ESC application    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> ESC application
Page: [1]
Login
ESC application - 1/10/2013 6:28 AM
JollyPopper
Score: 163
Last Login: 6/18/2013
Status: offline
If I have a motor that is recommended to use a 40 amp ESC and I put a 60 amp ESC in the vehicle, will any harm be done to anything in the plane? In other words, is overkill in an ESC going to damage anything?
_____________________________
"In theory, there is no difference between theory and practice; In practice, there is"
Hide Signatures
       Post #: 1
RE: ESC application - 1/10/2013 12:16 PM
cubaneight
Score: 101
Last Login: 6/15/2013
Status: offline
quote:
ORIGINAL: JollyPopper
No, you won't be causing any problems by upgrading to a 60A ESC. Just check that new unit matches or improves on BEC current (don't replace an ESC with a 5A BEC with one with a 3A for example). Also, don't forget that ESCs have a maximum number of cells that they can handle, so check that your new ESC is a match for that as well.
Hope this helps.
Hide Signatures
(in reply to JollyPopper)
       Post #: 2
RE: ESC application - 1/11/2013 2:54 PM
Dr Kiwi
Score: 120
Last Login: 6/1/2013
Status: offline
ESCs only allow through the current demanded by the motor and prop.. a larger ESC cannot force the motor to draw more current. You could put a 10A ESC or a 200A ESC on a motor propped to draw 10A... and with either ESC the motor/prop would only draw 10A.
Dr Phil Millener, Chattanooga, TN
Hide Signatures
(in reply to cubaneight)
       Post #: 3
RE: ESC application - 1/12/2013 6:00 PM
JollyPopper
Score: 163
Status: offline
Thanks guys
Hide Signatures
(in reply to Dr Kiwi)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.156RCU1
