F86_SABRE
Steve, What type of servos will you be using for flaps, digital ones? Also, will you be having a hopper tank next to the engine since you will be using one main tank in the centresection? Finally, which engines are you envisaging to be using for the plane? BTW if you have not finshed the outboard panels I suggest that you extend the 3/8" square balsa to W18 since on the plans these stop short just after rib# W17 Regards Reuben
