RE: Ziroli DC-3    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Ziroli DC-3
Page: <<   < prev  12 13 [14] 15 16 17 18 19 20 21   next >   >>
Login
RE: Ziroli DC-3 - 5/18/2005 4:13 PM
FliteMetal
Score: 100
Last Login: 3/22/2013
Status: offline
quote:
ORIGINAL: SteveD-RCU What about mineral spirts,any brand names?
Its more of an issue to find the small cans instead of gallon containers. WalMart used to have it, Home Depot and Lowes should as well. Paint Dept.
_____________________________
Ed Clayman,
ScaleAero.com
Hide Signatures
(in reply to SteveD-RCU)
       Post #: 326
RE: Ziroli DC-3 - 5/19/2005 9:59 PM
JohnCh
Score: 100
Last Login: 12/28/2009
Status: offline
When building a plane like this, and on other build threads of similar planes, I noticed formers, ribs and other ply parts are pretty much installed as they are from the kit. A lot of weight could be saved by removing the centers of ribs, etc, but I don't see it. Is there some reason? Are solid ply ribs needed because of the stresses involved? Has anyone seen a wing fail due to pared down (hollowed) ribs on a larger plane like this. A couple of hollowed ribs or formers could make up for a whole lot of hollowed balsa blocks. Just asking.
Hide Signatures
(in reply to FliteMetal)
       Post #: 327
RE: Ziroli DC-3 - 5/20/2005 1:30 AM
SteveD-RCU
Score: 101
Last Login: 5/21/2013
Status: offline
I agree with you John ,some weight could be saved if one wanted to go that route.Especially in the aft end were its needed ,one could reduce the amount of nose weight that everybody says they needed to add to get the right centre of gravity.These DC3 plans by Ziroli are pretty dated with not much consideration to weight savings .Still they are great plans.
< Message edited by SteveD-RCU -- 5/20/2005 1:32 AM >
Steve Daly
MAAC #14007
Hide Signatures
(in reply to JohnCh)
       Post #: 328
RE: Ziroli DC-3 - 5/26/2005 4:17 PM
SteveD-RCU
Score: 101
Status: offline
Just a few more pics,nice weather has arrived finally and I have a Bronco ARF to put together so I'll be slowing down a bit on this project,but not for long because I would like to test fly it this year.By that time I should have some twin time under my belt.The right side and underside are basically covered.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 329
RE: Ziroli DC-3 - 6/19/2005 4:27 AM
riptide1
Score: 100
Last Login: 6/6/2008
Status: offline
can you tell me where you got your tail wheel?
Hide Signatures
(in reply to alsez)
       Post #: 330
RE: Ziroli DC-3 - 6/20/2005 4:59 AM
SteveD-RCU
Score: 101
Status: offline
It came with the Robart retracts package.You could probabily get one from Ziroli...
Steve Daly
MAAC #14007
Hide Signatures
(in reply to riptide1)
       Post #: 331
RE: Ziroli DC-3 - 6/21/2005 8:59 AM
Flak
Score: 100
Last Login: 5/22/2013
Status: offline
Great looking DC-3. I am in the process of applying Flite Metal to my Ziroli B-25J. Man, that's a lot of aluminum! Good luck with your project.
"Keep 'Em Flying!"
Flak
"Keep Em Flying!"
Flak
Hide Signatures
       Post #: 332
RE: Ziroli DC-3 - 6/21/2005 3:27 PM
SteveD-RCU
Score: 101
Status: offline
Thanks , right now its on the backburner ,but not for long.I have a few jobs I have to finish before I get back at her.Good Luck on your B-25J Flak...
Steve Daly
MAAC #14007
Hide Signatures
(in reply to Flak)
       Post #: 333
RE: Ziroli DC-3 - 8/5/2005 2:22 PM
riptide1
Score: 100
Status: offline
Can you please let me know where you were able to get a fuselarge for the ziroli dc3?
Hide Signatures
(in reply to F86_SABRE)
       Post #: 334
RE: Ziroli DC-3 - 8/5/2005 2:27 PM
riptide1
Score: 100
Status: offline
steve send me what you want for it . Just lost one need to rebuild.
Hide Signatures
(in reply to cmsrp)
       Post #: 335
RE: Ziroli DC-3 - 8/5/2005 2:38 PM
riptide1
Score: 100
Status: offline
Use 16X10 work great on g38
Hide Signatures
       Post #: 336
RE: Ziroli DC-3 - 8/5/2005 3:05 PM
SteveD-RCU
Score: 101
Status: offline
I'll be getting back to work on my fuse in the near future,did you have a question Riptide?
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 337
RE: Ziroli DC-3 - 8/13/2005 3:32 PM
SteveD-RCU
Score: 101
Status: offline
Am now back at work on the FM covering process,its been a busy summer at work and I now have time to get at it.I am also pleased that Saito came out with this 220 single engine and am seriously considering getting a pair of these powerful engines to replace the US 41cc gassers.My only concern is fuel delivery from the 50 oz centre tank.Maybe those Cline regulators will do the trick here.Doesn't this engine have an optional pump?I thought I read that somewhere....
