Ziroli DC-3
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  7/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> Ziroli DC-3
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Ziroli DC-3 - 9/14/2003 10:55:07 PM
SteveD-RCU
Status: offline
I've started assembling my DC3 and will show some photos as I progress.Also I would appressiate any input.Anyone else building one of these?...Steve
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Ziroli DC-3 - 9/14/2003 11:01:38 PM
SteveD-RCU
Status: offline
It takes up all my building table space at 99".This is from a Precision Cut kit which fits together nicely.At this stage I have'nt glued any parts yet.
Click for fullsize
(in reply to SteveD-RCU)
       Post #: 2
RE: Ziroli DC-3 - 9/14/2003 11:05:26 PM
SteveD-RCU
Status: offline
Just trying on the nose section for size.Fits nicely and the glass work is very good.
Click for fullsize
       Post #: 3
RE: Ziroli DC-3 - 9/14/2003 11:07:57 PM
SteveD-RCU
Status: offline
Aft section
Click for fullsize
       Post #: 4
RE: Ziroli DC-3 - 9/14/2003 11:11:35 PM
SteveD-RCU
Status: offline
Robart retracts/tailwheel and cowls.I'll be stuffing a pair of US41's in them.
......more later...Steve
Click for fullsize
       Post #: 5
RE: Ziroli DC-3 - 9/15/2003 12:50:00 AM
William Robison
Status: offline
Steve:
I realize it will raise the engine cost somewhat, but don't you really think such a nice scale project deserves a more scale engine than the US 41?
I'm waiting for a pair to go in my F7F. Couldn't resist them.
Prices and specs here:
http://www.technopower.com/
Bill.
Click for fullsize
Click for fullsize
_____________________________
Real Airplanes have Two Engines
AMA 25139 - More than 40 years.
       Post #: 6
RE: Ziroli DC-3 - 9/15/2003 1:04:18 AM
SteveD-RCU
Status: offline
Acually I initally wanted to install radials Bill but the bigger Technopowers dont fit and the smaller ones dont have the power,Also the Saito 170's are just a bit too big for the scale cowls.I could make a bigger cowls and would involve enlarging the nacelles a bit.Could be done.The 170's would be nice.I could also opt for a V twin.....
< Message edited by SteveD-RCU -- 9/15/2003 1:13:08 AM >
(in reply to William Robison)
       Post #: 7
RE: Ziroli DC-3 - 9/15/2003 1:40:59 AM
William Robison
Status: offline
Steve:
Have you considered the OS R5-300? It's about the same six inch diameter of the A7 and B5 Technopower, and a lot more powerful.
Or for less money and even more power the ASP five cylinder radial is a full 4.0 cid, one third larger displacement than the OS. If you have room that one would do very well.
I just wanted more than five cylinders showing, so that meant the Technopower A7. Granted, it's only 1.35 cid, but my f7f issmall enough to fly with 0.40 two strokes, so my only problem will be trying to make up for the weight.
Bill.
< Message edited by William Robison -- 9/14/2003 7:41:23 PM >
       Post #: 8
RE: Ziroli DC-3 - 9/19/2003 10:02:11 PM
F86_SABRE
Status: offline
Hi,
At the moment I am building the Ziroli DC-3 albeit I have a fiberglass fuselage that mates very well with the rest of the Ziroli plan. I wish to know:
1. what the "normal" anticipated weight of the plane is.
2. information of how the plane flies (i.e. any vices).
Like Steve, I will be doing the DC-3 in the Canadian Air Force scheme although not with the double lightning flash as shown in Steve's photos. In this regard I would appreciate any further information as to the light grey FS number found on the lower part of the fuselage and on the wing underside.
Any ancillary information or tips one might have on the Ziroli DC-3 would be most welcomed.
Regards
Reuben
       Post #: 9
RE: Ziroli DC-3 - 9/20/2003 1:18:33 AM
SteveD-RCU
Status: offline
Hello Reuben;45-50 lbs is the projected weight.What engines are you using in your 3?I dont know of any vices the DC-3 has.Its supposed to be the best big twin to start out with,although I plan on getting some twin time on a Twin-Air 40 first.
Do you have any pics of the glass fuse?...Steve
< Message edited by SteveD-RCU -- 9/20/2003 1:19:09 AM >
       Post #: 10
RE: Ziroli DC-3 - 9/20/2003 8:57:45 AM
F86_SABRE
Status: offline
Hi Steve,
I had in mind in using either the MOKI 30cc gas engine with rear induction, rear exhaust (or sideways) or the MVVS 30cc gas too or the Tonini 25cc (german gas engine).
I wish to keep on the lighter side of this if possible. I also have in mind in using the MICK REEVES fiberglass covering instead of the traditional balsa/fiberglass system but still have to find out how much I need.
Its no problem in putting up a few shots of the fiberglass fuse...getting out doing it is the problem! heheheh
Steve...have you got any documentation regarding the FS number of the light grey that was used on the underside by any chance? I got my color scheme from a book about the DC-3 I have of the real DC-3 Canadian Airforce. Another scheme I like is the OTIS SPUNKMEIER scheme but unfortunately I dont know which type of fonts they use in their wording.
Catch you later.
Reuben
       Post #: 11
RE: Ziroli DC-3 - 9/20/2003 12:33:37 PM
SteveD-RCU
Status: offline
Not sure about the paint numder for that grey but can look into it Reuben,have you
checked out Douglasdc3.com ?
Steve
       Post #: 12
RE: Ziroli DC-3 - 9/20/2003 1:06:29 PM
warbirdz1
Status: offline
Steve....Keep in mind that your plane is gonna require some nose weight.......might as well install the weight as "horsepower".....have seen several with G-38's(Rear exhaust makes a nicer fit) and they fly quite nicely.......If you are inclined and a "Radial" can do the job for you.....even better.......as always with a twin........reliability is the key.....if the engines aren't performing well....don't fly it til they do.........specifically even more so with a taildragger.......nearly impossible to keep a good track on the T/O roll with engines that don't turn an identical RPM( within 200 RPM)......not the easiest to fly on one engine but will do it with adequate power.........Good Luck....Keep us posted ......Bill......
       Post #: 13
RE: Ziroli DC-3 - 9/20/2003 4:17:34 PM
SteveD-RCU
Status: offline
Thanks for the input Bill.I'll stick with the US 41's I have,because they are a reliable engine and they have some weight...Steve
Click for fullsize
       Post #: 14
