C rating    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Training >> C rating Page: [1]
Login
C rating - 1/9/2013 11:28 PM
iflircaircraft
Score: 123
Last Login: 5/19/2013
Status: offline
Ok, I got my first electric plane. A chipmunk EP.
I ordered a rimfire 400 brushless motor, a 20A ESC,and a 3S 1300mAh 30C lipo. My question is what is the C rating? Is it the Disharge rate? How does it affect the flight time? Would a 20C give a longer or shorter flight?
Tom
_____________________________
"Where there''s a WILL, There''s a WAY"
Hide Signatures
       Post #: 1
RE: C rating - 1/9/2013 11:37 PM
guver
Score: 174
Last Login: 5/16/2013
Status: offline
C stands for capacity and the number is a multiplier and in this case it is describing the discharge rating (probably constant current MAX)
Theoretically the cell can be discharged at 30 x 1.3 ah = 39 amps and this would equate to the cell being drained in 2 minutes. Your chipmunk won;t use it up that fast so a 20C or a 30C is just fine. The 30C having just a slight power advantage due to it carrying a higher voltage than the 20C. It won't affect flight time any.
and airplanes were in
Hide Signatures
(in reply to iflircaircraft)
       Post #: 2
RE: C rating - 1/9/2013 11:47 PM
iflircaircraft
Score: 123
Status: offline
ok, so I can use a 11.1V 3S 1300mAh 30C lipo or a 11.1V 3S 1300mAh 20C Lipo and get the same flight time? Electric can be so confusing.
Tom
Hide Signatures
(in reply to guver)
       Post #: 3
RE: C rating - 1/9/2013 11:52 PM
guver
Score: 174
Status: offline
Yes, it is the capacity that will determine the flight time. Use a 3sx1500 for longer flight.
Hide Signatures
       Post #: 4
RE: C rating - 1/10/2013 3:02 PM
BarracudaHockey
Score: 280
Last Login: 5/17/2013
Status: offline
Really its the internal resistance of the pack.
The higher the C rating the more current can be pulled from the pack without damage. The lower the resistance the less heat that will be created during high current drain, hence, less chance of damage.
The downside is the higher c rated packs usually weigh a little more and cost more.
Something to keep in mind, manufacturers C ratings are often, shall we say, optimistic. Some mfg's are more like fantasy. So keep a saftey margin.
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to guver)
       Post #: 5
RE: C rating - 1/11/2013 4:49 AM
aeajr
Score: 205
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: iflircaircraft
Tom
EVERYTHING YOU WANTED TO KNOW ABOUT ELECTRIC POWERED FLIGHT
Long Island Silent Flyers
www.lisf.org
Hide Signatures
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
