight box around for years I just want to lighten up a bit from now on.
Thanks guys.
Hide Signatures
(in reply to MTK)
       Post #: 12
RE: yeah, it's another what starter thread. - 1/10/2013 3:18 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: Cougar-RCU
Thanks guys.
The 6S Li-Po I use is 2 x 3S 1500ma in series. I've got the bats and dynatron set-up with Dean's connectors eliminating the clunky clips and the long extension wire. Pretty lightweight and very portable in other words.
The charge lasts several months....I check voltage every month or so and I'm always surprised at how slow voltage is used up in a starter application. In fact since I purchased the Dynatron a year and half ago, I recharged the batteries only twice and I fly a lot. On the other hand, my gas engines seldom need a lot of coaxing; a small bump and they usually start. So glad I made the switch from glow 4 years ago. This is a simple set-up that works great. As always....YMMV
Regards,
MattK
Hide Signatures
       Post #: 13
RE: yeah, it's another what starter thread. - 1/10/2013 3:36 PM
irocbsa
Score: 110
Last Login: 5/26/2013
Status: offline
I am using a similiar setup. I power my Dynatron with 2 3S Lipos in series that are mounted onto the starter with a hokey little aluminum bracket I cobbled together. I rarely have to charge the batteries and my field box is a lot lighter now!
Be aware that the Dynatron contacts like to weld themselves together on 24V, so occasionally when you hit the starter it will just keep spinning. You have to kinda wiggle the hand grip around to get the contacts to separate. Not sure if anyone else has run into this issue, but two other guys at our field that use the same setup have said they experience the same thing.
Hide Signatures
(in reply to MTK)
       Post #: 14
RE: yeah, it's another what starter thread. - 1/10/2013 4:47 PM
Cougar-RCU
Score: 100
Status: offline
how do you wire then series ? then how do you charge them
when hooked together like that? at 14 volts?
I am really liking the LiFe battery's could I do that with 2 of these then?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXYAS9&P=ML
that would give more time correct vers the one I posted above.
Thanks so much guys for all your help.
Jeff
Hide Signatures
(in reply to irocbsa)
       Post #: 15
RE: yeah, it's another what starter thread. - 1/10/2013 4:57 PM
irocbsa
Score: 110
Status: offline
Either buy a harness like this or make your own.
http://www.ebay.com/itm/Deans-Ultra-2S-Series-Y-Harness-Connect-2-Packs-/140531866495?pt=US_Character_Radio_Control_Toys&hash=item20b85a1b7f
Then you can disconnect both batteries and charge them.
Get 2 3s LiFes and that will give you 19.8V for plenty of power.
Hide Signatures
       Post #: 16
RE: yeah, it's another what starter thread. - 1/10/2013 5:14 PM
Cougar-RCU
Score: 100
Status: offline
PERFECT thanks so much !
Hide Signatures
       Post #: 17
RE: yeah, it's another what starter thread. - 1/10/2013 8:02 PM
Prop_Washer2
Score: 115
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: MTK
Thanks guys.
I have the Dynatron with the under mounted case for (12) Sub-C Cells, but would like to use 2x  (3) cell LiFe's or 2x (3) Lipo's. How did you mount the batteries to your Megatron..?? Pics..??
"I ran out of ideas and altitude at the same time..."
Hide Signatures
(in reply to MTK)
       Post #: 18
RE: yeah, it's another what starter thread. - 1/10/2013 8:06 PM
airraptor
Score: 130
Status: offline
One thing for everyone to get more power out of your starters that still use the cord as I do. replace the wire o nthe starter with some 12 gauge speaker wire. This will flow more energy to the motor. the starters use 14-16 gauge wire and isnt enough.
AMA # 186123
I dont always fly inverted, but when I do, I do it down low.
Hide Signatures
(in reply to Prop_Washer2)
       Post #: 19
RE: yeah, it's another what starter thread. - 1/10/2013 9:02 PM
Bill Rademacher
Score: 100
Status: offline
I fly helis and airplanes and I use this:
Sullivan dynatron with a finer edge adapter
http://www.afineredgemfg.com/
Also use a belt reduction unit with the same adapter for larger motors. So I have one battery for two starters.
billrad
I may not be able to turn a kit into a plane, but I can turn a plane into a kit...
Hide Signatures
(in reply to airraptor)
       Post #: 20
RE: yeah, it's another what starter thread. - 1/10/2013 10:13 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: Prop_Washer2
Dynatron?? I don't have the megatron.
The Dean's female connectors are each attached to each 3s LiPo. Each LiPo ia accessible for charging independently, in other words. A shorted male Dean's is inserted into the appropriate female ports sideways producing the 6S set-up. There's no need for adapter wires. Everything is done by the Dean's connectors.
Of course that leaves the other set of ports for the starter. The starter cable was reduced to a short stub about 5" long and a male Dean's was soldered to the leads. I simply plug into the open battery ports. Very compact and light. I'll try to post a snap 2nite.
The battery just hangs out in the breeze. A recepticle might be nice but I don't have one and besides I think it might get in the way. And if I ever dropped the starter, I think anything attached would break off. As I have it now, even when dropped (I've done it) there's no problem
Regards,
MattK
Hide Signatures
       Post #: 21
RE: yeah, it's another what starter thread. - 1/10/2013 10:15 PM
Cougar-RCU
Score: 100
Status: offline
So two of these in series should be enough power at 13.2 volts ?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=L32514&P=7
ordered the above deans harness now waiting for the starter
The cart before the horse I guess.
Hide Signatures
(in reply to Bill Rademacher)
       Post #: 22
RE: yeah, it's another what starter thread. - 1/10/2013 10:39 PM
Propworn
Score: 188
Status: offline
Who needs a field box? Sullivan Dynatron two 3s in series room for 3 glo starters and the box on the back has a push on push off power supply for electric fuel pump or any other 12 volt need. Leave your tool box/field box in the vehicle unless you need it. Fuel bottle has electric pump built into an aluminum lid.
Dennis
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 23
RE: yeah, it's another what starter thread. - 1/10/2013 10:41 PM
Cougar-RCU
Score: 100
Status: offline
Very nice work,, you made this? sell them?
Hide Signatures
(in reply to Propworn)
       Post #: 24
RE: yeah, it's another what starter thread. - 1/10/2013 10:44 PM
Propworn
Score: 188
Status: offline
Thanks, I just made it up got tired of lugging stuff around. I was thinking of designing one that incorporated a handle above the starter with a belt drive and removable cone for even bigger motors yet would retain the small cone at original drive speed for the smaller motors that seem to need faster spin up. Same 12 volt take off for accessories and possibly a quick charge plug for your glo starter. All in one so to speak.
Dennis
Hide Signatures
       Post #: 25
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> yeah, it's another what starter thread.
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.656RCU1
