RE: Ziroli DC-3    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Ziroli DC-3
Page: <<   < prev  14 15 16 17 18 19 [20] 21 22 23   next >   >>
Login
RE: Ziroli DC-3 - 11/16/2006 1:00 PM
bluemagic98
Score: 100
Last Login: 2/7/2013
Status: offline
awsome photos i have a colection of them going im going to be working on collecting parts and learning the ins and outs of the air system ussed for the landing gear. I have a lot to do before i finish this thank you for insperation.
_____________________________
Wild Hare 540 Edge-V1/V2 DA-50 JR9303 WH Cap-232 85" Evolution 58 WH Ultimate WH SU-26
Hide Signatures
(in reply to wings2an3)
       Post #: 476
RE: Ziroli DC-3 - 11/16/2006 10:13 PM
SteveD-RCU
Score: 101
Last Login: 6/18/2013
Status: offline
Well done man,congats
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 477
RE: Ziroli DC-3 - 12/1/2006 5:52 AM
PILOT RD
Score: 100
Last Login: 1/20/2013
Status: offline
I sure hate to ask a stupid ?? , but how is the outer wing panel jigged up or blocked up during the build/sheeting to ensure proper washout-incidence? I guess I must have missed this someway.
Hide Signatures
(in reply to SteveD-RCU)
       Post #: 478
RE: Ziroli DC-3 - 12/1/2006 4:56 PM
SteveD-RCU
Score: 101
Status: offline
Not a dumb question,cause you need 2-3 degress of washout.Setup your panels on your bench so you have 0 degress at the root and 2-3 degress at the tip .Blockup the outer ribs accordingly so you have your correct washout and proceed from there.Make sure its correct before and during sheeting also because the sheeting should lock in the washout you built in to it.Hope that helps.
Steve Daly
MAAC #14007
Hide Signatures
(in reply to PILOT RD)
       Post #: 479
RE: Ziroli DC-3 - 12/4/2006 6:26 AM
PILOT RD
Score: 100
Status: offline
I just watched a video of Greg Hahn's C-47 from 2005 at Dayton Ohio, it was really awsome. It looked like the plane had some really bad aileron or wing flutter on one side, then he brung it in for a landing. Did anyone else ever see this or have any input on a cause/prevention? Wish Greg would respond to this or tell me my glasses or medication needs to be changed. RD
Hide Signatures
       Post #: 480
RE: Ziroli DC-3 - 12/6/2006 6:06 AM
PILOT RD
Score: 100
Status: offline
Steve where did you get your tailwheel for your dc3? Roger
Hide Signatures
       Post #: 481
RE: Ziroli DC-3 - 12/6/2006 6:13 AM
SteveD-RCU
Score: 101
Status: offline
It came with the package Roger.Not sure but I think its a Robart type..
< Message edited by SteveD-RCU -- 12/6/2006 6:14 AM >
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 482
RE: Ziroli DC-3 - 12/16/2006 7:13 AM
Delta 3
Score: 100
Last Login: 9/11/2011
Status: offline
Not to interrupt, but it's been awhile.
You'r plane looks great Steve.
What remote video camera system would you suggest to install a plane that would carry reception on a good distance and still have a good picture
Hide Signatures
       Post #: 483
RE: Ziroli DC-3 - 12/25/2006 5:03 AM
kevinlmoses
Score: 100
Last Login: 3/13/2009
Status: offline
Does any of the Ziroli plan require fiberglass, or does the plan show how to build everything out of wood?
Hide Signatures
       Post #: 484
RE: Ziroli DC-3 - 12/25/2006 4:59 PM
PILOT RD
Score: 100
Status: offline
The plans show a built up nose, or you can buy the glass one from Nick. (what I did).After talking to Greg Hahn I question the scale outline of the glass one, but its probably better than what I could carve out of wood. The cowlings are not shown built up as far as I remember, which I got a set of glass ones also. RD
Hide Signatures
(in reply to kevinlmoses)
       Post #: 485
RE: Ziroli DC-3 - 5/12/2007 6:47 AM
bluemagic98
Score: 100
Status: offline
I was wondering what size props you guy's where ussing on the dc-3 i have 2 older us 41's they both have 2 blade props on them 18X6 on one 18X10 on the other. I was considering 16X10 3 blade or possably a 16X8 3 blade.
Hide Signatures
       Post #: 486
RE: Ziroli DC-3 - 5/12/2007 2:46 PM
SteveD-RCU
Score: 101
Status: offline
I have 16x10 MA props.I hope to testfly mine soon.
Steve Daly
MAAC #14007
Hide Signatures
(in reply to bluemagic98)
       Post #: 487
RE: Ziroli DC-3 - 5/12/2007 7:56 PM
FliteMetal
Score: 100
Last Login: 3/22/2013
Status: offline
Send me more images of you with your DC3. Some taken at the field would be even better. If you can
believe it there are still folks who don't think a Flite-Metal covered DC 3 can fly
Ed Clayman,
ScaleAero.com
Hide Signatures
       Post #: 488
RE: Ziroli DC-3 - 5/12/2007 10:42 PM
SteveD-RCU
Score: 101
Status: offline
I can believe it Ed,I'm putting new Fugi 32's with EI in presently and am taking out the used US41's.One has not been running up like it should and I'm getting tired of tinkering with it and I just don't have faith in them so hence the change of power.Plus the Fugi's free up space in the cowl for dummy engines.Steve
Steve Daly
MAAC #14007
Hide Signatures
(in reply to FliteMetal)
       Post #: 489
RE: Ziroli DC-3 - 5/12/2007 11:22 PM
FliteMetal
Score: 100
Status: offline
The Fuji's worked well in Greg Hahn's B-25. They sound a lot better. A pair of
Wms Bros. detailed dummy engines will look great in those cowls. Should be
able to sneak a scale exhaust outlet in there as well.
