RE: Ziroli DC-3
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> RE: Ziroli DC-3
Page: <<   < prev  13 14 15 16 17 18 19 [20] 21 22   next >   >>
Login
RE: Ziroli DC-3 - 11/16/2006 10:00:58 AM
bluemagic98
Status: offline
awsome photos i have a colection of them going im going to be working on collecting parts and learning the ins and outs of the air system ussed for the landing gear. I have a lot to do before i finish this thank you for insperation.
_____________________________
Wild Hare 540 Edge-V1/V2 DA-50 JR9303 WH Cap-232 85" Evolution 58 WH Ultimate WH SU-26
(in reply to wings2an3)
       Post #: 476
RE: Ziroli DC-3 - 11/16/2006 7:13:50 PM
SteveD-RCU
Status: offline
Well done man,congats
       Post #: 477
RE: Ziroli DC-3 - 12/1/2006 2:52:15 AM
PILOT RD
Status: offline
I sure hate to ask a stupid ?? , but how is the outer wing panel jigged up or blocked up during the build/sheeting to ensure proper washout-incidence? I guess I must have missed this someway.
(in reply to SteveD-RCU)
       Post #: 478
RE: Ziroli DC-3 - 12/1/2006 1:56:48 PM
SteveD-RCU
Status: offline
Not a dumb question,cause you need 2-3 degress of washout.Setup your panels on your bench so you have 0 degress at the root and 2-3 degress at the tip .Blockup the outer ribs accordingly so you have your correct washout and proceed from there.Make sure its correct before and during sheeting also because the sheeting should lock in the washout you built in to it.Hope that helps.
(in reply to PILOT RD)
       Post #: 479
RE: Ziroli DC-3 - 12/4/2006 3:26:54 AM
PILOT RD
Status: offline
I just watched a video of Greg Hahn's C-47 from 2005 at Dayton Ohio, it was really awsome. It looked like the plane had some really bad aileron or wing flutter on one side, then he brung it in for a landing. Did anyone else ever see this or have any input on a cause/prevention? Wish Greg would respond to this or tell me my glasses or medication needs to be changed. RD
       Post #: 480
RE: Ziroli DC-3 - 12/6/2006 3:06:33 AM
PILOT RD
Status: offline
Steve where did you get your tailwheel for your dc3? Roger
       Post #: 481
RE: Ziroli DC-3 - 12/6/2006 3:13:44 AM
SteveD-RCU
Status: offline
It came with the package Roger.Not sure but I think its a Robart type..
< Message edited by SteveD-RCU -- 12/6/2006 3:14:12 AM >
       Post #: 482
RE: Ziroli DC-3 - 12/16/2006 4:13:05 AM
Delta 3
Status: offline
Not to interrupt, but it's been awhile.
You'r plane looks great Steve.
What remote video camera system would you suggest to install a plane that would carry reception on a good distance and still have a good picture
       Post #: 483
RE: Ziroli DC-3 - 12/25/2006 2:03:42 AM
kevinlmoses
Status: offline
Does any of the Ziroli plan require fiberglass, or does the plan show how to build everything out of wood?
       Post #: 484
RE: Ziroli DC-3 - 12/25/2006 1:59:33 PM
PILOT RD
Status: offline
The plans show a built up nose, or you can buy the glass one from Nick. (what I did).After talking to Greg Hahn I question the scale outline of the glass one, but its probably better than what I could carve out of wood. The cowlings are not shown built up as far as I remember, which I got a set of glass ones also. RD
(in reply to kevinlmoses)
       Post #: 485
RE: Ziroli DC-3 - 5/12/2007 3:47:12 AM
bluemagic98
Status: offline
I was wondering what size props you guy's where ussing on the dc-3 i have 2 older us 41's they both have 2 blade props on them 18X6 on one 18X10 on the other. I was considering 16X10 3 blade or possably a 16X8 3 blade.
       Post #: 486
RE: Ziroli DC-3 - 5/12/2007 11:46:50 AM
SteveD-RCU
Status: offline
I have 16x10 MA props.I hope to testfly mine soon.
(in reply to bluemagic98)
       Post #: 487
RE: Ziroli DC-3 - 5/12/2007 4:56:14 PM
FliteMetal
Status: offline
Send me more images of you with your DC3. Some taken at the field would be even better. If you can
believe it there are still folks who don't think a Flite-Metal covered DC 3 can fly
Ed Clayman
http://www.FliteMetal.com
       Post #: 488
RE: Ziroli DC-3 - 5/12/2007 7:42:20 PM
SteveD-RCU
Status: offline
I can believe it Ed,I'm putting new Fugi 32's with EI in presently and am taking out the used US41's.One has not been running up like it should and I'm getting tired of tinkering with it and I just don't have faith in them so hence the change of power.Plus the Fugi's free up space in the cowl for dummy engines.Steve
(in reply to FliteMetal)
       Post #: 489
RE: Ziroli DC-3 - 5/12/2007 8:22:21 PM
FliteMetal
