PLASTIC SHEET TO MAKE WINDOWS    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> PLASTIC SHEET TO MAKE WINDOWS
Page: [1]
Login
PLASTIC SHEET TO MAKE WINDOWS - 1/10/2013 9:19 PM
georgek54
Score: 105
Last Login: 5/9/2013
Status: offline
Good Day
Trying to construct the windows on a DOUGLAS DC-3 DAKOTA, I tested various plastics without success, they just can not be glued to polyester fuselage. Now thinking to test thin plexiglass, if I could find 2 or 3 mm thick.
I also saw in Tower Hobbies a material called "LEXAN" which -as Tower declares- is proper for windshields.
Just wondering if this can be glued with EPOXY.
Has anybody tried this?
George
Hide Signatures
       Post #: 1
RE: PLASTIC SHEET TO MAKE WINDOWS - 1/10/2013 10:03 PM
foodstick
Score: 177
Last Login: 5/18/2013
Status: offline
Have you heard of a glue called rc 56, or 560?
It was always sold as sort of a specialty windshield glue
It dries clear, and SLOW.. but it stays fairly soft and REALLY seems to stick about any two things together I have used it on..
Lexan is good for window material,
Hide Signatures
(in reply to georgek54)
       Post #: 2
RE: PLASTIC SHEET TO MAKE WINDOWS - 1/11/2013 12:19 AM
TLH101
Score: 175
Status: offline
+1 to Formula 560 Canopy glue. Works great, and dries clear so those pesky little boo-boos don't stand out. I use it all the time.
http://www.zapglue.com/specialty-glues/
_____________________________
Terry
"Old Fart" in training. (not to be an R/Cer, but to be an "Old Fart")
Hide Signatures
(in reply to foodstick)
       Post #: 3
RE: PLASTIC SHEET TO MAKE WINDOWS - 1/11/2013 6:23 AM
iflytailies
Score: 100
Last Login: 5/14/2013
Status: offline
I have canopy material. It is 1mm thick and can even be put into shape if you have the proper setup and skills:
http://www.iflytailies.com/store/cockpit-accessories/canopy-material/
Owner - IFlyTailies
Hide Signatures
(in reply to TLH101)
       Post #: 4
RE: PLASTIC SHEET TO MAKE WINDOWS - 1/11/2013 7:13 AM
georgek54
Score: 105
Status: offline
Material "Z-433" can be glued with EPOXY?
Or you can also sell the proper glue for this?
Where can I find the "Formula 506 canopy glue"? Is it proper for all kinds of plastic? Because I tried a polysterene glue -normally used for static/plastic models- but also without results.
I understand that each plastic demands its specific glue.
Regards
George
< Message edited by georgek54 -- 1/11/2013 9:38 AM >
Hide Signatures
(in reply to iflytailies)
       Post #: 5
RE: PLASTIC SHEET TO MAKE WINDOWS - 1/11/2013 2:36 PM
Edwin
Score: 156
Status: offline
Not sure if locally available in Greece but Tower and Horizon Hobby has it, a very good glue for wind shields. Other glues that have worked for me was goop, but its a pain to work with. You dont need much. It sticks very well to polyester glass. I wouldnt use that unless the RC56 doesnt work. When I'm desperate and cant get the glue to hold (like a stubborn front wind shield on a busa kit), I used Gorilla Glue, just a slight very small amount was all that was needed. Careful, it foams and you have to wipe off excess. I would experiment with it first. Gorilla Glue is usually available from hardware stores.
Edwin
Hide Signatures
       Post #: 6
RE: PLASTIC SHEET TO MAKE WINDOWS - 1/12/2013 1:54 AM
iflytailies
Score: 100
Status: offline
Tower Hobby sells that glue. Type "canopy glue" in the search bar, and you will get a direct hit. Works very well
Owner - IFlyTailies
Hide Signatures
(in reply to Edwin)
       Post #: 7
RE: PLASTIC SHEET TO MAKE WINDOWS - 1/12/2013 1:52 PM
jaka
Score: 158
Last Login: 5/17/2013
Status: offline
Hi!
You can glue any plastic with RC-56 Canopy glue.
It's like white glue but more flexible.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Jan Karlsson - Supplier MVVS Products
Hide Signatures
       Post #: 8
RE: PLASTIC SHEET TO MAKE WINDOWS - 1/12/2013 3:44 PM
georgek54
Score: 105
Status: offline
Thanks friends,
I will try this glue from Tower Hobbies, hope this will make the job.
Regards
George
Hide Signatures
(in reply to jaka)
       Post #: 9
RE: PLASTIC SHEET TO MAKE WINDOWS - 1/12/2013 7:14 PM
foodstick
Score: 177
Status: offline
Just get it glued well with the 56 or 560, and leave it alone for a couple days, if its not clear its not dry, and if you have a large overlap it can take quite awhile to cure out.. maybe 2-3 days ... It is worth the wait though.. its good stuff.
Hide Signatures
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