< Message edited by FliteMetal -- 5/13/2007 1:12 AM >
Ed Clayman,
ScaleAero.com
Hide Signatures
       Post #: 490
RE: Ziroli DC-3 - 5/13/2007 12:59 AM
SteveD-RCU
Score: 101
Status: offline
Ah yes good idea Ed..
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 491
RE: Ziroli DC-3 - 5/14/2007 7:39 AM
a walk in the park
Score: 100
Last Login: 6/5/2008
Status: offline
Pilot RD,
Your glasses are fine, the aileron flutter you saw in the video was caused by a broken DuBro HD servo horn. I've never had that happen before, guess there's a first time for everything.
I promptly installed aluminum horns and she's been solid ever since.
Just finished getting her cleaned up and ready for the flying season, good ol bird!!
gh
Hide Signatures
       Post #: 492
RE: Ziroli DC-3 - 5/16/2007 3:00 PM
SteveD-RCU
Score: 101
Status: offline
Installing the Fugi32EI's now.Man these engines run nice.I also will install the TwinSync from RC Showcase which should be in today..
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Steve Daly
MAAC #14007
Hide Signatures
(in reply to a walk in the park)
       Post #: 493
RE: Ziroli DC-3 - 5/20/2007 1:04 AM
old git
Score: 100
Last Login: 12/26/2011
Status: offline
Hi Steve,
I only found this thread a week ago, how time flies when you come from behind. I loved the info' and pics you posted. I was amazed at the transformation the aluminium skin produced.
Glad to see that you had a successful flight, wish I could have seen it but I wonder how I would have withstood the suspense.
old git - - - - - - aka John L.
Hide Signatures
       Post #: 494
RE: Ziroli DC-3 - 5/20/2007 3:06 PM
SteveD-RCU
Score: 101
Status: offline
Haven't maidened her yet John, hopefully soon.I'm haveing some glitches that I am having when the engines are running.I am moving the batteries and receivers aft to try and eliminate them.The switches for the batteries where less than a foot away from the port engine accessed through the pilots door and when I run that engine I'm getting the glitches so I'm moving the switches also.
Steve
Steve Daly
MAAC #14007
Hide Signatures
(in reply to old git)
       Post #: 495
RE: Ziroli DC-3 - 6/13/2007 5:28 PM
SteveD-RCU
Score: 101
Status: offline
Installed a Futaba FASST 6 ch in her as per the manufacturers instructions and haven't had a single glitch yet while running the engines in my shop.It seems like 2.4 GHz is the answer in this case.I'm sure theres an answer to the glitches I was getting on 72mg,but I really like how this new radio is working.Albeit only 6 ch on a big twin,I have to put up with single stage flaps,and throttles on only one channel,but I can deal with that.Once the Futaba 8 channel modules come out I'll install it.I still have finish up a few things before I bring it out for some taxi tests later ... As you can see the antennas are protruding the bottom of the fuse.I may change this to the top.There is some debate here whether there is more exposure on the top or bottom.
I also ordered some more cowls from Nick Z.,they'll work well with these engines plus they're scale.
Click for fullsize
Click for fullsize
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 496
RE: Ziroli DC-3 - 6/14/2007 12:09 PM
ivves
Score: 100
Last Login: 5/30/2013
Status: offline
Hi.
Just wanted you to know that alu. covered DC-3 is a great flying machine !
Ivan
http://www.junkshop.nu/flyg/micros_ivve_dc3/ivve_dc3_big.wmv
www.ivan-hallberg.magix.net
Hide Signatures
       Post #: 497
RE: Ziroli DC-3 - 6/14/2007 3:53 PM
SteveD-RCU
Score: 101
Status: offline
Nice job Ivan,great video.
Steve Daly
MAAC #14007
Hide Signatures
(in reply to ivves)
       Post #: 498
RE: Ziroli DC-3 - 6/14/2007 9:11 PM
FliteMetal
Score: 100
Status: offline
Hello Steve:
George and I were concerned with the issue of the coax portion of the diversity antenna set up could be compromised if the actual antenna portion was permitted to be blow back by the slip stream.
That is why George utilized the plastic tubes to firmly hold the inserted antenna not only vertical, but at Futaba's recommended differentiated angles. 90' to each other and centered vertically with 45' to the fuselage.
The antenna angles between the two and their positioning within or on the fuselage is critical to the diversity (an actual operational term...not a catch phrase) arrangements proper function.
Here's an image of the way George arranged the plastic tubing for support.
< Message edited by FliteMetal -- 6/14/2007 9:16 PM >
Ed Clayman,
ScaleAero.com
Hide Signatures
       Post #: 499
RE: Ziroli DC-3 - 6/15/2007 5:08 AM
SteveD-RCU
Score: 101
Status: offline
I have since lengthened the tubes since you mentioned it Ed.My new scale NZ cowls just came in also.Those others were too heavy.
Click for fullsize
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 500
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.938RCU1