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 338
RE: Ziroli DC-3 - 8/17/2005 9:52 AM
Achilles_
Score: 100
Last Login: 10/9/2012
Status: offline
http://www.horizonhobby.com/Shop/ByCategory/Product/Default.aspx?ProdID=SAIE220A
Under Features
Fuel pump with larger bore carb available for those that want the ultimate in power.
Hide Signatures
       Post #: 339
RE: Ziroli DC-3 - 8/30/2005 3:07 PM
SPITFIRE47
Score: 100
Last Login: 8/25/2008
Status: offline
my dc3 ziroli under construction, motor: 2 zg 38, constructor , i have 17 years ago,
http://img6.imageshack.us/my.php?image=aaaa00216vm.jpg
http://img6.imageshack.us/my.php?image=aaaa00223tw.jpg
http://img6.imageshack.us/my.php?image=aaaa00231ph.jpg
http://img6.imageshack.us/my.php?image=aaaa00249nq.jpg
@+ aurélien
Hide Signatures
(in reply to Achilles_)
       Post #: 340
RE: Ziroli DC-3 - 8/30/2005 3:29 PM
SteveD-RCU
Score: 101
Status: offline
Nice pics Spitfire 47 was it finished?
Steve Daly
MAAC #14007
Hide Signatures
(in reply to SPITFIRE47)
       Post #: 341
RE: Ziroli DC-3 - 8/31/2005 12:02 PM
SPITFIRE47
Score: 100
Status: offline
not finished
Hide Signatures
       Post #: 342
RE: Ziroli DC-3 - 9/11/2005 12:37 AM
SteveD-RCU
Score: 101
Status: offline
Just a few pics to show I'm still at this project.I have the tail section pretty well covered with FM and am now proceeding with the left side/and top .I have decided to go with Saito 180's on this one.They run smoother and will turn the 16x8 3 bladers at 8200 rpm when you need it.They are also reliable,give off no radio noise,and they sound great,what more could you ask for?I already have one fairly low time 180 so I just have to pick up one more.I see there's a few of em on the RCU marketplace.I also have Cline regulators for the Saito's..
Click for fullsize
Click for fullsize
Click for fullsize
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 343
RE: Ziroli DC-3 - 9/15/2005 6:02 AM
SteveD-RCU
Score: 101
Status: offline
Working up the left side I just finished the doors.The hinges aren't permanent yet because I'm still looking for close up hinge details some where.I've looked at Airliners.net and DC-3.com but haven't found anything real close yet.I'll find something close enough to scale somewhere I'm sure.Now that I have a bit of twin time (15 flights on my OV10) I'm really inspired to get this one ready.
Click for fullsize
Click for fullsize
Click for fullsize
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 344
RE: Ziroli DC-3 - 9/15/2005 10:28 AM
bartnop
Score: 100
Last Login: 7/11/2011
Status: offline
Hi Steve,
Nice work. I am building a dc-3 as well. www.propellor.tv
When you give me your email address I'll mail you close ups of the hinges. I have more than 300 close up pics of a restored Dutch dc-3.
Bart.
http://www.propellor.tv
Hide Signatures
       Post #: 345
RE: Ziroli DC-3 - 9/15/2005 2:57 PM
SteveD-RCU
Score: 101
Status: offline
Thanks Bart.My email is steverdaly@shaw.ca
Yours is also coming along nicely,I seen the door picture on your finishing section of your website and I noticed the back door hinges are a lot smaller than on others.Are those hinges completely different ones or are the others just eqiupped with fairings or are they different types?
Steve Daly
MAAC #14007
Hide Signatures
(in reply to bartnop)
       Post #: 346
RE: Ziroli DC-3 - 9/15/2005 3:08 PM
bartnop
Score: 100
Status: offline
It was the first thing I build and frankly made it as a test. I will be changing those hinges to resemble the original ones better.
I did see different fairings on the back doors. Long ones and short ones. I am not sure which type used what. I am replicating the SAS dc-3 (used to be a c-47) anyway, so I just copy what I see.
The pics will come shortly,
Bart.
Hide Signatures
       Post #: 347
RE: Ziroli DC-3 - 9/15/2005 5:43 PM
SteveD-RCU
Score: 101
Status: offline
Thanks for the pics Bart,they're excellent...
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 348
RE: Ziroli DC-3 - 9/28/2005 6:16 PM
SteveD-RCU
Score: 101
Status: offline
Getting close to finishing the fuse.I still have to add some door handles etc.Here's some more pics of me finishing up the nose..I'm thinking I may open up the nose like the original which will enable me to add weight .I built a tray in front of the cockpit to accomodate this.I also still have to add the observation dome on top of the fuse.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by SteveD-RCU -- 9/28/2005 6:27 PM >
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 349
RE: Ziroli DC-3 - 9/28/2005 6:23 PM
SteveD-RCU
Score: 101
Status: offline
Here's a few pics of the aft cargo doors,I still have to add some detailing here yet also.Then on to the centre wing section.I'm looking forward to ordering the dummy engines and props from Aerotech Models.Sure is nice stuff he has there.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Steve Daly
MAAC #14007
Hide Signatures
       Post #: 350
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
